Question about HP Officejet Pro L7680 All-In-One InkJet Printer
HP Officejet Pro L7680 All-in-One Printer is printing blank pages. Copies, prints, nothing is printing, all the pages are blank, I just in stalled new catridges and still nothing.
websnail
  • 419 Answers
SOURCE: when printing on my HP
The HP88 printhead can dry out and cause clogging in the black part of the K/Y (black/yellow) printhead.
This has been a major problem for a few client schools of mine and for me in my attic space where air conditioning and/or hot dry air causes clogging.
You may want to consider purchasing a new printhead and an alternative black ink supplier (non HP) that uses Dyebase ink instead of pigment as this doesn't clog in the same conditions.
However, please note that if you do this it means you may lose your warranty (certainly on the printhead) and the printout won't be as clear for text as the black ink can "bleed" slightly into other colours. It has however solve the problem of clogging in one school that went through 5 printheads in two terms/semesters until we switched.
Posted on Jan 23, 2009
jimfernbank
  • 31 Answers
SOURCE: How to set date/time on HP Officejet Pro L7680
Instructions are on this web page:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01566785&lc=en&dlc=en&cc=us&product=2512009&rule=29401&lang=en
Posted on Mar 25, 2009
usopm
  • 33 Answers
SOURCE: HP Officejet Pro 8000 Printer goes through motion
your pint head dirty. so pls clean with wet close. if not work try soak with warm water until all dry ink gone pls be carefull when you do that make sure your print head dry before you use again.
Posted on Aug 10, 2009
efs_perpends
  • 1996 Answers
SOURCE: HP Officejet Pro K5400 printer catridge stalled
If you press and hold resume, will the carriage move over to the left? Hold it until it stops moving.
If that doesn't work, try resetting the printer, by following these instructions. This article may also apply.
Unfortunately, HP does not have any instructions on the support site for resolving a carriage jam for your model, and I am hesitant to instruct you according to another printer, without experience working on that particular machine. If you are still unable to correct the situation after following steps listed above, please contact HP tech support directly, here.
If you want to research the options available online, you home support page is here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Sep 01, 2009
  • 71 Answers
SOURCE: HP Officejet Pro L7680 prints half page only
to get to the root cause of the problem . you can try printing from the notepad and check it prints fine from the notepad . if it prints fyn then there can be some issues with the software compatibility.. which version you have for microsoft office.
Posted on Oct 20, 2009
I have an HP L7680 all in one printer/fax/copier. It prints just fine, it copies just fine, but INCOMING faxes do not print the entire page. What do I need to do?
first check all the connection to the printer check the phone line connected firmly on the printer then check for dial tone try to dial from the fax in the printer to any other number then return the call to the fax
Apr 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 When printing a power point presentation, lines are printing over the jpeg pictures on the slide
There is some problem with your print heads. Run a print diagnostic report and see if it helps. You also may want to trigger clean cartridges if triggering print diagnostic page does not help.
This issue may happen if the printer is not used for few days. Recommend to keep the printer powered on always, or then trigger print diagnostic page as it tries to unclog the blocked print heads to give you a clean print.
Hope this helps.
Oct 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
Oct 20, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP All-in-One Printer Series 1300 prints blank copies
Have you tried printing a test page from the printer itself. usually holding down the power button will instruct the printer to print a self test by itself.
Mar 10, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All In One Printer Spits Out Blank Papers.
Are these new cartridges? If so, take the protective plastic off of the cartridge and reinsert them:)
Feb 15, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP officejet pro l7680 all in one
Most likely the print head has failed and the black is not printing which is causing the printer to have issues. Talk to HP as I guess printheads have warranty or simply change the yellow/black printhead. Or if all of these fail give the machine to HP to get you a new one as this is not right. I hope this helps.
Nov 18, 2008 | HP Officejet Pro L7680 All-In-One Printer
PRINTING BUT NOT PRINTING ALL INFORMATION
u need to install the proper printer drivers again.
Nov 17, 2008 | HP Officejet Pro L7680 All-In-One Printer
AUTOMATIC ORIGINALS FEEDER
I'm trying to print/fax several pages but the feeder doesn't "grab" the paper--basically nothing happens...BTW, mine is the HP Officejet Pro L7780 All-In-One.
Sep 10, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One InkJet Printer Logo
173 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
