Question about Brother LS-2125 Mechanical Sewing Machine
HOW DO I THREAD FOR THE FIRST TIME A WHITE 1977 JEANS MACHINE?
What is a never used white jeans machine model 1077 worth?
Umm, an unused old sewing machine sounds like it should be worth a lot, however, in retrospect, machines need to be used and maintained regularly. Most likely the machine needs a thorough service as the oil has probably dried out over time and has/will seize the machine.
Vintage White Zig Zag Sewing Machine Model 1077 Cover Jeans Machine eBay
Jun 19, 2018 | Sewing Machines
My white 1800 jeans machine sewing maching is working but not stitching.
So the top thread is not picking up the bobbin thread? Try a brand new needle. If that doesn't work, then the machine is probably knocked out of time. Search for sewing machine timing or take it for service.
Mar 24, 2018 | Sewing Machines
Cant remember how to thread my White sewing machine Blue Jeans Machine model#1088
Here is a link to a very good site has a little of everything about sewing machines.http://www.sewusa.com/Threading_Diagrams/Threading_Pages/White_Sewing_Machine_Threading/white_1077_1088_1099_1122_threading%20Diagram.htm
May 13, 2012 | White Sewing Sewing Machines
The lower thread does not bring up , so that the uper thread does not come in contact with the lower thread .I hear unusaul noise while sewing.All these happend when I tried to sew a jeans .i used a thread...
As a general rule, domestic machines don't like buttonhole twist, that heavy yellow thread you see on the RTW jeans. Sometimes you can put it through the bobbin but use a regular weight thread on top but this means sewing upside down as you'll want the yellow on top. And lots of machines dont like different weight thread top and bottom so it just makes for awful stitching anyway.
Best solution to top stitch jeans is use a regular weight thread, large size jeans needle but thread up two spools of thread on the top with both threads going through the same needle eye. It still may not solve the problem though.
To your machine, firstly change the needle as it may be bent. Then unthread the machine and manually turn the flywheel through a stitch cycle and listen carefully, if you still hear a noise as the needle touches the rotary hook, you've knocked the timing out. Service man visit time.
Probably if you check the manual, it will say 50 weight thread, and you'll need to stick with that in the future.
Those big industrial sewing machines that they top sew jeans on are very different to a domestic SM, many make a chain stitch or fell the jeans seams and are very heavy duty.
Jun 05, 2011 | Toyota STF17 Sewing Machine
White model 1977 jeans machine
You can get the manual on link below # 82. Sorry there is no free one.
http://www.sewingmanuals.com/Sewing_Machine_Manuals/White.htm
Jan 05, 2010 | Sewing Machines
Hello I am new to the sewing hobby.My switches were fine during sewing a curtain then under & top stiches are a messed up. I rethread it might do fine 1/4 way down starts all over agian. Don't have a...
Here is a list of the model #s I found 1422 is not included are you shure about the #?
White 1077
White 1088
White 1099
White 1122
White 1202 1213
White 1240
White 1409
White 1411
White 1418
White 1466
White 1477 1488
White 1505 1510
White 1570 Classmate
White 1599 Jeans Machine
White 1600 Speedylock
White 1632
White 1700
White 1717
White 1760
White 1766
White 1787 1899
White 1800
White 1919
White 1955
White 1977
White 2000SM
White 2037
White 2134
White 2137
White 2220
White 2222
White 2837
White 2999
White 3077
White 3355
White 3900 F
White 4075
White 6477
White 7934
White 8000
White 8600
White 8800
White 8910
White Computer Machine
Nov 19, 2009 | Sewing Machines
Brother LS-2125 Mechanical Sewing Machine Logo
61 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
