Question about PPI Car Audio & Video
Hi I have a very old I know.ppi-2300 and I need a install manaul mostly for the sub wiring and remote in.can u e- mail me diagram @ Danracerx@gmail.com thanks And can u run just 1 sub?
  • 61 Answers
You can try to open google.com type the model and diagram
Posted on Aug 04, 2010
I have a PPI PCX-2400 and want to power two TREO subs that handle 2500 watts apiece. What is the best way to ire the PPI to these subs so that I get as much power from the amp to the subs without causing...
That would depend on the impedance (resistance) of the subs. Your best bet would be to use the full power of the amp to one channel (i.e. bridged) instead of to two separate channels (i.e. stereo). Two 4 ohm subs wired in parallel would present a 2 ohm load to the amp, which should allow you to get all 1600w out of it.
This explains series vs parallel quite well:
http://www.termpro.com/articles/spkrz.html
Mar 03, 2011 | PPI PCX-2400 Car Audio Amplifier
Is there a wiring diagram for the nikkai EAPA450 Amp
Hi, if you still need a photocopy of instructions email me mail@srands.co.uk
If you want instructions in brief this involves POWER CONNECTIONS, PHONO LEAD & SPEAKER CONNECTIONS:
POWER (At the same time when routing these wires, I would connect the PHONO LEADS from the car cd player to the amp, if your car cd player only has 1 preout (1red & 1 white) then you will need two phono splitters, a female to 2 males. Phono leads carry the unamplified sound from cd player to the amp):
~ Permanent 12V+ (Thick lead that is fused direct from battery all the way to the amp, wire must be 20a to 30a +, hence 1cm diameter wire, known as AWG8, Maplin sell cheaper kits then most)
~ Amp REMOTE (A thin insulated cable (5a is OK) from car cd player amp remote wire, this turns the amp on when the cd player is on, if your car doesn't have an amp remote wire, suggest nearest ignition supply or seperate switch that you turn on when you want to turn on the amp)
~ GrouND 12V- (Insulated lead (20a to 30a) to nearest part of unpainted car chassis such as interior panel screw hole, instead of an insulated cable all the way from the batery, this is common practise.
SPEAKER:
Each speaker has a - negative & + positive, these must connected correctly. The amp has 4 channel, 2 channel labeled as front, 2 channels labeled as rear. Using speaker wire, connect cable from amp to speakers. Note: Ensure the speakers being connected only receive sound from the amp (Not cd player as well, as would damage players or at the very least impair sound)
The amp has a feature called bridgeable this means a sub 8" or 10" sub can be powered by 'bridging' two channels. For example there are 2 ways to bridge power a Sub on the NIKKAI EAPA450:
i) Sub speaker wire positive + to channel RL and Sub speaker wire negative - to channel RR.
OR
ii) Sub speaker wire positive + to channel FL and Sub speaker wire negative - to channel FR.
Switches:
~ Bass boost, meant to be on for a channel if using sub, otherwise off.
~ X-over mode adjust hi/lo frequencies, only work if both x-over switches are on! Then adjust switch frequency knob, until it sounds right.
~ Gain (Volume knob) adjust volume knob up or down, until it sounds right!
NOTE:
You will need patience! many hand tools and parts such as: Wiring kit, fuse holder 20a/30a, Phono leads, speaker cable, Fork/ring connectors, wire strippers, wire cutters, set of screw drivers, also ueful to have zip ties to tdy excess cable and 'P' cable clips to tidy speaker wire to shelf, etc.
OK
Any more questions just email me mail@srands.co.uk
Dec 01, 2009 | Car Audio & Video
'04 Nissan Sentra S factory installed subwoofer wiring diagram
A FACTORY INSTALLED AMP/SUB WILL BE WIRED INTO THE VEHICLES FACTORY WIRING JUST AS ANY OTHER COMPONENT. YOU WOULD THINK THAT YOU WOULD FIND THICK POWER AND GROUND CABLES ALONG WITH RCA CONNECTIONS AS YOU FIND WITH MOST INSTALLS.NOT THE CASE HERE.YOU MUST FIND THE HARNESS THAT HAS THE POWER AND GROUND CONNECTIONS ALONG WITH THE INPUT WIRES FOR SOUND. YOU MUST OBTAIN A VEHICLE SPECIFIC WIRING DIAGRAM THAT HAS THE WIRING FOR THE SOUND SYSTEM PACKAGE THAT CAME WITH YOUR VEHICLE. YOU MUST THEN WIRE IN THE BLUE REMOTE TURN ON LEAD FROM YOUR UNIT TO TURN THE AMP AND SUB ON WITH YOUR RADIO AND NOT YOUR CAR BATTERY. YOU WILL ALSO NEED TO FEED SOUND TO THE AMP USING ONE OF THE REAR OUTPUTS FROM YOUR RADIO.
Sep 05, 2009 | Car Audio & Video
I have a PPI 2075AM amp.Plastic connector whats, what?
the sticker usually shows u the exact way the leads r set so just use the sticker
Aug 10, 2009 | Car Audio & Video
I need to know who is better for my cherokee sport 1999 ..!!!
Hello leonardoe,
The MB Quart's are component speakers and the PPI's are coaxials. In an "apples to oranges" comparison, the MB Quarts win. Most component systems in the same price range as a coaxial will have better sound imaging simply because you can mount the tweeters up high for better high frequency dispersion. Some also allow you to make adjustments to the crossover, which is built-in and fixed on the coaxial.
But component systems are more difficult to install. If your vehicle doesn't already have the wiring for separate tweeters, you have to install it. Likewise, the mounting of separate tweeters adds to the installation complexity.
Hope this helps.
Jul 15, 2009 | PPI PC650C Coaxial Car Speaker
I need a replacement for my logitech z-2300 speaker wired remote control. How and where can I get one?
To the two people with problems. This sounds a bit odd, but do you still have the broken remotes? I'm looking for a broken one. I'd pay shipping and throw a few bucks your way if you could send it to me.
AIM: gonzoleben
Email: andywitzz [at] gmail [dot] com
Thanks!
-Andrew
Apr 14, 2009 | Logitech Z-2300 Computer Speakers
Broken D-sub cable
I would advise against a direct solder inside the unit. I would go and purchase a replacement connector from a Radio Shack or other electronics parts store. Solder wires to this, then plug in, should fix problem.
Apr 03, 2008 | Logitech Z-2300 Computer Speakers
Wired remote cable extension
Most monitor cables have only 14 of the pins connected, but if you get a fully wired svga extention cable it does work fine.
Steve
Mar 23, 2008 | Logitech Z-2300 Computer Speakers
Sub hook up to PPI D3000 amp
I'm not familiar with this amplifier but in most cases, if a mono amp has more than one positive speaker terminal and more than one negative speaker terminal, the positives are directly connected and the negatives are directly connected. So  as long as you connect the speaker positive to a positive speaker terminal of the amp and the speaker negative to a negative speaker terminal of the amp, it will work properly.
Oct 12, 2007 | PPI D3000/1 Car Audio Amplifier
Problem in ppi pcx-2400
Check the amplifiers fuses. Some amps have speaker fuses that leave the LED on if blown. Check for continuity on the voice coils of both subs. Check for 12 volts on the remote turn on line from your receiver. If all of the above are good, the amp is probably toast.
Jul 15, 2007 | PPI PCX-2200 Car Audio Amplifier
Car Audio & Video Logo
54 people viewed this question
Top PPI Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
hoyzee1
Are you a PPI Car Audio and Video Expert? Answer questions, earn points and help others
