Air Conditioners
Problem for Air Conditioners
Generic problem for all Air Conditioners
My Kenmore room AC spews
By misterbb on Apr 26, 2008
my Kenmore room AC spews black, carbon-like particles when running.
I have cleaned the filter, with no change in the particle emmision.
Solution #1
posted on Apr 26, 2008
Not Rated)
textonor
Rank: Guru
Rating: 88%, 131 votes
misterbb I have the same thing happen with the LG in my office. I took the unit out, then took it outside, sprayed the front and back coil will Greased Lighting or dishwashing detergent mixed with water and washed it down with a garden hose. What is happening if like mine is that the dirt and such has built up on your fan blade, condenser coil, and evap coil and the unit just needs a good cleaning. I use to work in a shop in Texas where we did a lot of window units and cleaning was just part of the job. The coils should be bright and blade clean. Also if you take the cover off you should oil the fan motor with a light weight household oil. Hope this helps.
Popular Solutions for Air Conditioners
Questions and Unsolved Problems for Air Conditioners
Answer
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a... (More)
Answer
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at... (More)
Answer
My heater is not working. When the thermostat is placed in HEAT mode, it sounds like the blower is... (More)
Answer
just pourchased a PBE123A35MA on line Was told the fan cycles on & off however that is only... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air... Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
