Question about Milwaukee Tool Milwaukee 6010 - 6 1/2 Sheet Orbital Sander
I'm sanding my cedar deck prior to re-staining it. I've rented a Milwaukee 6010-6 5 Amp 1/2 Sheet Orbital Sander to do the edges up along the house: I'll be using a bigger sander for the bulk of the job once this is done. My problem is, the sandpaper sheets keep ripping and need to be replaced. I must be doing something wrong. Am I putting too much weight on the sander? I assumed this was the right technique because there's lots of dead wood on the surface and I need to sand down quite deep, but perhaps I shouldn't be putting so much weight on the sander? Or is there some other likely problem? (It's not snagging on nails: I counter-sank them all quite far to avoid that.) Thanks! My name is Ron.
    New Friend:
Ive stained my ceder deck 2years in a Rowe and I preassure washed It
Posted on Jun 01, 2013
danny_murray
  • 55 Answers
SOURCE: power tool switch
Call this number they are in ohio but have in the past been able to help out 937-325-6441 give them the part number and tell them you have not been able to locate the part
Posted on Dec 04, 2008
danny_murray
  • 55 Answers
SOURCE: 7336 orbital sander
If you are talking about the actual sanding pad itself it should just pull of .If you are talking about the backing pad it should un screw
mikeymiddles
  • 58 Answers
SOURCE: Orbital sander flicking the sand paper off
You did not specify how the sanding discs are meant to be attached to your sander's backing pad.  My experience with this type of problem is material from the sanding process builds up on the backing pad and does not allow the sanding discs to adhere properly.  If you have a velcro type system, clean the hooks on the sander's backing bad by soaking the pad's face in a plate of paint thinner for 20 to 30 minutes then use a wire brush to remove the rest of the paint physically.    For adhesive pads clean the sander's backing pad surface with denatured alcohol.  Do not use isopropryl or rubbing alcohol as this may not be 100% alcohol and could contain a lubricant like glycerin.  When the sander's backing pad is completely dry and clean it will hold adhesive backed pads fine.    Flaky paint is best scraped off before sanding, use a wide putty knife or a paint scaper to remove large flakes before sanding.  This will minimize airborne dust and cleanup.    For best results with adhesives, always keep your surfaces  clean!    Good luck and happy sanding!  Michael Mittelsdorf
Posted on Jan 10, 2009
rowdy45176
  • 2176 Answers
SOURCE: replace sanding pad on random orbital sander dw443
You will find usually 3 torx drive screws on the bottom of the tool, remove them and the pad comes off. The replacement pad number is 151416-01 list 27.49. Let me know if I can help further
Posted on Feb 23, 2009
  • 104 Answers
SOURCE: replace velcro pad on rupes random orbital sander
I have replaced velcro on various sanders , you just take the original velcro off and make sure that the base is very very clean, use turps and metho to clean it with then buy some velcro from a good hardware supplier and really good glue [two pack epoxy is best ] and simply cut to size and then just glue new velcro onto the base of the orbital sander
Posted on May 23, 2009
Need to get the case off Milwaukee 1/4 sheet sander
Look for a screw underneath the product information label. Hiding one screw under that is a favorite way tool manufacturers use to tell whether the tool owner has disassembled it, for warranty purposes. You can usually locate these screws by rubbing briskly on the label; the screw will be in an indentation.
Be sure to take a picture or make a copy of the label before you damage it!
Nov 29, 2012 | Milwaukee Tool Milwaukee 1/4 Sheet Orbital...
I am recently widowed and don't know how to get the sand paper out of and onto the sander
At both ends of the bottom pad, there are metal fittings that have a rectangular hole in the middle of them. Take a regular head screwdriver and put the tip in the hole and carefully but firmly lift up and hold while at the same time pushing the narrow edge of the 1/3 sheet sandpaper up under the metal piece which kind of looks like a C on its edge. Then let down the metal piece with the screwdriver and that edge of the sand paper should be held in place. Do the same thing for the other end of the sandpaper, making sure to pull the sandpaper sheet tight against the rubber pad.
Oct 08, 2010 | Black & Decker 7448 1/3 Sheet Orbital...
Palm sander 6016... i have to replace the
you dont need a puller for the fan, remove the lower pad assembly and the torx screw holding the bearing in place. use a screwdriver to gently lift the fan. the bottom of tool has to be disassembled to open the halves. Go to Milwaukeetools.com and type in your model number under the download section for a parts/tool explosion. Let me know if you need more assistance
Aug 25, 2010 | Milwaukee Tool Milwaukee 1/4 Sheet Orbital...
Dewalt d26451 type 1 random orbital sander. why does this sander jump around on the material and feel like it's fighting me all the time instead of sanding smooth and easy?
I have the same problem with a Porter Cable orbital sander I recently purchased. Whats happening is the sander is catching the edge of the board you're trying to sand and jerking back and forth as the sander base spins. It seems that if the board your're sanding is at least as wide as the sander base, the problem goes away, which does little good because there will be many times I we'll need to sand wood that is less in size. But you may try using a lesser grit sandpaper and see if that alleviates the problem somewhat.
Aug 10, 2010 | Dewalt Heavy - Duty 5" Random Orbit Sander...
The vibrating plate stopped vibrating but the motor seems to be working ok. Either the plate is jammed or something broke. What do you think? This sander is probably 30 years old, very heavy duty.
check the bearing in the platen, it is probably seized up. you can go to Milwaukeetool.com and download a breakdown for this tool. Let me know and I will try and help further.
Aug 08, 2010 | Milwaukee Tool Milwaukee 6010 - 6 1/2...
I need to remove the fan on my black and decker pad sander but theres no way to clamp the armature to unscrew the fan
Why would you want to remove the fan? There is a good chance that the fan is molded to the shaft and can not come off.
Jul 13, 2009 | Milwaukee Tool Milwaukee 1/4 Sheet Orbital...
Need to convert pad to hook & loop sys. Is product made to fit this sander pad ?
Thought about what my orbital sander is like, then went to a craft store and bought a large sheet/pad of velcro and cut it to fit the 6" rubber disc pad glued it to the pad and then bought hook and loop sanding discs. And you wondering why I didn't use my orbital sander?? Because I needed to get into tight spaces and the orbital sander is a bit too large for this, plus it's too heavy to use working overhead .
Thanks for your site and for asking if problem still exists. Appreciate it.
"Necessity is the mother of invention" Truer words were never spoken
Els439
May 29, 2009 | Black & Decker Tools & Hardware - Others
No sanding action and motor just buzzes
It will probably be the shaft from the motor to the orbital cam which is on the flat plate that you connect the sandpaper to , either the shaft or the bottom cam is broken [probably the shaft has snapped ] you can do a cheap repair with a good glue to reconnect the shaft [but you wont be able to push too hard again] or if you can get the parts just replace the shaft into the motor . they are really simple things to work on
Mar 30, 2009 | Dewalt D26441 Heavy Duty 2.4 Amp 1/4 Sheet...
Tiny washer missing from orbital sander
I dont have the model number but you can go to Milwaukeetools.com and type in your model and you can look at a parts breakdown for this unit, or send it to me and I will look for a number and if you give me your location I will try and find someone close that you can get it from. Let me know if I can help more.
Mar 12, 2009 | Milwaukee Tool Milwaukee Orbital Sander...
Cannot disassemble Milwaukee 6016 to replace brushes
exactly what screws did you remove. you have to remove the bottom platen first (pad) then remove the housing screws. you need to remove the fan also and then might need to apply some pressure to split the housing halves.
Mar 03, 2009 | Milwaukee Tool Milwaukee 1/4 Sheet Orbital...
Milwaukee Tool Milwaukee 6010 - 6 1/2 Sheet Orbital Sander Logo
207 people viewed this question
Top Milwaukee Tool Tools & Hardware - Others Experts
Bill Boyd
 perry tradesman    ...
perry tradesman ...
Level 1 Expert
Are you a Milwaukee Tool Tool and Hardware - Other Expert? Answer questions, earn points and help others
