Maytag neptune top loader washer
What does nd mean? Not Draining eaither so I assume it means not drained. How would I fix it?
    Genius:
  • 3,587 Answers
Start with checking the hoses and lines for obstructions
Posted on Apr 26, 2008
Nd keeps coming up
The ND error code means NO DRAIN. To see why the ND code keeps coming up the drain pump needs to be checked for a partial blockage.
GENE
Sep 13, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My washing machine is displaying the letters "nd",
ND is no drain error code for the FAV6800A and most Maytag machines.
Is there water in the Wash Basket. If not this could be a stuck Pressure Switch. If there is water in the Wash Basket then there could be a Drain Pump issue/Drain Line clog.
If you want to DIY I can help you.
Feb 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
I HAVE A MAYTAG NEPTUNE TOP LOAD WASHING MACHINE THAT WON'T DRAIN. IT COMES UP WITH A nd CODE.
The washer experienced difficulty draining. Check for a kinked or blocked drain hose. Check for a plugged standpipe.
Dec 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
What does the nd code mean
The washer experienced difficulty draining. Check for a kinked or blocked drain hose. Check for a plugged stand pipe.
Dec 02, 2009 | Maytag Neptune Washer
I keep getting the error code nd on my Maytag neptune whats this mean?
Error ND means that there is a drain problem.
Either there is debris inside drain pump hose, or the pump itself is faulty.
The problem is fixed accessing the drain pump hose to check for a blockage.
Keep a container ready to collect water when you undo pump hose.
Parts and diagrams available here.
Nov 14, 2009 | Maytag Neptune MAH9700 Front Load Washer
Washer does not drain
ND error means no drain. When this happens it is usually a problem with the drain pump assembly, located under the bottom panel, inside the machine.
check the drain hose and the drain lines, ensure they are not obstructed. Probably the drain pump need replacement.
Oct 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer wont rinse
we had the same problem with ours....nd means not draining and that means that there is something, probably coins stuck in your drain hose. pull the drain hose out and check it for change and make sure something isn't stuck.
Jul 21, 2008 | Maytag Neptune MAH9700 Front Load Washer
Maytag neptune washer code nd, what does it mean
nd means not draining. u may to check the plastic drain pipe in back to back sure it doesnt have a kink in it, and that it is placed so that the pump inside the washing machine doesn't have to pump it too far to get to the drain.
May 03, 2008 | Maytag Neptune Washer
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
