After a power outage and surge, I tried to run the carrier high efficiency furnace "FAN" only to circulate air in the warm house. when I stated the blower, it ran on slower spped than normally.usually cycles between high and balst furnace high....now its running slow.I tried the heat cycle and the blower speeded up a minor amount over just with the fan circulating....is there an internal circuit breaker that could've beed bitten with the surge??
    Scholar:
  • 149 Answers
Try replacing the fan capacitor some time power surges zap them.
its usually a 5uf or 10uf @ 370vac if you change it and runs fine it was the capacitor if not blower fans keeps slow verify that full voltage is getting to it ex 230 volts or 115volts verify with a voltmeter if you get voltage.
Posted on Apr 26, 2008
  • Alexander  Figueroa
    Alexander Figueroa Apr 26, 2008
    i forgot if you can take a snapshot of the diagram of furnace i can probably troubleshoot it from home and give you a better advice
    hvac.tech7872pr@gmail.com
    President:
  • 2,712 Answers
Hello jedoppler,
It does look like an internal IC could have been burnt by the power outage. However, I recommend that you get this fixed by a competent technician, rather than a DIY job, as it could be quite complicated isolating the faulty chip.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
  • Swilin Sampson
    Swilin Sampson May 02, 2008
    Just checking to see if your issue has been resolved… If
    please take a moment to close the ticket with a FixYa! rating under my
    solution.
    post them here.
    Cheers!
    IrishDruid
I have a carrier 48nlx024 I replaced the fan control board and the fan comes on by itself when t stat is off
Do you have a "circ" feature on your tstat? This will periodically bring the fan on to circulate air. Be sure you are on auto. Is the fan running continuously? Possibly have relay backwards.
Sep 02, 2017 | Carrier Heating & Cooling
Carrier high efficiency furnace blower not turning when thermostat set to on position
is breaker and emergency shut off on-- check ---thermostat /operating correctly--gas /valve on--thermocouple /in working order--gas valve /operating correctly---reset ,high limiter,safety 's //are correct and not popped ---fan working order ---
Oct 25, 2016 | Carrier Heating & Cooling
Can not get fan on to turn on. All else fine. heat only furnace. No air conditioning...only air circulation.I used to set it on "Cool" and "Fan On"and get air to circulate. Do I need new thermostat?
Since you have two thermostats that operate the heating unit and the fan, and the fact that neither will turn the blower on, I would suspect the furnace/ air handler. Turn the thermostat to heat and see if the heat and the fan comes on, if it does operate normally in heat, the fan relay or the high speed on the blower is most likely the culprit. (If the furnace is equipped with a circuit board, the fan relay is integral to the board, if it an older furnace it has a separate fan relay). If it does not operate normally in the heating mode, verify power to the furnace, see if the flame comes on, if it does: the fan motor, circuit board or the fan relay are most likely the cause. hope this helps!
Jul 20, 2015 | Heating & Cooling
Is 32c a normal temp for an exhaust on a force air high efficiency house furnace? This is the air temp that goes outside after heating the plenum. Is there a lot of heat going up the "chimney"??
Any furnace providing heat where it should and has little to no heat from its exhaust is doing a GREAT job ;-)
Our high efficiency gas furnace was installed with a PVC pipe as a 'chimney' which bothered me to no end until I found the surface temp of that plastic pipe only barely warm to the touch- that is a home run!
Jan 09, 2015 | Emerson Lennox Ducane Armstrong Furnace...
Furnace blower runs after temp is reached
Is your tstat fan selector in auto?? Does the fan ever shut off?
Jul 18, 2017 | Heating & Cooling
Power outage last night now my RUUD High Achiever AC Unit model# UPNE-048JAZ will not work
Power surge may have taken out your control board (in the furnace, does the fan work?), possibly the transformer (in the furnace) or possibly the capacitor (in the A/C). Call a professional.
Aug 22, 2009 | Heating & Cooling
Carrier air conditioner cycles on and off
The compressor/condenser is being called all the time. The reason it goes off is because the evaporator (indoors) freezes up when the fan is told to turn off by the thermostat. This further cooling lowers the low side pressure below the low limit switch point turning off the compressor unit.
Solution: Make sure the thermostat is wired correctly. Green wire is usually the compressor wire but maybe not.
Jun 17, 2009 | Carrier 38BRC036 Air Conditioner
Carrier Weathermaker SX model 58SX060-CC Blower runs all the time
Remove all power from the furnace, it is likely the brain in the furnace is need of being reset, from the battery replacement, why did you change the battery, was there an indicator telling you to change it?
Many times just removing all the power to the furnace will do the trick with a reset, if not let me know and we will go from there, but it sounds like the main brain is confused or bad, more likely confused, so try the power removed first.
Than let me know wbwill@sbcglobal.net
Oct 22, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
We installed a honeywell DH90 whole house dehumidifer #B08167014 4026552. Unit is removing water but the supply side is warm air. We are wondering if this is normal or if this air should be cold.
I assume you mean the exhaust side of the dehumidifier, which goes into the supply duct of the furnace.
All dehumidifiers, whether small portable types, or whole house types, exhaust warm air (which is also dry air) as they remove humidity. The whole house unit which you have is a great solution to humidity control. Since the furnace fan should be running on a call for dehumidification, the mixing of the air in the building which is circulating and the exhaust (Dry) air from the dehumidifier negates, or dissipitates the heat in the air coming from the dehumidifier.
Jul 31, 2008 | Heating & Cooling
Intertherm furnace
That is a stack limit switch. You are not venting properly. Is your unit power ventilated or gravity fed?
Nov 23, 2007 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
