Question about InFocus ScreenPlay 4805 Multimedia Projector
Whats wrong with my infocus x2 it will turn on but no light will come out or show any picture?
    President:
  • 567 Answers
Hi it seem like the bulb/lamp has gone bad, you should change it.
Posted on Aug 04, 2010
I have an infocus X2 projector that has a shadow on one side of the image. After reading other posts, this appears to be indicative of a light tunnel collapse. Is this problem repairable in an X2 and if so...
the light tunnel has collapsed and needs to be replaced. it's pretty simple to repair. there are directions on the "tips" part of my profile. so, you can get the part from an infocus service center and do it yourself or send it in to them for repair. either way, try www.avsolutionsny.com. they're really good.
Jan 29, 2010 | InFocus Office Equipment & Supplies
I replaced the bulb on my InFocus ScreenPlay 5000. The unit turns on the picture is showing a little green while the light warms up. After about a minute, the light turns off but the project remains on as...
there is an issue with the lamp ballast. probably needs to be replaced. send it in to an infocus service center. try av solutions in ny. they're really good.
i think it's www.avsolutionsny.com
Nov 23, 2009 | InFocus ScreenPlay 5000 Multimedia...
Infocus X2 projector shows picture in black and white only...
that little glass square broke off of the colorwheel, and it needs to be replaced. that yellow/gray line is from the light tunnel collapsing. both parts can be purchased and replaced by you. if you don't feel comfortable doing it, you can send it in to an authorized service center. try av solutions. they're pretty good. you can purchase infocus parts from them, too.
Oct 27, 2009 | InFocus Office Equipment & Supplies
Infocus lamp not firing
more then likely the ballast has gone bad and the lamp is not getting the right voltage to fire. Only other thing you can do is remove the lamp the turn the power on and check the voltage at the connector. This will not check the triggering voltage mine you only the lower operating voltage. But since you have replace the bulb with a known good one I'm betting on the ballast is bad.
Dec 08, 2008 | InFocus Replacement Lamp Projector Lamp...
Infocus projector power supply dead
the caps dry out. look for bulging caps. you won't find a schematic for the ps boards. infocus had someone else make them. the problem seems more like a overheating issue. as for the other one with the "just the fans", check the colorwheel.
Oct 03, 2008 | InFocus POWER SUPPLY CORD Multimedia...
Infocus x2
first try another computer cable. if same results, press the "auto image" button on the projector. if that doesn't work, press menu, select settings, then factory reset, and "yes". if you still have the same problem, the eca (main board) is bad.
Sep 01, 2008 | InFocus X1 Multimedia Projector
2 bulbs blown.
To be honest, most people who experience short lamp life on the Infocus X2 is on the genuine infocus lamps. If you read the user opinions here, you'll know what I mean. Me personally think that the X2 lamp filter some how manage to block the vents with dust which results in inefficient cooling in effect reducing the life of the lamp. The best thing to do is vacuum the lamp filters regularly and stick to cheap lamps as the oem ones on the Infocus X2 are also no good. Or better still, just replaace the bulb on it's own from here and save a lot of money.
Jan 26, 2008 | InFocus ScreenPlay 4805 Multimedia...
InFocus ScreenPlay 4805 Multimedia Projector Logo
392 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
