Question about Lanzar HTG244 Car Audio Amplifier
Why does my amp turn off when i turn the music up
    Problem Solver:
  • 6 Answers
YOUR SPEKERS COULD RATED MORE THAN YOUR AMP OR YOU HAVE BAD SPEKERS TRY 1 AT A TIME SEE IF IT HELP OF THE AMP DONT TURN OFF BY TRING 1 AT ATIME THEN ITS TO MUCH WATTS FOR THE AMP..........
Posted on Aug 04, 2010
The Sub-woofer output on my Yamaha HTR-5440 keeps dropping out!
may be dry joints on electronic components, consult a technicia for resoldering the pre amp or amp unit,
Feb 03, 2014 | Yamaha HTR-5440 Receiver
NOKIA N73 screen shows headset mode on the top right even when not connected to the headset.....so i am not able to hear anything even when i connect the headset it is not responding & i can't hear...
Hi Saik,
I think problem is caused by unplugging the jack before pausing/Stopping the music.
1) Plug in a headset into the jack
2) Open up a media player (either the MP3 player or any online music)
3) Begin to let the music play.
4) Stop the music from playing after a few seconds
5) Completely exit out of the media application.
6) With the headset still plugged in, wait about 15-30 seconds. (this is so that the media/pandora app task can "fully" stop from running)
7) Unplug the headset.
The phone should now be able to emit sound from the earpiece.
If the above does not work, other methods I have read tell you to plug in a headset & play music. While the music is playing, quickly remove & insert the headset into the jack (not too rough so if doesn't break anything) until you hear the music coming out of the speaker.
Finally, if you still have the issue, try rebooting. Turn off the Phone, Remove the battery completely and reinsert after 30 seconds. Turn on the Phone.
Hopefully that should fix the issue.
Jan 01, 2018 | Nokia N73 Music Edition Smartphone
Car will turn over and wont crank at times
Your alternator isn't charging your batter and needs to be replaced, your battery no longer holds a charge or doesn't have enough cranking amps for the application and that only applies if you aren't playing your music without the motor running. If you play music without the motor running it's going to drain your battery, sure, it'll still play music but the amps will be too low to turn the motor over fast enough to catch the timing on the motor in order to start it. Winter is hard on batteries as well, that's why they have cranking amps and cold cranking amps.
Mar 04, 2011 | Car Audio & Video
Everything works fine when i play a cd it works it reads it but dont hear the music when i turn to radio i hear the music,just wondering what could be wrong help me out thanks..
sounds like you have it hooked to an amp and have the blue power antenna wire instead of the blue and white amp remote turn on connected the the amp remote turn on terminal.
Mar 04, 2010 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
I have albums in my pc and want to transfer the albums to my nokia 97?
Not sure if you meant photo album or music album??? Here is the steps for both, music first:
Transfer music from a
computer
You can use the following methods to transfer
music:
● To install Nokia Music to manage and organise
your music files, download the PC software from
www.music.nokia.com/download, and follow
the instructions.
● To view your device on a computer as a mass
memory device where you can transfer any data
files, make the connection with a compatible USB
data cable or Bluetooth connectivity. If you are
using a USB data cable, select Mass storage as
the connection mode.
● To synchronise music with Windows Media
Player, connect a compatible USB data cable, and
select Media transfer as the connection mode.
To change the default USB connection mode, select
Menu > Settings and Connectivity > USB > USB
connection mode.
This works for music, photos, or video:
Select Menu > Settings and Connectivity >
USB.
To have the device
ask the purpose of
the connection
each time a
compatible data
cable is connected,
select Ask on connection > Yes.
If the Ask on connection option is turned off or you
want to change the mode during an active
connection, select USB connection mode and from
the following:
● PC Suite — Use Nokia PC applications such as
Nokia Ovi Suite, and Nokia Software Updater.
● Mass storage — Transfer data between your
device and a compatible PC.
● Image transfer — Print images with a
compatible printer.
● Media transfer — Synchronise music with Nokia
Music or Windows Media Player.
Here is the link for your manual online:
http://nds1.nokia.com/phones/files/guides/Nokia_N97-1_UG_en.pdf
Oct 22, 2009 | Nokia N97 Cell Phone
My Boss Amp keeps cuts off when I play the music from my stereo when i play music and turn it up the amp keeps cutting in and out and i have to tap it and it will turn on
someting is busted in the amp! needs to be repaired or replaced !
make sure all wires are tight tied to the terminals first!
thanks
erik
Feb 24, 2009 | Car Audio & Video
Jl; audio 500 amp
I assume the signal sensing switch you are talking about is the remote turn on for the amp. The amp should turn on when you turn your radio on, not your truck.
First try disconnecting the remote turn on that comes from your radio. After that is removed turn your radio on and them run a jumper wire from the positive voltage terminal of the amp ( the main power input) to the remote turn on terminal of the amp. If the amp turns on and you hear music, you have a problem with the remote turn on from the radio. If the amp turns on but you hear no music you have a problem with the audio input of the amp or the wiring of the speakers. if the amp does not turn on you have a problem with the amp.
I think you may have a problem with the remote turn on output of your radio. if so, you need to get the radio looked at by a service technician.
If the amp is turning on sometimes, you may just have a loose wire or faulty ground. Double check all the wiring.
Mar 18, 2008 | Jl Audio 500/1 Car Audio Amplifier
Cant turn up the music witout the amp shuting off
look insayd tz100 is dead replaeis end troae egayn
Mar 29, 2007 | Alpine MRP-M350 Car Audio Amplifier
Lanzar HTG244 Car Audio Amplifier Logo
60 people viewed this question
Top Lanzar Car Audio & Video Experts
Morne Olivier
Chris Ward
xxxxxx xxx
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
