Question about LG LH-D6230 System
The fan quit working and the machine overheats. The fan runs full time if you connect the black lead to ground, but I don't feel good about having that little fan running 24/7. The circuit to PN300 seems to be open somewhere to the black wire of the fan connection. Is there somewhere else to connect the black fan wire so that the fan only runs when the machine is turned on ? Howard
  • 11,896 Answers
Check to see if there is a relay or timer on the board. Most likely there is a relay that is not opening up. You can test it with an ohmmeter if you can reach it's solder joint connections.
Posted on Aug 04, 2010
Connect blue wire light ground
I think you have to connect the black to the white if you don't have any other wires.
Jul 27, 2013 | Minka Aire F803-TL Artemis? Fan
2002 Pontiac Sunfire engine cooling fan
Just unplug the connection from the fan and run a ground and power wire from the battery [Tap it on the connection to the fan]. It doesn't matter how they are hooked up, it will just spin backwards if hooked up backwards. If nothing happens, you will need a fan motor. If the fan works, you either need a fuse or relay.
Nov 20, 2017 | Pontiac Cars & Trucks
Light only turns on with the remote. How do I set it to turn on with the wall switch?
There are some fan models (particularly with a remote control) that use multiple cycles of a single power switch to select the operating mode. For example, if you simply flip the switch on, you get the fan. If you flip it on, then off, then on again within one second, you get the light. If you flip the switch on - off - on - off - on, you get both. The trick is to do it fast enough so the internal power circuit doesn't run out of capacitor charge and forget what you're trying to get it to do.
Sep 28, 2011 | Hunter 52" Ceiling Fan With Light And...
Radiator fan on drivers side will not engage motor overheats. what can be the cause?
There are a few. I have see the ground rust off, the fan motors burnt out, the fuse relay box. The best way to check is using a test light connect it to the two wires of the fan run the engine. If the light comes on before it starts to overheat then check the fan. If not the check the relay. But before you look at the fan make sure the fuse is good.
Aug 21, 2011 | 1998 Oldsmobile Silhouette
Overheats if left idling but not if driving...cooling fans aren't coming on...what couls be wrong?
the cooling fans on your car are comanded on by the engine control module which reads engine temperature from the temperature sensor . when comanded on the engine control module sends a signal to the cooling fan relays . which in turn runs the current to the cooling fans . So you might want to check the cooling fan relays and make sure the fues for the cooling fans are good and the relays .if the cooling fan fuses and relays are good it could be a problem with the fan motors or the engine control module not reading the right temperature in that case it could mean you have a problem with the temperature sensor
Mar 04, 2011 | 1998 Cadillac DeVille
My computer overheats and shuts down every time I run an intensive program, what can I do to better cool down the system. I already moved it to an open spot and cleaned out the dust
make sure all dust is clear of the processor heat sink. then if you overclocked the processor you may want to back off overclocking a little bit. make sure you have plenty of thermal silicone paste in between your processor heat sink and processor
Dec 23, 2010 | Dell XPS 625 DESKTOP GAMING MACHINE- Black...
At first I thought I only had a burned out drivers' side headlight. I replaced it and it worked. But neither of the two high beam lights work. In fact, when I turn on the high beams, all the headlights...
You have a rusted out ground leads to both front lamps. It may be bad enough rusting up front that effects both fenders. Run some heavy ground wires from negative of battery to both fenders, then tie in the negative lamp leads to the fenders. Might as well make sure the ground connections to everything else are holding up as well. I've added grounds to windshield wiper motors and blower fans that quit working as well.
Aug 09, 2010 | 1987 Chevrolet Nova
When idling saturn ls 4dr sedan wants to overheat
Sounds like either you are low on coolant or the cooling fan isn't working. With engine cool remove radiator cap and check coolant level, top off if necessary. If full start engine and turn on A/C full blast, full cold the cooling fan should come on almost instantly, unless there are two individual cooling fans in which case only one may turn on. If no fans turn on check all fuses whether related to fan or not. If all fuses fine try swapping relays around, they are usually all the same size/style. If fan still doen't work you have either an open positve or ground side of the circuit, Which will require wiring schematics and a multimeter. If coolant full and fan/s turn on and engine still overheats you'll need a new thermostat installed.
Mar 24, 2009 | 2000 Saturn Ls 4dr Sedan
95 grand am radiator fan only runs with AC on
Cooling Fan Temp Sensor is the First thing You Check (with what you have described) Cooling Fan Should ALways come On When The A/C is turned On as A/C Adds A Load to Engine, If Temp Sensor is Faulty it Will Not Give GROUND Signal to ECM >For COOLING FAN >RELAY to Give ground and turn ON The Fan.
There ARE 2 temp Sensors that Serve Different Purposes 1 is for Dash READING GAGE & Or TEMP LIGHT the Other is For ECM or Fan Relay (SAME Thing) you Said>""can disconnect the sensor and fan continues to run" < This Leads me to think you Changed the Wrong One. Not Questioning your Skills Just Here to Help.
TEMP SENSOR FOR 3.1L V6 is Located upper RH rear of engine compartment, near exhaust system. Temp SENSOR for 2.3L Engine is Located in LH rear of engine compartment.
I Hope this Helps Lead you to a NON-OVERHEATING Pontiac.
Good Luck and Have A Great Evening. rejakwilson
Feb 04, 2009 | 1995 Pontiac Grand Am
LG LH-D6230 System Logo
35 people viewed this question
Top LG Audio Players & Recorders Experts
Marvin
Marvin
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
