Question about Element Electronics FLX3220F 32 in. LCD TV
My 32 in lcd tv FLX 3210 has sound and no picture.
My 32'lcd television has sound but no picture.
Posted on Nov 08, 2010
  • Bud Martin
    Bud Martin Nov 09, 2010
    Please read my guide below to narrow down the problem.
  • 11,361 Answers
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 04, 2010
2 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: 32" elements tv model # FLX-3210 When the tv is
It will be better if you can get me the part number off the board as there are several revisions of the part for the same model and all of them may not be compatibl with your set. The board looks like this. Its for your set but please verify the part number before buying.
http://www.shopjimmy.com/philips-996510009688-backlight-inverter.htm
Posted on Jan 08, 2011
Where is the inverter board located on the element flx-3210? Is it somehow combined with the powersupply? I've taken the TV apart and have found everything except a part that resembles an inverter...
Yes, inverter circuitry is combined in one board together with the power supply circuitry. It is beside the connectors of the power supply board to the mainboard. You can see two high voltage transformers, these are the one producing high voltage feeding the bulbs...
Nov 01, 2011 | Element Electronics FLX3210 32 in. LCD TV
I have a FLX-3210 that powers on and then you get a picture for a few seconds and then turns off
Tv still have audio sound after the picture disappear a few sec.?Yes,than ur tv have a 1 or 2 long boards called LCD inverter boards are dead.These 1 or 2 long LCD inverter boards only job are to help to provided a backlight to the tv LCD screen panel to get a picture.Tries like websites Shopjimmy.com,Ebay.com to buy a 1 or 2 long LCD inverter boards for the replacement.
Sep 01, 2011 | Element Electronics FLX3210 32 in. LCD TV
My FLX 3210 has good sound but no picture. Any suggestionsl.
Good day!!!
that problem is cause of bad inverter board...
just replaced it to fix your problem..
please don't forget to rate my answer...just click yes in this query "was this helpful?"
Thanks for using fixya...
Aug 06, 2011 | Element Electronics FLX3210 32 in. LCD TV
I have an Element FLX 3210 that won't light up and show a picture..it has the sound but no picture.
Check the two caps (10uF 450Vdc) by the inverter transformers, also check fuse F2.
Worst case will be shorted out ballast caps in the LCD panel assembly.
http://s807.photobucket.com/albums/yy352/budm/Element/Element%20FLX-3210/
Jun 04, 2011 | Element Electronics FLX3210 32 in. LCD TV
How do i get picture in picture?
As far as I know, this TV doesn't have a PIP feature. The Element Electronics web site didn't appear to list this older model. www.elementelectronics.com did provide a phone number for customer support.
http://www.retrevo.com/support/Element-FLX-3210-TVs-manual/id/4540dj094/t/2/ does have the manual online.
I hope this helps.
Oct 24, 2010 | Element Electronics FLX3210 32 in. LCD TV
Element Electronics FLX3220F 32 in. LCD TV Logo
117 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
