Question about MTX Thunder 4250D Car Audio Amplifier
What can i take out if my car should go bad - MTX Thunder 4250D Car Audio Amplifier
  • 70 Answers
The deck, eq, epie, apex, amp, wires and sub
Posted on Aug 04, 2010
04cavilier misfire on 4 cylinder
Can be bad plug, bad wire, bad injector, a bad valve, or bad vacuum leak. Read the misfire section in the middle of the page at link below.
Do It Yourself Diagnosis and Repair
Aug 14, 2017 | 2004 Chevrolet Cavalier
My car turns over but wont start, what do I need to do/
Check the basic 3 - gas, spark, compression.
Spark can let you down if you have bad or broken high tension leads, or you have a bad distributor cap (I assume your car still has mechanical spark distribution), a bad distributor rotor or bad points (point gap / condenser). You could also have a bad ignition coil.
Gas can let you down if your fuel pump is bad, you have blocked fuel lines (fuel filter etc), sticky fuel level float (I assume your car has a carburettor and not electronic fuel injection).
Compression can let you down if you have a broken cam drive belt.
Check all of these. Otherwise, get someone with mechanical background to check the car.
Oct 08, 2014 | 1999 Ford Escort
Signs of bad oxygen sensor
could be a fouled plug or bad plug wire.
Mar 19, 2014 | 1991 Oldsmobile Cutlass Supreme
Car horn not working
as with all elect. fails check all fuses
in this case the 15 amp fuse marked, HORN
can i presume all else works good> car drives.?
all answers, USA spec car. nobody ever tells location, so..... if not USA< all answers wrong. the usa car has just 1 horn.....
got voltage to horn? 12v
Yes or no.?
if yes horn bad.
got voltage from horn relay
yes, bad wires.from, relay to horn
no, got voltage 12v to horn relay coil,
yes, good, no bad fuse.
got 0v to other relay coil (all tests honking)
yes, bad relay.
no, bad horns switch.
if you want me to guess. sure.
1: bad wires ../connections, end to end.
2 bad horn
3: bad relay
4: bad horn switch.
Dec 27, 2013 | 2005 Toyota ECHO
Kia shuma 1999 occasional starting problem; idling problem; bad smell
I would look for a loose electrical connection somewhere in the engine. Most likely an intermittent connection is sending bad information to the computer and it is setting the fuel / timing badly to try and compensate for the bad signal. Could be a bad computer too.
Try taking the car to a local autoparts store and have them read the engine codes.
Aug 19, 2012 | Kia Shuma Cars & Trucks
Head lights cutting off and on at night while driving
bad ground on the headlight circuit,bad switch,bad auto sensor,or bad sockets or bulbs,or bad daytime running light module.
Apr 14, 2010 | 1993 Lincoln Town Car
From 1991, i wash the engine and after this the car is not working good any more, is not taking power, the exoust is going hot in 5 min. what i need to do
take back to carwash and hit reverse button. it will remove all the water out of engine---bad for electronics, that why your auto no work good anymore never wash engine at car wash, bad bad bad. water goes where it shud not go---more bad,
that why car wash have reverse button. to reverse water flow out of car engine. BAd bad bad
Nov 02, 2009 | BMW 325 Cars & Trucks
Harmonic balancer bad car runs real bad
The harmonic balancer controls the triggering of the combined crankshaft/camshaft sensor. This controls ignition plus fuel injection. Replace the balancer and adjust the sensor or replace it if damaged.
Oct 18, 2009 | 1998 Pontiac Bonneville
The car is missing very bad. It want stay crunck.
it could be bad plugs and wires.clogged fuel filter.bad gas.dirty injectors.scan it check mass air flow sensor.and egr valve.
Jul 13, 2009 | 1999 Oldsmobile Alero
MTX Thunder 4250D Car Audio Amplifier Logo
32 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Marvin
Marvin
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
