posted by pchrist on Apr 26, 2008
Ok l think the k8v se deluxe board is shot is there a board out there that i can get that the processor will swap over and i will be able to use the 2.5 gb of ram i have??? Looking for something inexpensive that i can just replace the this board with. the processor i have is a amd 2.4 ghz.
Please help!!!!!
Comment by pchrist, posted on Apr 26, 2008
what would a decent price be on this unit???
i seen this board is it a good one??? how about the abit boards???
Link
what do you think of this??? How hard is it to put the fan on? would the fan from the old board work???
Link
Comment by pchrist, posted on Apr 28, 2008
So is that foxcon board good??
Sorry just not good with buying a new board!!!
The 20.0 is really nice!!! I could probably deal with out the extra 512 for that price. i could add in a jump drive using ready boost to pick up a little slack!!!!
I have an atx case so that isn't a problem. The foxcon won't work because i need the agp slot. Thinking really hard about that 20$ board. Performance should be just at good as the old correct??
Solution #1
posted on Apr 29, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Bought the board at geek last night along with an 8 gig flash drive to use as a readyboost addition. all for 60 including shippng!!!!
Thought it was a pretty good deal.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Don't know what your budget is...LINK
This board will support the processor you have and three sticks of ram.
Comment by mewms_14904, posted on Apr 26, 2008
That Abit is a good board but I thought you had 2.5 gig RAM
Abit only supports 2gig
GEEKS.COM has good boards cheap
you want a board that is 800mhz FSB and supports 64bit Architecture AMD socket 754 processors
link
link
link
link
Comment by mewms_14904, posted on Apr 28, 2008
I've never had a problem with FOXCONN boards, If you want a cheap board, check out the geeks.com and there is a board I linked that is on sale today for $19.95. it only supports 2gig ram. but everything else is OK. also what size tower does your unit have as the ASROCK board is full size and not a small or micro ATX.
Comment by mewms_14904, posted on Apr 29, 2008
Actually better as the board from the geeks allows for the addition of a separate board taking you up to the 939 amd processors.
All your components will transfer over. processor heat sink fan etc.
Solution #3
ok look on Ebay and you will find exactly what you need. No problem. Ans otherwise there are a ton of on line shops around who still carry this.
Comment by dutchman05, posted on Apr 26, 2008
Hiya christ looks like a good board and the fan is easily put over. But even a new one cost almost nothing. I would go for this one as an abit board needs different fan anyways.
Good luck with it and about 50-60 dollars is a real good deal
Suggest a new solution for this problem
Post a New problem for ASUS K8V-SE Deluxe Motherboard
Email this problem
Email this problem
Can you Help with these Motherboards problems?
Repair Service
Find Motherboard Repairman Near You:
