Question about Samsung Washing Machines
We havea samsung top loader washing machine model: wa85vpl/AG. It's not suking water nor spinning the drum. could you help us fix the issue?
  • 46 Answers
SOURCE: Overflowing washing machine
check the pressure switch . its circluar in shape with 6/8 wires attached, and a small nipple with a 10mm pipe attached. as the water rises in the drum air is pushed up thru this pipe which when working ok , eventually pushes against a switch .hence its name. so, if there is damage to this pipe( maybe rubbing against the drum) the passage of air escapes before reaching the switch. if the pipe is ok then check the switch by blowing up the pipe (with the power off ) and u should hear a small click inside the switch. if not replace
Posted on Feb 07, 2008
SOURCE: Siemens Wash & Dry 6140 (Front loader Washer drier)
SUCCESS !!!! - WOT A RESULT.! - SO PLEASED I HAD A GO.
Dry joint found on PCB was BLACK & MELTED, specifically one on the relay terminals was not connecting to the pcb track anymore ;looked like poor original solder joint.
GOT THE OLD SOLDERING IRON OUT, FLUX PEN AND SOLDER AND VOILA!!!
SAVED £280+ (SIEMENS QUOTE: NEW PCB £200 PLUS LABOUR £40/HR)
Posted on Apr 26, 2008
futureloginn
  • 734 Answers
SOURCE: Kitchenaid Top Loader leaks
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
SOURCE: washing machine drum is very wobbly
* General tips
* Balance the load
* Level the machine
* Inspect the water pump for a blockage
* Inspect the coupling
* Inspect the transmission
* Adjust the drive belt tension
* Check the motor bearings
* Check the drum brakes
The above are possibly the general remedies for this problem.But possible if the problem still persists after this, possibly the drum bearings might have been damaged during the previous heavy vibrations.Please do post comments.Will be glad to help you out.Good luck.
Posted on Jan 16, 2009
SOURCE: AEG OKO_LAVAMAT 6200 DIGITRONIC fRONT
I have the same problem and Dell Appliances serviceman this morning stated it was a faulty interlock mechanism and that was preventing the spin function working. cheers.
Posted on May 12, 2009
The drum seems loose. When it spins to let the water out it will spin good then all of a sudden it will bump loudly
Search Results
    How to Diagnose Drum Problems in a Washing Machine ...
    ? 7:48
    https://www.youtube.com/watch?v=wUL5Wb1T71c
    Nov 19, 2013 - Uploaded by eSpares
    For all your washing machine spare parts go to http://bit.ly/1DumBrv The most common fault in a washing ...
    GE Washer Top Loader Out of Balance Shaking Repair ...
    ? 14:19
    https://www.youtube.com/watch?v=GA98ZmnzEfc
    Jul 12, 2014 - Uploaded by Mike Davies
    GE Washer that Shakes and is Load during Spin Cycle. step by step ... Washer Tub Seal Replacement - GE Top Load Washing Machine ...
    GE Front Load Washer Inside Drum Loose - YouTube
    ? 0:46
    https://www.youtube.com/watch?v=P8EcTTL2lcI
    Apr 4, 2013 - Uploaded by Wayne Meador
    I need help with my GE Front Load Washing Machine!!!! If you or anybody that you know can help me fix this, I ...
    Kenmore top-load clothes washer drum/tub is loose and bangin
Jan 08, 2016 | Washing Machines
My washing machine fills with pieces of black matter. I have done machine clean washes and it still happens every time, covering my clothes in black pieces that look like cardboard. Please help my - the...
Hi mine does exactly the same! I have to call in my washing machine technician more often (he told me this would happen with a top loader as opposed to a front loader, boy was he right!!) and he cleans out the drum. Mostly it is the fabric softener which is too thick. I water mine down to 50/50 and I do another spin after my final wash. I also empty the filter of water at the side/bottom of the machine. This annoying problem is caused by the way the drum turns on a top loader as opposed to the front loader. My top loader cannot heat water automatically either like a front loader, and I think this also adds to the problem as hot/boiling water would dissolve all that soap/fabric softener. Hope this helps.
Jul 12, 2014 | Samsung SW62ASP Top Load Washer
My Samsung SWT5V9W top loader spins when you turn the power button on. It still spins during the cycle and 'fights' itself to agitate. Would this be a computer issue?
This can be related to a mechanical issue, Check for free movement of the drum and shaft. check the mountings of the motor,check the suspension and finally the level of the machine, use a rubber mat if the machine moves around.
Jan 23, 2013 | Samsung Washing Machines
My kenmore washing machine (front loader, model #970-C42062-00) is not spinning the clothes dry. sometime water is left in the drum other times not. the drum is making a squeaky noise as well. what...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 22, 2011 | Washing Machines
HI,WHEN MY WASHING MACHINE SPINS IT IS SO LOUD AND MAKES A CLUNKING NOISE.WHEN EMPTY AND I SPIN THE DRUM IT FEELS LOOSE.CAN YOU HELP WITH THIS PLEASE. THANKYOU.
Yes
Either one of your springs have broken at the top of drum.
Or the dampers under the drum have failed.
Possibly both.
You can get to your top springs by removing lid.
Dampers access is via the underside.
Remember to disconnect power and water before opening up machine.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | Washing Machines
I have a SIMPSON ENCORE 555 heavy duty washing machine. It will do a normal wash cycle, but when it comes to the spin cycle, it doesn't distribute the washing around the drum and hence won't spin. any...
Hi just read your posting.Now does the washing tangle around the agitator?In your posting you mentioned the washing not distributing around the drum.Could you confirm that your machine is a top loader for me,because the word "drum and distribute" are terms for a front loader.If your machine is a top loader which I think it is then the problem could be your brake arm or spin coil is not operating.Please reply and let me know if the clothes are tangling around the agitator.Looking forward to your reply.
Sep 07, 2010 | Washing Machines
My washing machine leaks & doesn't drain
Is this a FRONT LOADER? Or, a TOP LOADER?
If you have a leaking FRONT LOADER, the following link explains how to access and inspect your washer for leaks:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
In the majority of the cases with front loaders, the door bellow begins to leak. A routine inspection of the seal perimeter will tell you if there are any rips or tears. If the bellow is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If this is a TOP LOADER, the following link explains how to access and inspect your washer for leaks:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
In the majority of cases with a top loader, the water pump begins to leak. These pumps are not serviceable and require replacing if damaged. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
Follow the tips in the link(s) provided and make sure you inspect all hoses and tub seals as well.
If you have any questions, please post back with your MODEL NUMBER, so I can determine what washer configuration you have. I hope you find this information helpful.
NOTE: The drain issue you referring to may not be a problem at all. It is normal for some residual water to remain in the wash tub below the spin basket. This is the low point of the drain line and some water ALWAYS resides here. If the water is visible in the spin basket, then you have a legitimate concern. In addition: If this is a TOP LOADER, some models use a balance ring on the top of the wash tub that is filled with fluid. This helps to stabalize the wash tub during the spin cycles and minimize off-balance issues.
Apr 20, 2010 | Whirlpool Washing Machines
Washing Machine agitates only
maytag front loader washing machinne the drum agitates but does not spin
Feb 10, 2009 | Maytag MAH6500 Neptune Front Loading...
Water drains in wash cycle
It is probably a solenoid valve for the drain that is stuck open. There could be an object in it or may be defective.
Jun 12, 2008 | Washing Machines
Washing Machines Logo
106 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
