Question about Teac Audio Players & Recorders
I have a teac px-500 quartz lock direct drive turntable, it's really old, from the mid to late 70's. I am getting no power. is this something that is fixable. are there still service manuals for these things, or parts?
SOURCE: aiwa stereo turntable system px-e860k
how long have you had it? could be that you just need a new belt if it keeps slipping off...
Posted on Oct 20, 2008
  • 104 Answers
SOURCE: problems with weights on turntable arm
http://www.turntableneedles.com/FAQs_ep_33.html
found instructions above.
scroll down to
"How do I adjust tracking pressure and anti skate?" under the section of "OTHER"
Posted on Feb 16, 2009
  • 13 Answers
SOURCE: Technics SL-Q200 Quartz Direct Drive
Your best bet is to get a good quality switch contact cleaner to clean all the contacts on the speed control switches.
I guess the contacts inside the switches will have corroded slightly with your turntable having been stored in the garage.
Posted on May 16, 2009
SOURCE: Turntable does not rotate when switched 'on'.
Throw it from a second story window then smash it with a sledgehammer. That's what I plan to do with mine.
Posted on Jun 03, 2010
  • 396 Answers
SOURCE: how do I attach the turntable belt to the Aiwa px e850
Lift the platter off the turntable. You can identify the motor spindle by using your fingers to turn the round shaft which rotates freely. Remove the rubber mat off the platter. Place the belt around the outside of the drum on the bottom of the platter. From the top of the platter, place your finger in one of the platter holes and tension the belt so it will not fall off or twist. Griping the platter trough the holes while keeping tension on the belt place the platter on the turntable aligning your finger with the belt to the motor spindle. Place the section of the belt on your finger over the motor spindle. Replace the rubber mat on the platter.
Posted on Jul 21, 2010
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
How to start to play
Go here for a picture:
http://www.proaux.com/TEAC-A4010-GSL-Reel-to-Reel-Recorder,name,1638,auction_id,auction_details
http://www.angelfire.com/electronic2/vintagetx/index.html
The two arrow buttons on either side of the FAST key will play it Forward or Reverse. Combining the FAST key with a direction initiates a fast forward or rewind.
May 16, 2009 | Teac GF-600 Turntable
May 13, 2009 | Technics SL-1210MK3 Turntable
Problems with weights on turntable arm
scroll down to
Feb 14, 2009 | Teac P-988 Turntable
Stanton ST150 turntable won't spin
Hello DeKay,
I just had a spindle lock issue this past Sunday at my gig. I had the turntables out in my car and brought them in. I let then warm up for 2hrs before plugging them in.
Everything was good. Then mid set my right side turntable started spinning really fast and then DEAD STOP.
I was pushing the platter and it really hard to turn. I took off the platter and tried to turn it with my hand. It was dead locked, WTF?!!
So I limped through with one turntables since I use Traktor Scratch Pro and made it through the whole night successfully.
I searched the net and it was suggested to lubricate the 1200 spindle with 15W40 motor oil. Since the motor design is indentical, I picked up some 10W40 motor oil since I couldn't find 15W40.
I oiled both turntables to be on the safe since. I tapped the spindle on the locked turntable to help loosen it.
I drove back home which is pretty much an hour drive and let the tables sit for another 2 hrs.
I decided to grab a thick towel and vice grips to work on the locked spindle.
Clamping down on the towel with the vice grips on the brass fitting for the platter I was able to free the spindle quite easily.
I was then able to turn it by hands so I did in both forward and reverse directions to work the oil down into the spindle bearings.
I put the platter back on and spun it manually to check for resistance, it was spinning nicely!
Plugged in the turntable, set the pitch at 0 and watched the stobe dots. There was no waver in the strobe dots. YAAAAAAAY!
My turntable is back to new and since I only use them on the road they stay stored most of the time.
So I would suggest just oiling the spindles every so often to keep them tip top.
Hope this helps you!
Peace,
DJ Quartz
Nov 06, 2008 | Stanton ST-150 Turntable
Turntable help
http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things.
Sep 20, 2008 | Aiwa PX-E860 Turntable
Sylvania stereo Model sc241w
Sounds like the belt broke off, if so, you must replace the belt with the proper replacement belt. If it is a Quartz Lock system, it will be very pricey to fix. If so, it's best you take it to a professional if it is a Quartz Lock system, they are very delicate systems and require careful repair.
Hope this helps!
Jul 13, 2008 | Technics SL-1200MK5 Turntable
398 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
