Question about Whirlpool GU2400XTP Built-in Dishwasher
I have water standing in bottom of dish washer and apparently no power though circuit breaker is on...
  • jeannejbuie Aug 11, 2010
    Where is the fuse located. I do not have a manual, I bought this house and it did not have one with the dish washer.
  • Whirlpool Master
  • 1,527 Answers
Hello the fuse in the dishwasher may have blown the fuse will be in the power supply
regards
shaun
Posted on Aug 04, 2010
  • daveSF Sep 09, 2010
    Can anyone tell me if there is an inline fuse. We had a power outage last night and there is no power to the panel and there is water at the bottom. I don't have a manual, so if anyone has one for a whirlpool gold GU2300XTLS2, can you post a soft copy for me please. One last question I was thinking it might be the thermal fuse from reading the forum but I am not sure where it is located or what it looks like - any help would be grealty appreciated.
    Dave
Delonghi dishwasher giving error e 4 and water standing iv cleaned it still not working
Posted on Aug 20, 2010
Power is getting to my Bosch Exxcel dishwasher but it won't turn on. (None of the lights come on)
Start with the basics. Double check your power and circuit breaker. Next there is a float in the bottom of the dish washer located inside make sure this is free and clear.
Jan 06, 2017 | Bosch Dishwashers
How to repair my kenmore dish washer not powering on but shocked me before it shut down for good ?
it sounds to me as though you may have a bare wire giving a direct short to the system.therefore by having a hot wire grounding out on the dishwasher body, it is running that current to the dishwasher body where if you touch the dishwasher you will recieve a shock.this also doesnt allow the electricity to go to where it is needed to power your appliance.
May 20, 2014 | Kenmore Dishwashers
My child put dish soap in the washer and the suds have leaked through the door onto the floor. How do I clear up the suds from inside the dishwasher? This also caused the circuit breaker to trip and I...
Turn off curcuit breaker. Mop up suds and water with towel. Remove kick panel mop up water here and dry out with a fan. Replace Kick Panel. Reset Curcuit breaker. Add one cup of Vingar to bottom of tub. Run a rinse and hold cycle. Repeat if necessary.
Sep 11, 2011 | Maytag 24 in. MDB7601AWS Stainless Steel...
How do you reset the spring on the door? the door falls down when opened.
just need to on do the unit from the two screws that hold the top of the dish washer in,,,make sure you have enough hose and power cord to pull the unit out just a little ways,,,but it is always best to unplug the dish washer,,,but the unit needs to be pulled out and the springs just need to be hook back on towards the bottom of the dish washer,,,always work safe,,unplug the dish washer. water and electrical never works together
Feb 19, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
No power
possible faulty module. did u check fuse on circult board? water proberly coming from faulty water valve.u need 2 find where water is coming from b4 u install repaired circuit board.please reply 4 more help
Apr 01, 2010 | Fisher and Paykel GWL11 Top Load Washer
My dishe washer wont turn on
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced
Now, if you have confirmed that the unit is receiving power from the outlet, and the unit is still not responding, this will lead to a failed control board, or timer module. replace either the timer, or control board, in this case.
Nov 05, 2009 | Dishwashers
Dish washer will not start. Program shows that there is power, but it will not start. Door is securely shut. the other day I took the trap apart and saw about 1C of standing water below the silver...
Hi..
If dish washer wont start check this
  • Check for a blown fuse or tripped circuit breaker
  • Check that the dishwasher is plugged in securely
    or
  • Inspect the wiring connection to the dishwasher for burns or breaks.
  • Check the door latch
  • Test the door switch
  • Test the timer motor
  • Test the selector switch
  • Test the motor start relay
  • Test the motor
Check also this
  • Unjam the motor
  • Unjam the pump
  • Test the motor
  • Check the drive belt
Good luck !!!
Regards
PCmania
Jul 11, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Soapy water standing in bottom not rinsing soap off dishes
It sounds as if it is not draining. Try to trace the drain line under the sink. Usually it goes into a disposall. The port where it connects to the disposall may be clogged. Another thought. If you had the disposall replaced recently they may not have taken the knock out plug out which would give the drain water no where to go.
Apr 09, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Dish water won't start
hi,
you shouldn't have to pull the washer out, the fuse that may be the problem should be located in the door with the control board. there should be some screws around the door to remove it. however, the fuse may need to be special ordered. also make sure the power is off to the unit before you work on it.
Mar 30, 2008 | Bosch SHU9915UC Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
882 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
