I need to re-set my screen to where it stay on and does not go off if you will tell me where I need to go to do thatplease.
  • 487 Answers
Ok this is easy fix.
Press start
control panel
performance and maint.
power option
select never at monitor power off
and never at all the others.
than this will stay on and dont give you any problems
Posted on Apr 26, 2008
HL32V86 Hisense 32' stuck on standby wont turn on it seems screen stay black
Call the HiSense tech dept. You can find the number on line and they will tell you how to fix it or you can try using the remote and go to settings and see if you can fix it that way. Also the manual for this tv should be available online as well.
Jan 03, 2015 | Hisense Televison & Video
I HAVE 60 ' INCH FATBACK WHILE THE TV TURNS ON THE SCREEN THAT TELLS YOU , SETTINGS , STAYS ON UNTIL IT WARMS UP ....YOU GO TO YOUR REMOTE AND HIT MENU , IT DISAPEARS....BUT ONLY WHILE ITS WARM .
Got a heat related issue likely on main signal board---might be able to localize it (suspect a flat pack chip) with a hair dryer to heat the board just a bit.
Nov 05, 2012 | Televison & Video
Change the country setting for a garmin 1350
Typically, when the unit is turned on, the satellitetechnology is able to pin point the unit's current location and provide mapsbased on the user's position. However, if there is not a clear signal or youare located in a different country than the ending destination you are tryingto program into the unit, you may have to manually change the country. For thatplease follow these steps: 1. Touch anywhere on the display screen to access the mainmenu. 2. Tap or select the "Change Preferences" options. 3. Navigate to your map settings. In a Garmin this will belocated under the "View Maps" and then "Change Maps"settings. 4. Use the "Up" and "Down" arrows toscroll through the list of available countries. Once the country you arelooking for is highlighted, press the "OK" button. You will then beasked to select a state or more specific region in the selected country. Onceselected, press "OK" second time. Hope this will help you. Good Luck.
Aug 16, 2011 | Garmin Nuvi 660 GPS Receiver
Need to restore my sony vaio vpcee31fx/bj to factory settings how do i do thatplease
  1. Reboot your computer
  2. Press F11 to go to the configuration screen. A menu will appear, with the option to perform a Factory Restore.Choose "Restore Factory Defaults"
These instructions may vary depending on your operation system
Jul 10, 2011 | Sony VAIO EE Series Notebook VPCEE31FX/BJ
My computer is in one stage telling me the application is missing or corrupt, it stays on that one screen, i need help to reboot it to factory settings
Hello.
Reboot your computer and during the first part of start up repeatedly press the F11 key. This will successfully restore your all settings.
Hope this helps.
Dec 26, 2010 | Compaq Presario CQ60-220US PC Laptop
Green led light stays on,there is no messages or missed calls
I think it's there to tell you that you're within network coverage.
You can turn it off by going to Options, Screen/Keyboard, and set 'LED Coverage Indicator:' to "Off".
Hope this helps!
May 03, 2010 | RIM BlackBerry Curve 8310 Smartphone
Samsung screen black out
Sir,
your screen has got lose solidation which is usually ocuring in Samsung screen and Philps that is why you are suggested to get your screen resolidated through near by electrition
Aug 28, 2009 | Samsung HP-R5052 50 in. Plasma HDTV
The tv skeen stays black but the red light stays on . is my tube blowned out and needs replaced .idon't know can you tell me ?
If the screen is black but on, as opposed to black because it is off, check to see if your timer is set to turn the tv off.
Mar 08, 2009 | JVC AV-32050 32" TV
Set for copier to make balck ink copies no color
on the lcd screen upper leftarea touch the area where it says auto color then set it to black. then touch add function copy settings scroll to the one that says standard setting it will ask you if you want to set the setting then set it in . the default screen now should stay in black
Jan 30, 2009 | Canon imageRUNNER C3170I Color Copier
White screen
Set camera to playback and see if you get normal quality pictures. If not the CCD sensor is faulty ( or of course the LCD screen may be faulty ) and camera will be replaced since it is new.
Sep 03, 2007 | Fuji FinePix F10 Digital Camera
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
