Question about Acer Aspire 5315 Notebook
Fan making noises overheating? - Acer Aspire 5315 Notebook
  • 496 Answers
This is a very common problem with Acer Aspire5315 Notebook and in some cases the Laptop automatically just shuts down and things get very annoying in hot summers
If you have not opened a Laptop before then I will strongly recommend you to take this Laptop to a technician and get it serviced in front of yourself. The technician should open the body of the Laptop take out and blow air into the fan which should remove a lot of dust choking the fan making this noise. The other parts should also be cleaned in the laptop service process such as the fan duct leading to the CPU. When service is done on this PC it will remove 80% of the problem.
If you still face the sudden shut down problem. It will be due to the flakiness of the fan and you need to download a software usually developed by third parties and sometimes free to download just use the right keywords on you search engine and easy to install and which controls the timing of the CPU fan to start and stop.
Regards,
Tauqeer
Posted on Aug 04, 2010
  • Tauqeer Khurram
    Tauqeer Khurram Aug 07, 2010
    If you are using Windows 7 or Windows XP then you are lucky having an Acer Aspire 5315 because Windows Vista is extremely slow on many systems but believe me its not the base base problem as I have said in summer the situation gets worse but this problem seem to decrease more and more as the winters are on an approach in most countries. Remember computers always love cold environments and they work well also.
Instal windows 7 and your problem will be solved. I did the same and works wonderful, plus you'll have a faster lap
Posted on Aug 05, 2010
    Genius:
  • 1,354 Answers
Hi
you have to replace Processor fan
it's not working
My 2003 dodge durango keeps overheating , i just had new radiator put in and it started overheating again but now it is overheating with a very loud screeching noise like a belt sound what could be ca
as for noise will have to inspect under hood,could be fan or belt or pulley ,water pump .these are some things it could...My suggestion for overheating is replace thermostat. If your car has electric cooling fan then it may not be working..turn defrost on and if fan kicks on then fan motor is good..Now this does not mean that fan is working properly because fan is controlled by heat sensor switch that kicks fan on when motor reaches heat range......Things i would have checked....hope this information helps and good luck and Please rate my post...
Aug 17, 2012 | 2003 Dodge Durango
Laptop making loud fan noise like its overheating,
Go buy a can of compressed air and blow out the fans and vents. That should get it running quiet again.
Jun 08, 2012 | Acer Aspire 5336-2524 Intel Celeron 900...
For a week now my laptop has been overheating,then will shut itself down,the overheating happens rapidly,all internet connections have slowed exponentiallyy as a result,is it fan related?the laptop is
The laptop will need to be dismantled down to the motherboard level, use a can of compressed air attach straw and blow out all ports, heatsink and fan. It might be a good idea to remove both for closer inspection and several good blast of air for good measure, and check the thermal paste between the heatsink and processor ic has not dried out.
Apr 09, 2012 | Compaq Presario CQ62-112TU
My 2001 mazda protege started to make a very loud noise when idleing and even louder when the fan kicks on. Today I was driving and began to smell something hot ,looked down and my ar was overheating. I...
remove the thermostat and place in a pan of water a boil and wait to see if the thermostat opens , as for the noise , get the thermostat sorted out and see if still makes the noise , could just have been caused by the overheating, one thing at a time so you know what the problem is
Jun 03, 2017 | 2001 Mazda Protege
The fan on my HP Pavillion laptop is making a loud noise
It is good idea to repair it in service before burn out. Fan blockage may lead to processor overheating and burning ... so as soon as better regards Greg
Mar 08, 2010 | HP Pavilion DV9700Z notebook PC
Motor makes a noise (not all the time) and now the fan runs after key is turned off- never did this before!
what is temp of vehicle possible overheating if fan stays on and veh is hot and noise can be water pump --if temp is normal check fan and fan relay
Oct 21, 2009 | 2001 Chevrolet Impala
Fan makes a lot of noise, then computer suddenly shuts down
Seems to be overheating. When you say the fan makes a lot of noise, do you mean an unusual noise or just that it is on high?
Feb 10, 2009 | Acer Aspire 5002WLMi Notebook
Noisy fans laptop overheating?
Try using Compressed Air in a can by the vents. I would not recommend taking apart the laptop.
Dec 22, 2008 | Computers & Internet
Weird Fan Noises and constant overheating
Try to clean the cpu fan and also the door of thermal, it might be dust cause that noise.
Jan 20, 2008 | HP Compaq Presario V2000 Notebook
Acer Aspire 5315 Notebook Logo
396 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
