Question about SanDisk Sansa e250 MP3 Player
Hi, I bought the Sansa MP3 player recently. I worked for couple of days. Now when I start it shows initial Sandisk log and stops there.....I am not able to do anything thing....Even after connecting to the computer I am not able to view the data...Please suggest how to fix this issue
  • kakima Aug 04, 2010
    Press and hold the power button for fifteen seconds before releasing it. Does that do anything?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • SanDisk Master
  • 102,366 Answers
Having gone over a month with no response, I assume the reset solved the problem.
Posted on Sep 17, 2010
  • kakima Sep 17, 2010
    Having received no response in over a month, I assume the reset took care of the problem.
2GB SANSA Express
You may need to get either a memory stick to go in the available spot, or if you do not already have one and do not want to spend any money, get a paper clip and carefully stick it in the slot and it should come automatically.
Oct 28, 2008 | SanDisk Sansa MP3 Player
My Sansa Express Music Player shows mulfactioned error
Insert A Micro SD Card And Start It Up
It Should Work
Shut It Down And Remove The Micro SD Card
It Should Startup Fine.
Sep 09, 2008 | SanDisk Sansa c150 MP3 Player
Sansa E250 hanged
I got a sansa player and it all of a sudden stopped working - It might just need to be reset - not sure if this will help but it did with mine.
If you have a power button that "slides" hold it up in the "on" position for 15 seconds.
Sep 02, 2008 | SanDisk Sansa e250 MP3 Player
A problem with my sansa shaker
Hi again audreytagle. Please take your slip and take your sansa to the place you bought it and show them the problem they will probably give you a new one. before you do that try inserting new batteries into the sansa shaker and see if the product works. if not use the above mentioned solution.
Jul 30, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
SanDisk Initializing
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 03, 2008 | SanDisk Sansa m230 MP3 Player
Sansa - sandisk m250 troubleshooting
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second and then reinstall the battery without pushing any further buttons.
  2. Plug the Sansa into a computer, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. This solution has worked for me.
I do not know if this will work on other Sansa m200 type .mp3 players.
Dec 20, 2007 | SanDisk Sansa m250 MP3 Player
Refresh database freezes
Try updating the firmware of your player. Switch the player to recovery mode (enable hold switch and press and hold the record and power button until you see on the screen welcome to recovery mode) download the sansa firmware updater on the sandisk website and install it to your computer. When it ask to connect the device connect the player and check if there are updates on the player. Also try to format the player it may be the songs on the player is causing the problem.
Jun 17, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Creating+ Saving Playlists and Doubled Songs
If you open the Sansa as normal Win file directory, can you see them? Is "Show Hidden Files" enabled in the file options?
Jan 01, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
