Question about HP PhotoSmart 7760 InkJet Printer
Hp photosmart 7760
I had a paper jam. I removed the paper but it didn't help.
when I tried to print again I got a loud noise and the display said ,print cartridge cradle is stock, clear jam then press ok
With a paper jam in any printer you must turn the printer off and pull the paper out in the direction it would normally go. Otherwise you can break something mechanical or damage electronics. The first thing to do is to turn the printer on, and when the ink station travels to the center (as in when you open the cover to replace cartridges), pull the plug from the wall. Wait 20 seconds and plug it back in. The result is a re-initialization of the paper feed motor. It doesn't work to pull the plug out of the printer, you must pull the ac plug out of the wall and interrupt the boot up process. Another thing to try is to turn the printer on so when you open the cover the ink station moves into place as though you intend to pull a cartridge out, then uplug it from the wall, and you should be able to freely slide the ink station back and forth on the carriage bar. If that goes okay, then you need to go deeper. Usually, to find the problem the printer case must be dismantled (not an easy job, even for a pro, as covers have many hidden tabs to be released, usually all at the same time, requiring more hands than humans normally have) to see what has happened. The cause is usually way over on the left side of the carriage where a cog or tab has been pushed out of place or a hidden piece of paper is bound up on something that won't allow the ink station to travel the carriage all the way. A piece of paper could also be squashed tight under the paper pickup assembly. It is beneficial to note that when you removed the paper the whole piece came out (not missing a corner or torn piece). The mylar encoder strip (a plastic strip about 3/8 wide running running the length in back of the carriage bar) tells the ink station where it's at. It can be damaged and must be in place or it may make the printer think there's a jam (called a false paper jam). Last thing would be to take it to someone who cleans inkjet printers, as we have done since they were invented, as 90% of problems are solved in the dismantling and cleaning, for a set price.
Posted on Apr 26, 2008
    Sergeant:
    Champion:
  • 221 Answers
Try to see if there're any Paper Pieces left while you were removing the rest of them. If you find there any, remove then retry. If this fails, contact the Service Center.
Sahaja Yoga is FREE OF CHARGE.
Printer says paper jam on calibration
If you check closely, you may find there is a small piece of paper trapped between the rollers?
Feb 21, 2013 | HP PhotoSmart 7760 InkJet Printer
Hi. I have a paper jam in my Photosmart 7760
1.unplug the power from printer to reboot it
2..if the lights flashing like woof said check for jammed paper or sticky label inserts in the back door of the printer.
4.clean the circuit bit of the cartridge (sometimes a thin film of ink can stop the circuit)
Oct 20, 2009 | HP PhotoSmart 7760 InkJet Printer
Hp photosmart 7760 print cartrige cradle is stuck.this happened after i ripped a paper jam out
try to move the cartrige cradle to left and right for about 10 to 11 times. if the issue still persist you may need to service you printer
Sep 27, 2009 | HP PhotoSmart 7760 InkJet Printer
My printer keeps saying there is a paper jam but there ins't any paper in it
  • reset the printer, reboot the computer, try to print again.
  • open up the printer and remove the slivers of paper in it.
Sep 14, 2009 | HP PhotoSmart 7760 InkJet Printer
Won't turn on
When removing jammed paper from a printer you need to be very careful as printers have a paper sensor which is very sensitive and it can be damaged if you pull the paper to hard. I first need to know, the printer doe not turn on or it does not print ? What brand of computer is it ?
Aug 25, 2009 | HP Photosmart 2710 All-In-One InkJet...
Get error message on my HP Photosmart 7760 that "Print cartridge cradel stuck. Clear jam then press okay"...but there is no jam. :( Help...thanks.
jam not on the paper but, check the space where the printhead slides on, see if there is something blocking the path
Jun 26, 2009 | HP PhotoSmart 7760 InkJet Printer
Paper jam, not allowing me to print.
Clear the paper that is causing the jam, if this does not work try uninstalling the printer and re-installing. It worked for me with a HP Photosmart 7760
Nov 24, 2008 | HP Office Equipment & Supplies
Printer reads insert card.
Removing from my que due to inactivity
Feb 07, 2008 | HP PhotoSmart 7760 InkJet Printer
HP PhotoSmart 7760 InkJet Printer Logo
197 people viewed this question
Ben Johnson
