Question about Hitachi NV45AB2 Roofing Coil Nailer
My nailer is shooting the head of the nail and stumbling especially if not in perfect vertical position(tip at north and air fitting south) even then it still skips and nailhead first with the odd nail just falling out.
  • 125 Answers
SOURCE: won't feed nail
This happens to my gun too. You probably need to oil the gun once in a while. Here is how you fix it:
Disconnect the gun from the compressor first don't wanna get hurt or anything like that. There is a pin that shoots the nail out well that pin is jammed so what you have to do is push that pin to the original position. using a flat head screwdriver would help you to push that pin back into place. Let me know how that turns out please. I pretty sure that is the problem with your gun. Make sure you lubricate the Nailer once in a while.
Posted on Oct 02, 2008
  • 1388 Answers
SOURCE: air leak
Several models of hitachi nailers share the same orings and other parts including the check ball under the trigger pin in your gun. Remove the roll pin holding the trigger to release the trigger pin, (plastic with one oring) then remove the valve with a screwdriver. Replace the vinyl check ball and seal. Parts are available at www.toolpartsdirect.com. This should fix the problem that you are describing, however use caution and check that the safety if properly adjusted. Enjoy
Posted on Dec 07, 2008
smjdragonfly
  • 79 Answers
SOURCE: air leaks not the problem
sounds like the piston or the head valve is stuck. Open up the back with an allen wrench. Look it over really well. Clean it out with some WD40 after you pop out the head valve and take out the piston and cylinder. You're probably gonna need a kit with seals and o-rings. There is also a bumper (towards the front of the gun that seats inside the cylinder, make sure everything looks good and not dry-rotted or dirty. Lemme know. Please rate me
Posted on Jun 18, 2009
rowdy45176
  • 2176 Answers
SOURCE: NV45AB2 worked great a year ago.hooked it up last
if you havent used in a year the o rings could be dry and you can try and lubricate them, but sounds like it needs them replaced. You can try going to Nailgundepot.com and buying an o ring rebuild kit from them. It contains all the needed parts except for the grease to lube the o rings. Let me know if you need more help
Posted on Dec 23, 2009
Testimonial: "Thanks for the reply and the items to check Rowdy45176,It is an older gun i bought used."
  • 382 Answers
SOURCE: Hitachi NR83A2 nailer pushes next nail down
Are you using full round head nails?
The hissing indicates your O-rings are worn out and need to be replaced. This is not covered by warrenty and is common for all nail guns. Lots of kits are available on Ebay or your local Hitachi service center should stock them.
Hope this helps,
Cheers
Posted on Jan 22, 2010
My clipped framing nailer will shoot two 2 3/8 at the same time. what do I need to repair this gun?
I would look at the nail collation and nail angle first. If both OK for this tool, remove all the nails and air hose. Bounce the tip and see if the driver falls down on its own and if it does the o ring is worn and would need replaced. When inside the tool look for other wear items.
Mar 04, 2012 | Dewalt Clipped Head Framing Nailer
My clipped head nailer does not shoot the new round head nails very well. constant jamming or shooting two nails at once. These are the nails stocked by Home Depot and most lumber yards
This response does not speak directly about your model of nailer, however addresses the problem of the nail supply. Generic nail suppliers are trying to sell us nails that are not exactly a perfect fit for our nailers. Nail guns are made for an exact angle and head of nail. Yet printed on the box of some of the case of nails, I see that the nails contained within will fit a variety of nailers with a variety of angles (+/- several degrees ).
You can choose a good fitting nail by taking a close look at your gun. Take a strip of nails and place them on the outside of the rails/magazine with the first nail perfectly aligned with the path of driver. With the first nail aligned with driver path, the angle of the rest of the strip of nails should align with the rails. If the angle is off slightly could be ok. Now align the strip of nails perfectly with the rails. Notice if the point of the nail or the head reaches the path of the driver blade first.
Recall that the nail should align perfectly with the path of the driver so that the driver blade will hit squarely on the head of the first nail over the shaft of the nail. If the head of the nails is forced away from the centerline of the path of the driver one way or the other, you will not get a solid square hit driving the nail true (think of hitting a nail with a large hand held hammer with an angular blow bending the nail). If the nail head is angled too far towards the path of the driver, the driver can hit two nails (the driver will hit the edge of the second nail of the strip).
The driver is designed so that it will not touch the second nail on the strip (assuming the nails fit perfectly). The driver blade is tapered at the bottom on the side that faces the nails. This taper allows the driver to hit the first nails then gently nudge the rest of the nails back into the rails slightly. To verify the shape of the driver blade, dry fire your gun into soft wood and examine the imprint. The imprint will not be round, but "D" shaped or flat on both sides like some Paslode framers. The flat side of the "D" will face towards the rails.
By using the information here, choose the nails that best fit (align) your gun (measure the angle with a protractor) . The lumber yards do not have a very good selection of brands. Try a professional fastener store that deals in nails and nail gun repair. Good luck
Jun 23, 2011 | Ridgid FactoryReconditioned ZRR350CHA...
When I go to shoot the nail, it won't sink the nail all the way. The head of the nail is still an inch or so out of the lumber. Also, when I push the safety against the nail, sometimes it won't shoot. I...
Remove the nails and dry fire the gun against thick rubber or coiled hose to absorb impact. Driver should be visable about 1/4 inch past the nose. If not visable then tip of driver may have been broken off. If driver length ok then time to reseal gun to regain full power. To solve irregular firing, replace the trigger valve (usually part# TVA6 ) and examing the trigger itself for worn contact surface or worn retainer roll pin. Parts are available at www.toolpartsdirect.com. Good holidays
Dec 28, 2010 | Stanley Bostitch F28WWMCN 28° Industrial...
MY NAIL NOTIS SHOOTING AND BENDING THE NAIL INSIDE THE GUN
you have a problem with the nose or the driver. I would also check for a jammed nail in the nose assembly. let me know what the model number is and I will try and find a breakdown for you.
Sep 18, 2009 | Stanley Bostitch Coil Framing Nailer
DeWalt d51822 framing nailer, shoots 2 nails at once 1 in 5 times
I worked at at tool rental center while attending college and learned from the old tool masters about nails and nailers. Rental stores have many different brands of nailers to rent and customers would bring their own nails of all brands. You will notice on the case/box that your nails will /should work on many other brands however the degree or angle of the nails is not always exacly as stated on the box. You should check with protractor the exact angle of your nails and also check the exact angle of the nailer. Use straight edge on travel path of the piston and another on guide rails to check angle of the gun. You will discover that all is not as stated as in a perfect world. If the angle is off slightly, the head of the second nail will get into the path of the driver. This happens mostly with clip head because the nail heads are so close together. The full round head is spaced further apart with less jamming. If angle is off slightly, take a look at other brands of nails with protractor in hand, the angle will be different slightly or choose a slightly thicker nail. Look for the nails to fit with bottom of nail hitting the barrel first. This will move the head of the nail slightly away from the center line. Finally do not release pusher with force as this will jamb nails closer together. Good Luck!?
Jun 03, 2009 | Dewalt Heavy - Duty 31° Clipped Head...
The nailer shoots a nail when the trigger on the handle is pulled irreguardless of the hammer being used to strike the head
I found a broken retainer ring in the head of the nailer. It had the striker head jammed in the down position so when you pulled the trigger to arm the head with air pressure, the flooring nailer shot a nail.
Thanks ..
Apr 18, 2009 | Air Tools & Compressors
Porter cable fc350a frame nailer shoots just air
Could be a couple things, first are you using the right nails in the gun e.g. collation and degree. Second do the nails move freely in the magazine and how is the pusher spring on the nail does it have enough pressure. Then I would unplug from air remove all the nails andjust tap the nose on a piece of wood and does the driver drop? If so the piston Oring is worn and needs replaced, but if you do that I would recommend replacing all the rubber. Let me know and I would need the exact model number to come up with parts.
Jan 25, 2009 | Porter Cable Cable No. FC350A Clipped Head...
Nail would not shoot out
The problem that you describe is caused when the driver is not returning all the way back up to the top of the cylinder not allowing the nails to enter into position . You may have one of several problems including worn piston oring, bent driver, worn check valve, worn lower bumper, or low air pressure. Simple test is to manually push the driver blade back to top using a thin piece of metal that fits into bottom of gun. Be sure to disconnect from air supply when doing this. Good Luck
Jan 08, 2009 | Stanley Air Tools & Compressors
Nail gun will not shoot nails
Lee
Remove the head, take out the blade and make sure its not bent or the tip broke off. Also while out insert the blade into the nose and see if there is any foreign object blocking the blade travel.
Jan 06, 2009 | Porter Cable 23GA Pin Nailer Kit
Won't feed nail
Sep 24, 2008 | Hitachi NR83AA3 3 1/4" Clipped Head...
Hitachi NV45AB2 Roofing Coil Nailer  Logo
61 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Roger Paull III
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
