Question about DISH Network IR Remote Control
Dish network 5.3 IR Remote doesn't work. Tried new batteries, doesn't seem to have power. How do I open it?
  • biftucker Dec 09, 2008
    I also would like to open the remote controll device. I only have one button that will not work 80% of the time. I might just be a dirty contact that could easily be fixed without replacing the remote. Thanks!
  • 51 Answers
I do not suggest opening your remote. If you call dishnetwork and inform them no lights are illuminating with new batteries, they will replace the remote. Pricing may depend on your accounts warranty.
Posted on Aug 01, 2008
TV 1 does not pick up Dish, scanned but doesn't show Dish
1) change the new batteries
2) Clean the contacts batteries very well
3) retight the springs contact for better contacts batteries
4) Open the remote and clean the keypad with special spray contacts cleaner.
Otherwise you must go to the repair shop.
download again the code: www. fitness.manualsonline.com
God bless you
May 23, 2012 | DISH Network IR Remote Control
Cannot control it with a RF to IR emitter.
Does the DISH remote work without the emitter? If it does work, then the problem is associated with the emitter. If it doesn't work, do you have fresh batteries in the remote? If you do have fresh batteries, you may need a new remote. Please contact us if you have DISH Network equipment at 1-800-333-3474 or go to www.dishnetwork.com, then click on the Contact Us link under the Support link on the main page. I hope this helps.
Ray Calo
DISH Network
Mar 29, 2011 | DISH Network DTVPal DVR by
I have 722 and a ir/uhf remote. Remote is set to uhf. All was ok until about 2 weeks into use and remote does not work unless 6 inches from antenna. I tried wizard numerous times and resetting to ir and...
Hello, this is Becki Barned, with DISH Network customer service. For this issue, since you have already replaced the remote and have the 5 foot coax cable on the antenna, then at this point, we would want to send a tech out for you. The technician can determine if this is an issue with the receiver box, or can set up a back feed for you. I can help you out with this issue further. You can e-mail me at becki.barned@dishnetwork.com .
Becki Barned
DISH Network Customer Service
Jan 16, 2011 | Universal Remote Control DISH Network...
jholsinger1,
It sounds like this is TV 1 that you are having this problem with the remote, is that correct? What has changed from when the remote was working till now? Was anything moved like the TV/receiver? You may have some type of interference with the UHF signal. Without getting more specific information, I'm generalizing the trouble shooting steps. Would you clarify if it's TV 1 or TV2. Please post to this site and I will respond back to you.
Ray Calo
DISH Network
My dish remote for my new vizio tv only works part-time. the volume and power work, but the guide button only works less than half the time and only after holding it down for 5 seconds. i have exchanged...
judileighahl,
If you have replaced batteries and had a new remote sent out to you, either the Vizio TV is emitting an IR signal that is interfering with the remote IR signal to the receiver. To test if the TV is emitting interference, is it possible for you to turn the receiver in a direction away from the TV and see if the remote will work? If it does work after moving the receiver, that indicates interference from the TV. If it doesn't change the situation, you might check for other interference from other components (florescent lights, etc.). I hope this helps.
Ray Calo
DISH Network - Executive Offices
Nov 30, 2010 | DISH Network IR Remote Control
Remote lights up as if it is going to work however it won't do anything batteries are new, so that is not an issue almost seems like it needs to be re programmed or something my 2 year old could have...
Without knowing the exact issue I can only provide general information. Since it seems like it may be a satellite address problem, I can definitely help with readdressing the remote.
To program remote to Receiver:
1. Access System Information from main receiver.
2. Note the number on the bottom by Primary Remote Address/Secondary Remote Address.
3. Hold SAT until all lights turn on on top of the remote.
4. Enter a number between 1-15 and press #.
5. Press record 3 times after it finishes blinking and the number by remote address should change.
Tommy Faust
DISH Network
Aug 31, 2010 | DISH Network IR Remote Control
Remote tv on & off won't work
I do hope that this has been resolved. If not, I have enclosed some steps for you to follow. You will want to follow the link below, which will walk you through a power scan. A power scan will scan your tv for the code that works with the remote. I hope that this helps.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
Jul 27, 2010 | DISH Network IR Remote Control
My dish network remote has an issue it take me 10 mins to get the remote to change chanels i have to keep pressing the button for allmost 10 minutes before it well work the remote has fresh batteries
drackul69, I am unsure what type of TV you have, but some LCD TV's generate heat while they power on and a remote on IR will not work until the TV warms which can take 5-20 minutes. If you have a LCD TV that may be a cause for the problem. If so a UHF remote for TV1 will fix that.
Tommy Faust
DISH Network
May 17, 2010 | DISH Network IR Remote Control
Dish network remote to run RCA DVD player
I had rca remote that did not recieve ir signals but rf signals instead. Check online with rca or in owners manual for what type of signal factory remote sends. The dvd player I had was 5 dvd and that was the case. Dish might have an option like direct tv where you can program rf signals as well. Call dish network support or look online
Apr 25, 2010 | DISH Network IR Remote Control
Dish network remote
i would suggest trying power scan again...
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
if this doesnt work try addressing your old remote to the receiver by pressing record from system info screen
Jul 06, 2008 | DISH Network IR Remote Control
DISH Network IR Remote Control Logo
1,016 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
