SOURCE: led light keeps flashing on my phoenix gold amp
if the amp went into protect you need to disconnect all power including ground for at least 20 min to discharge caps inside.
SOURCE: Sub Wiring
if you wire the subs in parallel you would achieve 2 ohms which would theritically double your rms, sadly this isn't the case what with wire resistance and such you might get around 270 rms still not that bad. to wire in parellel you run a positive off the amp to the positive on one sub then run a wire from the first subs negative to the second subs positive the run from the second subs negative to the amps negative and bam 2 ohms but be warned this will put more stress on your amp and cause it to heat up faster. peace bro and best of luck
SOURCE: Phoenix Gold Octane-R 15.0:1
PG won't release schematic diagrams. Are the burned components resistors? If so, what are their circuit board designations (Rxyz)?
