Question about Dishwashers
Milano dishwasher does not progress to the wash cycle on any setting. The wash relay in the door control panel clicks but the wash cycle does not start... Any ideas on what to do? Is it better to get a new one than try to repair it?
  • Brad Brown Aug 04, 2010
    What is the exact model number?
  • drivet Aug 04, 2010
    It's a Milano DW101S-MI.
    4 years old approximately.
markevans
  • 148 Answers
SOURCE: problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Posted on Dec 28, 2007
  • 90 Answers
SOURCE: help with dishwasher
What Brand is it?
Posted on Jan 05, 2008
SOURCE: ignis dishwasher model no. adl 347
I have the same problem. Having spoken to an engineer I have been told that the controller has gone. £120 for a new one plus fitting. So you are looking at a £200 bill to repair. Not worth it ???
Posted on Jul 16, 2008
SOURCE: IDL705 dishwasher showing error code
Indesit IDL700 first two green lights flashing and cycle stops with dirty water left in the machine. CAUSE - blocked or jammed drain pump. SOLUTION - First remove all the filters inside the machine, syphon or sponge up all the water in the sump and check for any obstruction over the fine grill at the very bottom. (we had a pistachio shell covering the hole!). If this doesn't cue it you will need to gain access to the pump. First, turn off the power. Gently lift the machine onto it's side (be ready for some water to spill out!). Remove the bottom plate (6 screws) and disconnect the sump float switch. Remove the single screw retaining the pump to the bottom of the machine and rotate to remove. You should be able to see the rotor blades. With your finger check to see if the pump rotates freely. To dismantle the pump, remove the 3 screws and separate the two halves. Our pump was jammed with an apple stalk!. Reassemble and connect any cables. Apparently this is a known problem with these machines and can be prevented by assembling the filter system correctly and pre-rinsing plates etc. before placing in the dishwasher.
Posted on Nov 01, 2009
tbreeze47
  • 3083 Answers
SOURCE: brada dishwasher ef2401 wont start wash cycle
If it's under warranty, get someone to look at it. Probably a bad switch or sensor in the unit, could be something simple, and they're not hard to open up, but the soap dispenser mechanism has to be reassembled (it often falls apart upon taking the door apart). Last resort is the appliance serviceman. New house? New dishwasher? Warranty? That's your best option.
Posted on Mar 14, 2010
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Leaking Milano Dishwasher
check all screws in door,and seals,also you might have a disconnected rinse hose in the door
May 13, 2015 | Dishwashers
Dishwasher code F4E1
The F4E1 is a code that signifies a WASH MOTOR issue. Specifically, no Communication. This is usually caused by:
A loose connection in Wash Motor Circuit, Motor Communication Circuit and/or an open wash motor.
1. Unplug dishwasher or disconnect power.
2. Check all connections in Wash/Rinse Circuit and Motor Communications Circuit. Fix/replace an open connection/part. Motor fuse on control open.
Using keypad press "Heated Dry", "Normal Wash", Heated Dry", Normal Wash, and the "cancel button" to reset.
Start a cycle and listen for 2 relay contact clicks at the start of interval to confirm both the pilot and motor relays are turning on.
These relays provide power to the motor, but the motor does not start until it receives a start command later in the cycle). If hear only 1 or zero clicks and wash motor does not come on later in service cycle, and there were no loose wire communication wire connection when checked above, then unplug dishwasher or disconnect power and replace control.
Apr 21, 2014 | Dishwashers
Panel lights shut off when door closed. Have to set before shutting door is this normal?
Hello Pat Braley - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may also prevent the unit to start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Dec 08, 2012 | Frigidaire Professional Series 24 in....
I have a candy integrated dishwashed and when I set it to do a wash all it does is rinse for hours
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .Inthis case as the machine seems to work on and on it seems that the fault relates to the controller. It seems that the controller does not progress in the cycle and so goes on .
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Thank You for using Fixya
Aug 23, 2011 | Candy Dishwashers
THE DISHWASHER STAYS IN THE WASH CYCLE
Check to see if the water is getting hot during this time, if not then the heater is probably not working, could be bad heater, bad door switch or bad heater relay on the control board.
Dec 14, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
Mid cycle stop
the thermostats need replacing thers 3 of them you can get to them from the front its better to take the door skin off first so you can see better then take the lower panel off.the thermostats are on the right hand side underneath.
Feb 12, 2008 | Asko D1716 Built-in Dishwasher
Soap door won't open during wash cycle
IT SEEMS YOU SOAP DOOR HAS A BAD SOLENOID ACUATOR OR RELAY
Jan 17, 2008 | Kenmore 24 in. 16592 Built-in Dishwasher
Bosch shu5300 dishwasher
there is a relay on the main control board that has gone bad. you have to replave the whole board to fix the problem
Nov 24, 2007 | Bosch 23 in. SHU5302UC Built-in Dishwasher
Dishwashers Logo
154 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
