Question about Garmin GPSMAP 76CSx Handheld GPS GPS Receiver
The gps 76gsx cannot get any signal..press new location and still cannot get signal
Hi...
I have the same problem.. Did you fix this?
If you fixed please let me know
thanks
Richard
blchasme@hotmail.com
Posted on Nov 25, 2010
Gps singal lost
Often, when your GPS is in a "covered" area ... e.g. inside a building, in a tunnel, under a bridge, amongst / under tall buildings, etc... when there is no open space (directly) between your GPS and the satellites, your GPS will loose its satellite signals. If you're in such locations, try to find some "open space" and wait a bit for the signals to be picked up again.
Another common reason why the GPS doesn't get signals, or doesn't get the signals quickly, is because the "latest" satellite positions (locations) have not been updated in your GPS. If/when you connect your GPS to your computer (e.g. using HOME ) and download the GPS satellite (QuickFix) location information, your GPS will have the most recent locations of the satellites in your vicinity/region. With this information, your GPS can pick up the signals more quickly ... instead of having to search/scan around to find the signals ... which can take a bit more time. While your GPS is searching for the satellite signals, it shows the "signal lost" or "no GPS signal" message.
Jan 16, 2014 | Tomtom GPS
How to change time
In Map view tap anywhere near the center of the screen. A new screen is displayed. On that screen locate the Change Preferences icon, tap it. Press the right pointing arrow (may have to tap 6 or 7 times) until you find the time and Date icon. Tap it and configure. You can set the clock manually or let it synchronize itself with the GPS signal.
Dec 20, 2013 | Tomtom One XL GPS Receiver
HTC STATUS PHONE cant find my location
The GPS signal cannot pass through solid non-transparent objects. Signal reception may be affected by obstructions such as high-rise buildings, tunnels, bridges, forests, weather (rainy or cloudy days), etc.You may also want to check to see if your GPS is turned on.How to turn on or turn off the Global Positioning System (GPS) close
  1. From the Home screen, press the Menu key.
  2. Touch Settings.
  3. Touch Location.
  4. Touch Use GPS satellites to select or clear the check box.
Dec 04, 2011 | HTC Inspire 4G Smartphone
My gps will take me to the home page but when i press on map to show my location i can't find any gps signal
While on that screen, pls reset it from the small pin hole reset button.
Hopefully it should come back to normal.
good luck.
Jul 29, 2010 | Insignia NSNAV01 GPS Receiver
How can I get a sattelite signal on my garmin nuvi 750? . It has worked great up until I lost the signal a few days ago. if you go to your location it is stuck on the last location before I lost the...
Power the GPS down for a spell, maybe an hour or two, overnight if possible. This will clear the memory and then power it up again, let it reboot. Make sure the GPS has a clear view of the sky or use an external antenna so the GPS can gather satellite data. Also do not press the buttons many times as this can confuse the GPS and make it "lock" up.
Feb 09, 2010 | Garmin nuvi 750 GPS Receiver
Can't get a GPS signal for last 24 hrs
I had a similar problem and did solve it with the soft reset (pressing reset button). I have a One XL and there is a small reset button that you push with a paper clip. On the XL 330 you press and hold the on/off button for 15 seconds and the unit should reset.
My symptoms: Would not find a GPS signal. When I looked at the GPS Satellite status (press on the GPS signal strength bars, again on the GPS/battery status) you can see it locking on up to 8 satellites but would still not show a gps signal lock. Normally it only takes 4 satellites to get a gps lock. My other sympton was that when I attached the GPS unit to the computer and operated it with TomTom Home, it worked fine and locked on to the gps signal quickly (even inside my home). But it would never (at least for 30 minute trips) lock on to a gps signal. After doing a reset it began working normally and locked on to a gps signal after finding 4 or more satellite signals.
Aug 06, 2009 | Tomtom XL 330 Car GPS Receiver
I am not getting satalite signal on my tom tom xl
The most common problem to this is because the TomTom doesn't know it's current location.  It may be that you last used your device a long distance from where you currently are now.  I don't know how long you waited for the gps signal to acquire but it can take up to 10 minutes (even on military aircraft if they don't know current location).
Power it up and press on the signal strength icon.  That will bring up your satellite tracking status.  If it don't look like it's doing anything, then your gps has probably malfunctioned.  If it looks like it's acquiring satellites, then give it a good amount of time (10-15 minutes) to see if it can find your location.  I recommend doing it outside of your vehicle with no satellite obstructions to make the process go faster.
Good Luck
Jun 10, 2009 | Tomtom One XL GPS Receiver
GPS 60 unit shows "Searching the Sky" status message all the time
The "New Location" fix above brought my GPS 60 back to full operation. I did reload the GPS software from Garmin but the recovery depended on well charged batteries and as above: turn the unit on
press MENU button
scroll to "New Location"
wait 10 minutes for the GPS to recover.
Jan 02, 2008 | Garmin 60 GPS Receiver
Loss of signal
Leslie, Not updating your GPS isn't going to cause signal loss. Push the options key, go to configuration, then to diagnostics, scroll down.. select reset gps. it will say it takes 5 min. to relocate.. etc. see if that fixes it. If it doesn't fix then when you restart your unit and the user menu appears. Press "-" key and "repeat" button at the same time.. then select clear gps user data or.. user data gps... something to that nature.. Hope this works out for ya. -Dan
Oct 18, 2006 | Magellan RoadMate 700 GPS Receiver
Garmin GPSMAP 76CSx Handheld GPS GPS Receiver Logo
170 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
