Question about Tools & Hardware - Others
I just got a craftsman framing naier #351-18320. and no owners manual what nails can i use?
  • rgrizfn2 Aug 04, 2010
    thank you it helps a lot
  • 15,935 Answers
CLICK HERE for your manual.
The nails you can use are listed on page 2.
Thanks!!
Posted on Aug 04, 2010
Senco frame pro 601 turns nail upside down with nail head going in wood first
The nails can turn over if you have the wrong angle or gauge nails in the tool. Make sure you are using the proper nails for your gun because they are not all the same.
Feb 19, 2015 | Senco Tools & Hardware - Others
I have a craftsman framing nail gun model number 351-18320 question how I reload it just got it on craiglist
Hi, W/D here.
On the side of the slide that holds the nails will be a tab. If the gun is empty, it will be close to the base of the slide, near the head of the gum. Grasp the tab, and pull it all the way back until it locks in place. Load your nails. Now, near where the tab that you pulled back is locked in place, you will see a (usually) silver button. Pull back slightly on the first tab, then push the button, releasing the lock. Let the slide push the nails into place, and you're ready to go. Place 2 drops of oil daily in the nail gun where the air line connects, then hook up the air line. Fire away!
Here is a link to an exploded diagram of your nail gun. Double click the diagram to enlarge it. On the right side of the page is the link to a free download manual. Enjoy!
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Nailer-Parts/Model-351183200/0247/0732000?searchedModel=351-18320&blt=
Best regards, --W/D--
Please feel free to rate this carefully hand-crafted solution, made especially for you. Thanks.
Feb 18, 2011 | Craftsman Nailer Kit, Palm Air Driver
My craftsman framing nailer has two nails jammed in head. Is this something I can repair myself?
Yes, just disconnect the air line and get in there and dig them nails out, don't wait for somebody else to work on it. Do it yourself. The front of that gun should lift up and expose the nails coming through, pull them out with pliers, make it clear, then reload and fire it back up and see what happens, a lot of times the generic nails will clog up.
Oct 10, 2010 | Nailers 3 12" Pneumatic Air Round Head...
Owner manual
Most all manuals are available at www.bostitch.com, look for support tab, then select service parts and documents. Find your model number in the pull down list and finally select usage manual.pdf, enjoy.
Jun 18, 2010 | Stanley Bostitch Coil Framing Nailer
Craftsman framing nailer not working properly
Yes you can purchase a Kit from the sears parts department. And just in case you are not aware of it, one needs to insert a few drops of oil into the air fitting periodically to keep things lubed. This may also fix the problem if you haven't been doing that. Good Luck and have a great week. Jeff
Apr 05, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
I have a FC350A FRAMING NAILER, IT IS IN THE
check to make sure that there is not a nail jam , if the driver will not retract then the gun will not cycle . if no nail jam then replace the inner trigger
Feb 02, 2010 | Air Tools & Compressors
Nail comes out another hole
are you using the right nails and are they inserted properly if this is an angle gun? Also look for a jammed nail that might be causing this. look at the magazine bolts to make sure they are tight. You can go to Paslode.com for the owners manual and troubleshooting guide.
Sep 10, 2009 | RTO PasLode 900420 Impulse Framing Nailer
I have a Sears framing nailer that uses clipped head nails.
I know on some other brands that to convert them we had to change the noses, but I honestly don't know about Craftsman. If you give me the model number I will try and do some more research and possibly come up with a tech support number for you.
Aug 25, 2009 | Air Tools & Compressors
Craftsman framing gun shoots every other nail how cam i fix it?
make sure the track is clean and lubricated, also spray we40 in the nose
Jul 20, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Oven door came off
Got it fixed! I found the owners manual posted on another site with replacement instructions. Expand the hinges from the door and insert a nail or screw into the hole there to hold hinges open. With hanging slots parralel to pins in oven frame slide back into place.Once in place open door completely and remove screw or nail. Couldn't be easier.
Jul 01, 2008 | Whirlpool GS460 Gas Kitchen Range
Tools & Hardware - Others Logo
987 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
