Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
My daughter set the router up and then moved out with the setup disc and she doesn't remember the pass code. My signal is not secure and my neighbors all use it. How can I make it secure? It always wants the pass code.
  • 550 Answers
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Posted on Aug 04, 2010
Testimonial: "Thank YOU!! That was extremely helpful and the response was a lot quicker than I expected. "
Cd perdu du routeur impossible de retrouver mon code??
Posted on Sep 05, 2010
How do I lock my wireless internet so neighbors can not log on
1. First you must set password to access the web interface, so that only you can change the setting.
For a linksys the default web-interface is at 192.168.1.1 The first term you access it enter username:admin, password admin. If that does not work read the manual to find that out.
2. Explore the TAB and each sub-menu to familiarize yourself with the interface. For change to Take effect you must SAVE. Button is at the bottom.
3. In the TAB SETUP>Basic Setup Activate the Automatic DHCP reservation of IP addresses. Enable it on the same page
4.Under the ADMINISTRATION TAB >Management enter a new router password.
5. Under the Wireless TAB> Security Menu, select the Security Mode as WPA2Personal, and Encyiption AES. Enter a passphrase ( like a password but can be a phrase -part of a sentence. For key renewal enter a number like 3600 seconds.
Save all.
Now if you connect a device through the wireless you will be prompted to enter the pass-phrase. You will be asked for it after every power down of router or reboot of router. If you reset the configuration by pressing the reset button on the router you must redo everything again.
Remember: You will erase everything every time you reset the router. So if you make mistakes, just reset it with a straightened paper clip.
Remember, any body who has physical access to the router can reset. If tech savvy, he/she can give him/her/self access.
Jan 07, 2014 | Efficient Networks SpeedStream 5100 Modem
Every time i secure the router the wpa/wep isnt compatible with my daughters laptop.....not too sure what do
Does your daughter have a very old laptop? Some older wireless cards do not support wpa/wep. You can still get her a USB wireless adapter and use that to connect to the router.
Mar 01, 2011 | Belkin F5D7234-4 Router
Set security pass code
After connecting modem(1) to router (2) connect your computer (3).
(4) Power on your modem, wait for modem to cycle(approx 2 minutes)
(5) Power on your router.
(6) Insert your CD - Click Router Setup & follow steps to setup secure wireless network...
NO CD DRIVE INSTALLATION
IN YOUR BROWSER ADDRESS FIELD:
http://www.routerlogin.net & click ENTER
1. Enter the router User Name admin & default password password to open your router's main settings page.
2. Main settings page, you'll be asked if you want to "Check for Update". Click Cancel. ( you can always check for new firmware after you're connected to internet)
3 Choose first menu item on left; Setup Wizard & make sure YES is selected
click NEXT, follow prompts complete setup.
SET UP WIRELESS SECURITY
  • 1. From main page choose Wireless settings
  • 2. Name your network- something easy to remember (Hint* People see it when you are up & running, write it down as well!) {The default name is NETGEAR}
  • 3. Select your security method. NETGEAR recommends: WPA-PSK(TKIP +WPA2-PSK (AES).
  • THEN, enter a Pass-phrase {Write down also, you will get e-mail confirming registration etc... But, BSTS.
  • NOTE: Both your Network Name (SSID) & Pass phrase are case sensitive. Network name, Security method & Pass phrase must all be the same on all the wireless devices connected to your router.
  • 4. Click APPLY & close your browser.
Depending on your cable/internet provider- if these instructions don't do it,
one of their agents should be kind enough to assist?
I was lucky enough to have them do it with me over the phone, after I had surgery & got sick of looking of the thing in the box in my floor!
Good Luck!
Dec 02, 2010 | NetGear Computers & Internet
We keep losing connection to internet when playing xbox 360 live. will be playing and screen freezes up for 15 to30 seconds then kicks us from xbox live.have a router with 3 xboxs hooked up.its unsecured...
If it's unsecured, there is a possibility that other people nearby are logging on to your internet connection through your open router. The more connections through the router, the slower it becomes. And the Xbox will drop is the connection becomes too slow.
As for a better answer as to why your losing your connection, try relocating the router. Often moving it higher up will allow a better signal. Other times a wall or shelf which contain metal objects is the cause. The signal weakens as it passes through construction materials, and nearby metal objects will definitely cause signal degradation. Try moving the router, sometimes only a foot or two is sufficient.
You should definitely learn the process to secure your router. It's like connecting your computer with a network cable to all of your neighbors computers and inviting them to see what you have stored on your machine. If their computer savvy, they can even watch what your doing in real time and even activate your camera and microphone! (It's been known to happen).
Securing the router involves the use of a network key (think of this as a password). Most modern routers have the default password printed on the body of the router. Using a special program installed when you installed the router, you can access the router and set the password. For example I use a Netgear router and the program that it installs is called "Netgear Genie". You access the router through the program using the routers user name and password (default as shipped is usually "admin" for both. Then set up the router to use security. After this all of your devices you authorize to connect to this router will also need to use the same Network Key (password). It's actually an easy process. For example, after you set the security, the labtop will attempt to connect and finding the system secured, ask you to enter the "network key" or password, to allow it to connect. It should ask you to remember this password so it can connect without assistance in the future
If your still uncertain, try running the router's setup program again. Most are designed to walk you through the process quickly. Just remember that all your devices will need to use the same password, the one that is printed on the side or bottom of the router. Usually it's something silly like "wonderfulwater456879" or whatever. Good luck and be more careful with your data in the future.
Jun 16, 2017 | Microsoft Xbox 360 Console
My neighor stealing my signal
You need to encrypt your wireless signal. Here are some instructions for getting in to your router's control panel.
Once you manage to log in, find the firewall region or wireless security region. Make sure to encrypt your wireless connection with the WPA-PSK authentication method using the TKIP encryption. Make sure to write down your pass-phrase, as you will need it to connect to your wireless connection.
Jan 31, 2009 | NetGear WGR614 Wireless Router
How do I protect the router from hacker neighbors?
on some routers, you can use your computer to make a security code on the router. once that is done, they cant use it unless they find out the security code
Jan 31, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless router
1. Log into the router with your browser by entering 192,168.0.1 into the URL bar near the top of the screen.
2. Type admin in the user field
3. Type motorola into the password field.
This will get you into the router setup.
Go to the wireless tab and setup WEP encryption. Write down everything you do, because you'll need ti later if you don't remember it.
Once setup, you'll need to setup any wireless computers that you want to hook to the router.
Here's a link to the router manual. If you go through it page by page, starting at page 22, then you should be OK. Key things to setup are WEP encryption. A lot of the other stuff, you don't have to worry with. And, you can change the login user name and password, which is highly recommended.
http://www.fixya.com/PostAnswer.aspx?thid=1586831&prdid=496213
Jan 23, 2009 | Arris SURFboard SBG900 Wireless Router...
Router problem
Connect a computer to any one of the four LAN ports of the Belkin wireless router. DO NOT use a wireless connection, use a cable.
Open your web browser and type the IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
Click Security under Wireless menu.
Under Security, Select 64 bit WEP (or 128 bit WEP).
Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you. Example (0102030405060708090a0b0c)
Apply the settings.
Please write down the key – You will need it later to configure your and your neighbors wireless computers with the same key.
Remember to set an admin password before you close down, other vice anyone can access you router and change the setup and admin password.
/regards
Teis
Dec 31, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
How do i stop people from stealing my signal from my dlink router
add a wep key. go on the address 192.168.0.1 and add a web key, i cant give you the specific way of doing it with out accses to a maual as this is modal depentent, read your maual and it will tell you some were hope this helps.
Sep 25, 2008 | Computers & Internet
Wireless router pass word
sakoz,
You have to reset your router. There is a small reset button on the back, which you have to hold in for at least 15 to 20 seconds if I remember correctly.
You should be able to then log back into it with the factory preset it came with.
Please let me know if this helps. Good luck!
Mar 01, 2008 | Linksys Wireless-G WRT54G Router
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
181 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
