Question about Frigidaire ATF6000ES Front Load Washer
Final spin cycle doesn't spin - Frigidaire ATF6000ES Front Load Washer
  • 119 Answers
CHECK YOUR PUMP. IF IT'S CLOGGED OR BAD. IF NOT CLOGGED OR GOOD, YOUR MOTOR CONTROL BOARD IS BAD. GOOD LUCK
TIMOTHY 714-334-1998
Posted on Aug 04, 2010
I had the same problem! The solution is having a tech change the door lock mechanism. This resolved the issue in my case. Even though the door locked properly, it seems the machine was not recognizing it so it didn't go into spin cycle. Try this before changing anything else! It cost me 500$ in parts before the tech finally figured it out!
Posted on Aug 31, 2010
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
Frigidaire Gallery washer won't produce final high spin
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
Aug 14, 2014 | Frigidaire Washing Machines
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
STYLEMATER 4214164, AGITATOR SEAMS TO BE STUCK,
are you sure it's aggitating?common problem with direct drive washers is the motor coupling breaks and the transmission can't engage with the motor or you could have a bad transmission.usually you'll find oil leaking out of the ******. you can check this and the coupling at the same time.one other thing,when in spin open the lid and then close it and listen for a clunk and see if it spins,that would be the clutch on the ******.if this happens see if you can get it to spin in any other cycles,i've had bad timers do this,if it spins near rinse but not in the final spin and if you open the lid,close the lid and then the clutch falls and it does spin i'd say you have a bad timer,you can watch the timer,if it moves all the way to end but it doesn't spin in the same spot on the final spin but does spin in any other cycle it's the timer.but check the coupling first.http://www.youtube.com/watch?v=9K1KHEogf3c copy and paste,it will show you how to get at the coupling.
Oct 30, 2011 | Roper RAS8445KQ Top Load Washer
I have a Kenmore washing machine: Model 110 20722990. When it gets to the final spin cycle sometimes it works sometimes it doesn't. You can hear it going but the agitator is not moving and it does...
ok first, i need you to do a little test,,,put unit on final spin ,does it spin at this time ,,yes so pick the lid up every so lightly ,,did it stop ...put the unit in final spin again unit does not spin push down on unit lid and it spins..in both cases you have a bad lid switch.,,the part # is 3949238 the picture is how it look,,if you need help installing just repost...good luckonthejob5130_1.png
Sep 09, 2011 | Kenmore 24032\24036 Top Load Washer
Model GLTF167A0S0 Serial XC22704657... The final spin frequently doesn't work. I tried another wash cycle and the "high speed" spin didn't work. I can manually start the cycle and it...
If the water is pumping out fine you may need new shocks. But if it is slow pump the shaft on the pump is loose and causing the noise and possibly the spin issue. If it is loud when it does go into a spin (sounds like a jet engine) you have bad bearings. Big bucks to fix.
Jun 03, 2011 | Frigidaire GLTF1670A Front Load Washer
Doesn't change cycles, first spin and rince cycle doesn't work at all
Sounds like you have a bad timer Does it spin on final cycle? (Spin Cycle)
May 11, 2009 | Washing Machines
Washer will not start final spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 05, 2009 | Maytag EPIC MFW9700S Front Load Washer
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
329 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
