Question about Campagnolo Cycling
How to put campi cassette back together - Campagnolo Cycling
    Brigadier General:
  • 8,546 Answers
There are many different Campagnolo cassettes out there. A little Googl search goes a long way.
Here's a start.
http://branfordbike.com/page.cfm?pageID=60
http://www.parktool.com/repair/readhowto.asp?id=48
Posted on Aug 05, 2010
How to open vhs tape and put back it back together?
Open all the screws and raise the top off the bottom part. Avoid touching the outside of the tape. Be careful not to let the tape reels fall out and get tangled when you put the cassette back together.
Apr 23, 2014 | Televison & Video
'96 gmc safari: I bought a cassette adapter to
They aren't in the same family are will never work together! Take it back!
Oct 07, 2012 | Cars & Trucks
Defective cassette adapter for iphone 4s. stuck in side of the cassette deck
take the deck apart, get the tape and put it back together or see if you can find someone who fixes decks and ask them to take the tape out
Jun 16, 2012 | Dynex Mp3 Stereo Cassette Adapter Dx-ca103
Last season Shimano and several mail order houses said 'no problem' to using my existing Ultegra 6600 brifters with a 6700 SS rear derailleur (which would allow using the 11-28 cassette) Now...
The real question here is - are you having a problem and how can it be fixed?
Even full gruppos can cause users to ask us for adjustment advice.
OTOH, theoretically incompatible parts like Campi shifters and Shimano derailleurs can be made to work. I have several such pairings that work flawlessly. But then, I'm running 9-speed.
The thinner you go with cassette cogs the finer and less fault-tolerant everything has to work together.
As is attested to here: http://www.bikeforums.net/archive/index.php/t-623547.html
"AFAIK, there is no change to the RD's actuation ratio, so it should work."
http://cycle.shimano-eu.com/publish/content/global_cycle/en/nl/index/tech_support/faq_s/compatibility.download.-Par70parsys-0024-downloadFile.html/Road_charts_2009.pdf
http://www.parktool.com/blog/repair-help/rear-derailler-adjustments-derailleur
Sep 23, 2011 | Cycling
Hi I broke my 7 speed cassette I cant find what kind or make it is I would like to put a shimano on it just wanted to know if it would fit the bike is only 3 mounth's old can you help ? Thanks Charlie
Take it to a bike shop and ask them because they have to take some measurements very precicly. They can tell you if it's Shimano, SRAM, or Campy.
Aug 20, 2011 | Cycling
Hi, Repacking a Campy 8-speed cassette
Nice sticky grease might do the trick.
Jul 04, 2017 | Campagnolo Cycling
I have been given a set of Mavic NKSIUM Race wheels currently fitted with a Campag Cassette. Are these hubs Shimano compatable, as I want to fit a 8 speed Shimano Cassette Ian...
Nope. Campi and Shimano casette bodies are TOTALLY INcompatible, BUT I have had good luck with finding Campi casettes online (eBay) and having no interchange problems between my wheels and Shimano or Campi 9-speed shifters and derailleurs on several bikes. I switch wheels without concern for the other hardware.
http://desc.shop.ebay.com/i.html?_nkw=campagnolo+8-speed+cassette&_sacat=0&_odkw=campi+8-speed+cassette&_osacat=0&_trksid=p3286.c0.m270.l1313&LH_TitleDesc=1&_rdc=1
Within Campi there may be incompatibilities, though. If your wheels have an 8-speed Campi cassette now I think you'll be ok.
Feb 09, 2011 | Mavic Cycling
I have a Campy 10 Speed Shifter, running with SRAM S60 wheels, it causes some problems when upshifting
If you are running a SRAM or Shimano Cassette, then the spacing will be ever so slightly off. If you want to have precise clean shifting then you need to either replace the cassette body with a Campy one and replace the cassette with campy or get a 10-speed conversion cassette such as those from American Classic. Campy spacing on a shimano/ Sram spline.
The wheels in and of themselves should not make any difference.
Another trick for perfect shifting, make sure that your rear derailleur and shifter match - Campy to campy, Sram to Sram as examples.
Jan 02, 2011 | Cycling
I have a Campy cassette set on my Cannondale. Lately, there has been an intermittent clicking noise coming from the rear wheel when pedaling. Nothing appears to be hitting the wheel. Also, at speeds above...
Clicking noises are commonly bearing problems but may occasionally be loose pedal cranks. If rear cassette isn't free wheeling properly sounds like a free wheel bearing is defective. I don't know your Campy - mine are all Shimano - but you should be able to replace the free wheel assembly OK as a separate service item. Mind you if it's of an age to demolish a bearing you should also be checking the gear teeth and chain for wear.
Nov 21, 2009 | Cycling
Cycling Logo
241 people viewed this question
Top Campagnolo Cycling Experts
Michial Gueffroy
Marvin
Marvin
jimmarmor_ma
Are you a Campagnolo Cycling Expert? Answer questions, earn points and help others
