In the middle of washing a load, the samsung 7.0 J845 stopped and smells VERY hot, like something overheated and melted. Now it isn't working at all What is that likely to be and how much will it cost to fix it.
  • 343 Answers
Most probable cause is the belt between the motor and the drum pulley. If your machine is still under warranry, you have a case...
If not call a serviceman and make sure he/she has experience with this problem..
The original part is not adequate...
Good luck....Nomess
Posted on Aug 04, 2010
Do washing machine water pumps some how can get that hot from something being already wrong cause the water pump to melt down?
pump running without water will get hot enough to melt plastic .and that would suggest a plugged filter to me
Sep 30, 2015 | Washing Machines
Our washing machine smells at the start of a wash cycle and smells of fish.We have done ample clean cycles using different products and washed using various washing powders and liquids etc at 90+c. is...
posibly not melting glue as there not used in making the machine try putting a blech hot water wash cycle a few times in the machine and if the washer is not being used leve the door open to allow the unit to breath and stop using powder wash detergent use liquid wash detergent
best luck
Nov 10, 2010 | Bosch Washing Machines
Our samsung j845 front loader wont drain we have pulled every hose off and flushed them all out we have drained it and still nothing everything still sounds as if its working properly but it just wont...
I have a Samsung J845 front loader washing machine, A few weeks ago, no water would go into the machine, so replaced the broken solenoid. Now the water never stops going into the machine ??? The solenoid is working but not getting electrically turned off. When I pull the terminal from the solenoid the water stops. What has gone wrong now???
Jun 04, 2010 | Washing Machines
Burning smell
There's a number of reasons to smell burning after a washing machine cycle. It's a 220V appliance, so if it short's out it will cause problems. It's more likely the motor being overloaded making it hot and causing the electrical burning smell, or a short that's overheating something electrical. Check to see if the belt that spins the whole barrel is melted or worn anywhere. Inspect the wiring that's attached to the system that engages spin, which is different from agitation by the big tower.
If these both check out, an trip to the Maytag Man might have to fix overloading motors or relays, or switches, if anything turns up in your search for the source of the electrical smoke. Ozone is what you are smelling, FYI.
May 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
How to replace the belt on a Samsung J845 frnt loader washing machine
If you stand in FRONT of the washer, leaning over the top, the drive wheel is underneath the main drive motor, on the RIGHT hand side.  Loop the belt over the drive motor wheel, then over the main pully, and it should be good to go!
May 20, 2008 | Samsung WF337AA Front Load Washer
Washing Machine Smell and Stopped Working
thatss what it sounds like to me the motor simply turned off on overload( giving that electrical, almost burnt rubber smell.) either that or it was overloaded as well as overworked. i wouldnt see any reason for concern, unless was happenig on regular basis
Apr 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Plastic pulley melting
Whatever the pulley is attached to has seized. Either the water pump or tub drive, or something else has stopped spinning. The belt continued to run because the motor kept pulling it, and the friction from the belt melted the plastic pulley. Hopefully its the water pump, as its the most inexpensive. You should change the belt along with this fix, it has also got hot and probable will not last as long as it should.
Mar 15, 2008 | Maytag Atlantis MAV9750A Top Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
