Question about GE Spacemaker JVM1640SJ Microwave Oven
What does the flashing microwave icon in the lower right of the display mean? The oven will not start but everything else seems to work(like the timer, etc). This is the second time this has happened and after sitting a couple of hours last time it started working. I can't find anything in the manuel that shows the blinking display icons. Thank you
  • 38 Answers
SOURCE: Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
Posted on May 09, 2007
fridgetech
  • 473 Answers
SOURCE: GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
Posted on Oct 10, 2007
SOURCE: Microwave not heating.
check magnetron related circuit and replace magneron, check condencer, diode and etc.,
Posted on Oct 28, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp R 530DK 1200 Watts Microwave Oven won't cook
Good for you for doing the cold reset. Good job!
Hopefully it was not stored in a damp or unheated area, since that can case damage that will complicate the diagnosis.
But generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
Posted on Nov 25, 2007
  • 4 Answers
SOURCE: GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Posted on Dec 11, 2007
Our Advantium 120 oven (model # SCA1001KSS 02, Manufactured June 2008)is not working. Began w/ time not coming on when cooking and just a little green microwave light shows while cooking.
Typical of a control microchip failure caused by a power surge. With a microwave as old as yours, it is safest to simply replace the entire oven rather than attempt to fix it, as older magnetrons are likely to fail.
May 05, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
Why panasonic microwave oven stops working
when it does that is power supply. they do that. change power supply and see what happens
Apr 29, 2014 | Panasonic Nn-sd681s 1 2cuft 1200 Watt...
It displays SE and nothing works.
SE error means you have a shorted membrane keypad.
With your model number I can detail your options.
Jul 02, 2010 | Samsung SMH7178STD Microwave Oven
What does F-82 mean?. it is flashing on the display and the Microwave is not working. Thanks
F82 means there is no power being supplied to the lower high voltage transformer. It may be due to:
- failure of relay RY-4 on the circuit board
- 10A fuse open
- controller failure
We have the service manual and have uploaded it to our site here to help you.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more free information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jun 17, 2010 | Panasonic Pro NE1757 Microwave Oven
GE spacesaver xl1800 microwave. Unit comes on, but no heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
agf
Jun 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave works but does not cook (does not heat up). Everything else seems to work properly.
hello,
what this means is that there have been a disconnection on the wire of the element (heater)
what you need to do to fix up the problem is to unscrew the oven then trace the wire down to the element power point and fix it back to it position
please make sure all form of power supply is OFF when carry out this function
Good lock and thanks for using fixya.
Jun 03, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Bottons on microwave do not work
HI, the touch pad board has failed. you will need to replace this damaged board asap. this will correct the issue.
Sep 27, 2009 | Microwave Ovens
Replaced lower light. It flashed. Now the light
With this model you should unplug it first. More than likely it is a burnt track/trace on the controller board between the relay and the header going to the light. Easy to fix if you have a soldering iron, short piece of solid wire etc. Accessible from the front, just take off the top grille and then the one screw for the control panel.
Jul 02, 2009 | Whirlpool MH1140XM Microwave Oven
heatman101
jkjf
Apr 02, 2009 | Maytag MMV5207BAW Microwave Oven
My KEN GT/AL17 is displaying a "g" icon under the time display and will not function. Any ideas?
As requested, the Microwave was unplugged overnight but the hard reset did not work. The lower-case 'g' is still showing
Sep 25, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,079 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
