I need an online manual for my realistic pro-48 am-fm scanner model number 20-143
SOURCE: realistic pro 2010 scanner
to program
turn on unit, press program button, key in frequency ###.### press enter. keep advancing thru the channels with the program button until finished
Posted on Aug 03, 2008
SOURCE: realistic pro 2020 scanner
The Realistic PRO-2052 is an old (vintage) scanner receiver with fixed AM and FM modes on the bands it cover, as specified by the U.S. band allocation. The PRO-2020 covers only the VHF and UHF frequencies and modes AM and FM is not user selectable. Frequencies can be programmed into any of the 20 memory channels
U.S. Coverage: (varies from state to state and other countries. We don't use 30-50 Mhz here in the Philippines for 2 way mobile communications, except for cordless phones)
30-50 Mhz Lower VHF at FM narrowband only (covers mobile, emergencies, businesses, etc. and
cordless phones)
108-136 Mhz Aircraft band at AM narrowband only
138-174 Mhz Amateur and Commercial band at FM narrowband only (2 meter band)
410-512 MHz Amateur and Commercial band at FM narrowband only (70 cm band)
If you're trying to select AM or FM for a specified frequency, I'm afraid you can't do that as it is not selectable.
If you are trying to program AM Broadcast frequencies (mediumwave (MW) or FM Broadcast frequencies (FM radio stations), those were not covered by your PRO-2020's microprocessor. Even if you modify your scanner to receive those bands, you will not hear radio transmission properly since the receiver do not decode FM wideband, which is the standard mode for FM broadcast and Television band.
MANNY DE GUZMAN, JR.
SoundMagik Home Studio
Manila, Philippines
Visit my website at http://mannydeguzmanartist.wetpaint.com
My talents and modeling site at http://teenmodels2007.wetpaint.com
Posted on Dec 18, 2008
SOURCE: Realistic pro-2011 direct entry programmable scanner 20 channels
PRO-2011 Programmable Scanner (200-0118) Operation Faxback Doc. # 34694 PROGRAMMING FREQUENCIES 1. Select the desired channel in one of three ways: (a) Press [MANUAL]. Continue pressing until the display shows the desired channel. Press [PROGRAM]. (b) Press the desired channel and [MANUAL]. Press [PROGRAM]. -- or -- (c) Press [PROGRAM]. Press the desired channel. Press [PROGRAM]. 2. Type in the Frequency. NOTE: If you are uncertain about specific frequencies in your locale, RadioShack's "Police Call Directory Including Fire & Emergency Services" is an excellent reference. 3. Press [ENTER]. To program the next frequency, press [PROGRAM] to advance to the next channel Repeat the same steps to add more frequencies. HINTS AND TIPS FOR PROGRAMMING When you make a mistake while entering a number, press [CLEAR] and re-enter the correct frequency. If you enter a frequency that is outside a PRO-2011 band range, Error indicator lights. Press [CLEAR] and select another frequency. Any frequency within a PRO-2011 band range will be accepted. However, the frequency that can be stored into PRO-2011 memory is in 5 kHz step in the VHF bands and the 12.5 kHz step in the UHF bands. The scanner will automatically round off the entered frequency to the closest valid frequency. For example, if you enter 145.234 MHz, the PRO-2011 will accept this entry as 145.230 MHz. Or the entry 398.263 MHz will be treated as 398.262 MHz. The tuning range of your PRO-2011 is permanently stored in the microprocessor chip. There's no way it can be extended or altered -- even by a skilled electronics technician. So if you try to enter a frequency not in the PRO-2011's tuning range, you'll get an error message every time. If you want to change the frequency entered for a specific channel, enter the new frequency over the old one, following the steps in "PROGRAMMING FREQUENCIES" (above). (IR-09/25/96) Privacy Policy
Posted on Mar 05, 2009
regal_anthon
  • 23 Answers
SOURCE: I have misplaced my user guide for my Realistic Pro-36
http://safemanuals.com/brand-user-guide-instructions-owner-manual/RADIOSHACK see if this helps
please rate Thanx
Posted on Mar 08, 2009
BillB-SA
  • 2761 Answers
SOURCE: need codes for a Realistic Model#20-129 Pro-2024 Scanning Receive
Here;s a link where you can download and print the manual for your scanner:
http://support.radioshack.com/support_electronics/doc31/31323.htm
Bill B.
San Antonio
Posted on May 16, 2009
Owners manuel for Radio Shack Pro-2039
Nope... seems that since Radio Shack folded up it's tents almost all of the old links have dried up! And GEE, I had one of these scanners but have no idea where it is now?
A FEW of the exceptions follow...
PROGRAMMING
This Link is for the Pro-2021 BUT your PRO-2039 programming will be much the same!
Radio Shack Realistic Pro 2021 Scanner Programming and Overview
This link may help you too but it's a much more advanced scanner!
RadioShack Pro 2050 Scanner Programming Tutorial Police Scanner
PRO-2039 SPECIFICATIONS RigPix Database RadioShack Realistic Pro 2039 20 7462
GENERAL Type:VHF/UHF receiver/scanner Frequency range:66-88 / 108-174 / 380-512 / 806-960 MHz (Europe) Tuning steps: Mode:AM/FM Channels/memory management:200 regular in 10 banks @ 25 ch/sec
10 monitor Power supply:Mains Current drain/power consumption:Max 13 W @ 230 VAC Antenna impedance/connector:50-75 ohms / ? or built-in telescopic whip Dimensions (W*H*D):190*80*180 mm (7.5*3.12*7.12") Weight:1 Kg (2.2 lbs) Other features: RECEIVER SECTION Receiver system:Double conversion superheterodyne
1st IF: 10.7 MHz
2nd IF: 455 KHz Sensitivity: Selectivity: Image rejection: AF output power/speaker:1 W at ?% distortion / 8 ohms External speaker connector: MISCELLANEOUS Manufactured:China, 199x-199x (Discontinued)
For "PURE AUDIO" there is a MODIFICATION/Link:
http://schreiber.pl/mods.dk/mods.php3-radio=radio_shack&model=pro-2039&selectid=1855.htm
ANTHONY
Dec 21, 2017 | Radio Shack Radio Communications
Realistic uhf/vhf model 20-400 pro 58 ten channel. Where can I get an owner's manual?
Products associated to Radio Scanners - RadioShack.com
support.radioshack.com/productinfo/ProductResults.asp?...Scanners...
Get Acrobat Reader. Previous Page. Products associated to Radio Scanners. SKU/Catalog #, Model, Description ... 20-139 · Realistic PRO-38 10-Channel Direct Entry Programmable Scanner ... 20-313, Pro-76, Pro-76 200-Channel VHF/AIR/UHFHandheld Scanner ... 20-400 · Realistic PRO-58 Programmable Scanner.
Dec 18, 2015 | Radio Shack Radio Communications
Good Evening Pam
Radio shack has a listing of Scanner resources here:
Radio Shack Realistic Scanner Manuals The materials for the Pro 58 are here
http://support.radioshack.com/support_electronics/8570.htm and gives access to specs, parts list, features, and a guide to scanning. It's very mid-20th century in appearance, including using type-writer style fonts.
Hoping this helps!
D
Looking for a manual for a Realistic Patrolman Pro 40 UHF/VHF Scanner. I don't even know what kind of power supply it needs.. LOL
Hi, that unit looks to be a mobile scanner and if I'm seeing right then you would need a Base power supply that could supply 12volt to it. Course you could also use a computer power supply and find the 12 volt line out on it. Here is the link to some spec's for it. Looks also to be crystal controlled so it cannot be reprogrammed. Good luck.
RadioPics Database RadioShack Realistic PRO 40
RadioShack Realistic Pro 40
Sep 06, 2015 | Radio Communications
Looking for the owners manual for the realistic pro 2009 programmable scanner
  • Hope this helps.
Regards, Tony
Oct 15, 2011 | Radio Communications
I lost my code sheet and I can't program my scanner any suggestions? It's realistic Pro 2023 Scanner
Radio Shack has a pretty good search feature for old instructions on their website. You will need their part number off the unit, which will be something like "20-321". Do a search and you can get a PDF instruction manual for it online.
Dec 29, 2009 | Radio Communications
Realistic pro 2020 scanner
cordless phones)
Manila, Philippines
Jul 02, 2008 | Radio Shack Pro-2052 Scanner
Realistic pro 2010 scanner
to program
Jun 24, 2008 | Audio Players & Recorders
106 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
