Question about Craftsman Garden
I have a 6.5 craftsman push mower. It will start up on the first pull but dies a few seconds later. What could be the problem?
  • 43,501 Answers
There is a filter between the gas tank and the carb... pull that apart and get the dirt out...
heatman101
Posted on Aug 04, 2010
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
More results from forums2.gardenweb.com
Sep 25, 2015 | Cub Cadet Garden
Have a 6hp craftsman mower starts and runs for 30 sec dies have replacer carb with running mower carb replaced plug replaced coil flywheel key fuel tank sounds like it is seizing up slows down for a
you have bad valves seats probably broken loose do to overheating replace short block or by new motor short block cost to much 300.00 new motor 225.00 to 245.00
Sep 07, 2014 | Garden
Free craftsman manuals
First, drain the tank by removing the metal clip from the fuel line. Remove the air filter. Then remove the 3 bolts retaining the air filter holder. You will see the fuel line and the fuel filter. Squeeze the metal clips that hold the fuel line to the filter, and slide the line off. Replace filter with new one and reverse the process.
This is for a push mower. Good luck! Hope this helps.
Aug 18, 2014 | Garden
Why lawn moser starts then dies?
Carb needs to be cleaned
Aug 04, 2014 | Craftsman Garden
Craftsman 6.75hp 22 mower starts for a few seconds and concks out
If the carbeurator is pitted or corroded in any way you need a new carbeurator
Steve's Small engine repair & Blade sharpening
Jacksonville. Fl
Feb 08, 2012 | Craftsman Garden
Sears Craftsman mower-Tecumseh engine 3.75 HP- wouldn't start-replaced air filter & spark plug; dismantled carburetor and cleaned it; now it will start but only runs for a couple of seconds and dies....
check the linkage for the governor, maybe on the wrong side,when off it should be pushing the throttle wide open, the governor brings it down after start up!
Jul 06, 2010 | Craftsman Garden
The mower is 3 months old worked fine untill yesterday
the problem is either u have trash in the bowl of the carb or the float in the carb is stuck. either way u need to have someone look at it.
Aug 12, 2009 | Mtd 22" Yard Machine Push Mower
Craftsman zts 7500 will not run with levers engaged
Cody,
Yes, I am sitting when I do engage the blades on my craftsman zts 7500. All you do is pull/push the engaged button to your left well you are seated.
Apr 05, 2009 | Craftsman Garden
Garden Logo
94 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
