Question about Whirlpool Calypso GVW9959K Top Load Washer
In the middle of washing a load of clothes the letters fl showed up and the washer started beeping what do i do about this and what does fl mean
  • 119 Answers
FL - Overfill Condition
This error message occurs only if the machine control board
sees an open circuit at P17. If this is the case:
■ Press Stop/Cancel to clear the display.
■ With the power disconnected, check the upper harness
connection to P17 on the machine control. Look for any
contaminants on the contacts. There should be a closed
circuit in the harness between P17 contacts 1 and 3.
■ Replace the upper harness or machine control as necessary.
TIMOTHY 714-334-1998
Posted on Aug 04, 2010
My neptune washer stop working. has power but doesnt cycle. shows a FL code. cycle i mean as spin to start washing
FL means that the door isn't locked properly. Make sure that its locked tightly and restart the cycle
Feb 16, 2011 | Maytag Neptune MAH5500B Front Load Washer
Kenmore Elite top load washer will not begin wash cycle and keeps flashing "FL" and beeping twice every few seconds. Tried unplugging it to see if the electronics would re-boot. How can i correct this...
Hi
Thanks for using FixYa. Error LF or FL means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 12, 2010 | Kenmore 24032\24036 Top Load Washer
Whirlpool cabrio washing machine
FL error code generally means 'flood condition' which is telling you the machine is overfilling with water with water.
Try pressing STOP/CANCEL to clear the display.
If the condition persists the water fill valve or sensor may be faulty and may need replacement.
May 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag neptune washer display showing FL
fl is a over fill. clean the pump out and the sump near the pump is in the back the dran hose goes to it
Nov 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
I have a whrilpool calypso washer flashing the fl code
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^$#@
Nov 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore washer starting
"FL" is an over fill indication. Unplug the machine first (if you haven't tried that already) in an attempt to clear. If the problem persists, check all connections going to your control board, which is located under the control panel. Take them off one at a time and look for any contacts that may be corroded or dirty. This could be an indication that you have a bad control board, or a pressure switch that is starting to malfunction. Let me know if this helps.
Jun 22, 2007 | Kenmore 24082 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
125 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
