Question about LG LFX25971ST Bottom Freezer French Door Refrigerator
Not cold and make any ice - LG LFX25971ST Bottom Freezer French Door Refrigerator
  • LG Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
Samusung RFG297HDRS Ice maker not cold enough to produce ice.
Suspect that the rubber boot that runs all around the edge of your freezer door is deformed, allowing warm air to seep into your freezer. You will see where your temp sensor is located by clicking into the site of a parts supplier like ShopJimmy.com and pulling up their photo of the guts of your unit.
I’m happy to help further over the phone at https://www.6ya.com/expert/gramps_bab85ce284d72c1d
Oct 29, 2014 | Samsung RFG297HDRS Stainless Steel
Why won't by ice maker make ice?
The icemaker will not harvest if the temperature isn't cold enough. this may be why you are not getting ice.
Oct 04, 2014 | Frigidaire FRS6R4E Side by Side...
Ge refrigerator is not cold enough and ice is not working
What is the model number?
The ice maker will only run if the freezer is at the correct temperature.
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 27, 2012 | Refrigerators
Seems to make ice but will not keep it cold therefore it melts. It does this about 3 or 4 times a year but after staying off it will start working again
The only thing that keeps the ice cold is the ice itself. If the icemaker isn't making ice fast enough then the ice will melt before more ice drops to keep it cold. In other words the motor ice the slower the ice melts. Now if the door gasket isn't sealing properly then the ice could melt to fast. Also the ice is going to melt some and when it does the water has got to drain out the bottom. If the water doesn't drain the ice will be sitting in water and will speed up the melting process dramatically. I hope this helps!
Sep 28, 2010 | Scotsman DCE33PA1BC 15in Built-in...
GE Profile Artica icemaker does not make ice. model # PSC235GNA. We still get cold water .
use a thermometer make sure freezer is normal operating temp if freezer is cold enough and water is filling ice maker you may have bad ice maker very simple system make sure your getting water 1st thing to check is for water if you have water and freezer is cold youll have ice
Aug 18, 2009 | GE Refrigerators
ICE MAKER GETS COLD-DOES NOT PRODUCE ICE
Hi
Try turning the thermostat to a lower setting. (warmer) It might be set too cold and the thermostat isnt being satisfied. Usually this is all thats wrong with it. Temperature in bucket between 10-15 degrees.
Jun 08, 2009 | U-Line Icemaker
Frige is cold, freezer is cold & freezing . . . Ice maker not making ICE.
Hi: As we don't (as in I) know the actual temp. in the freezer, this is a simple and free try. Cold is cold. The temp in the freezer has to be 0 degrees to make ice. They are thermally protected. A good guess for temp. is your ice cream. Is it rock hard? A lot of refrigerator thermometers are inaccurate. Just try setting your freezer colder. Ignore human nature and don't check the freezer every 30 Min's. You will never get to 0 degrees. I hope this helps, Jeff
May 31, 2009 | Refrigerators
Hoshizaki ice machine repair?
seems that its low on water or float switch is bad. try to clean float
Sep 02, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
LG LFX25971ST Bottom Freezer French Door Refrigerator Logo
102 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
