Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Refrigerator isnt cooling, freezer is working fine. Vacuumed out underneath, turned cooling system off, unplugged for some time and plugged back in and reset temps. I can hear the fan running, and have made sure vents are not blocked.
  • 7,365 Answers
Light switch could be stuck on, to check that open the door somewhere on the side or bottom, there will be a little button, push it in & hold it, to see if the light goes out, if it does not go out, push it a couple of times more to help it to come unstuck, if the light will not go off the switch has to be replaced
the thermostat could be set to low, adjust to a higher number
check the door seal,; open the door 1/3 way,,& let go of the door,,see if it closes on it's own,, it should be a little hard to open after it's been shut,, also stick a dollar underneath the door seal & close the door,, then pull the dollar bill out & there should be a little drag,,if it pulls out to easy then the door needs adjusting,, or the door seal is bad...
to see if the seal is bad,,open the door,, & look at the seal,., it should not be flat or squashed in places, it should be firm all the way around,,
to adjust the door,, look on top of the frig,,there will be a door hindge on top,, some have a plastic cover & some don't,, if your has one remove it,, there should be 2 screws,,loosen both screws BUT DON'T TAKE SCREWS ALL THE WAY OUT,, grab the door & move it till it's even with the side & top,,,
then tighten the screws back,, then recheck with the dollar bill,,,
there are 10 other problems that would require a service tech to check & fix
hope this is helpful
Posted on Aug 04, 2010
Why is my fridge warm
There is a fan and a damper the blows cold air from freezer to refrigerator compartment. Damper is stuck closed or fan is not working is a good starting point.
May 07, 2017 | Whirlpool Refrigerators
Refrigerator not cooling
replace the ptc overload/relay on the side of the compressor this aids in starting and running of the compressor
Jan 12, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
My maytag refrigerator isnt cooling enuf, fan works but not enuf cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Oct 22, 2012 | Maytag Refrigerators
My refrigerator is not cooling. The freezer side is working fine. I vacuumed the front, back and underneath.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 22, 2011 | Refrigerators
Fridge bought in 2004. Won't freeze & cool. Lights, fan, all work. Vacuumed coils underneath & behind. Unplugged for a while and replugged. Help!
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 06, 2011 | Amana ABB2524DE Bottom Freezer...
Frozen solid freezer, warm refrigerator. (model Amana bottom freezer abb1922few) Can see frost on freezer foods and back vents (almost occluded). Just vacuumed wads of dog hair/dust off of front half of...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 27, 2010 | Refrigerators
My refrigerator stopped cooling and my freezer stopped freezing but the freezer is still cooling
Same thing with our GE Eterna Series - off and on for the last two weeks. Took back panel off, looked around, vacuumed dust build up off of the fan blades, etc.; everything worked fine for five good days. Then frig went out stopped cooling. Off and on for the last week. Unplugging it works for a day then back to not freezing and or colling.
Jul 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge and freezer cools when it wants to - freezer on top
hard to say, there is many questions left that need answered...does the compressor run, does the fans run? what more could you tell me.... whirlpoolpartssurplus.com free tech support
Jun 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cooling. freezer works fine.
Try taking the front cover off at the bottom and or the back of the fridge and try vaccuuming underneath.  Make sure you unplug in when you do this.  Then plug it back in and see if that solved the problem.  You have fins and coils underneath that if they get really dirty the fridge will not work properly.  Hope this helps
Mar 10, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
121 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
