Question about Bosch 24 in. SHY66C05 Stainless Steel Built-in Dishwasher
The glasses are coming out of the dishwasher with a cloudy film on them. the plates are just fine but the glasses are really bad.
  • Bosch Expert
  • 414 Answers
Check your salt container is full and the cap is on securely. Check the rinse aid is full. Check that the holes in the top spray arm are not blocked with food, plastic etc. or if you have a deodoriser hanging on the top basket that it is not obstructing the rotation of the spray arm.
This model has a diversion motor that alternates the water flow between the top and bottom arms, there is the possibility that this is faulty and the water flow is locked and only feeding the bottom spray arm. (This unfortunately will require a professional to replaced the instantaneous water heater). If you put the machine on a prerince cycle you should be able to hear the switch between the two baskets (approx every minute) to verify this, if you completely remove the top basket the change in the noise will be more obvious.
Hopefully, the first part of info will solve your problem.
Hope this helps, please leave feedback or add comment if this helps or you require further assistance.
Posted on Aug 04, 2010
Machine working fine last week then began to not clean efficiently then water did not all drain away so plunged, soaked up excess, cleaned filter, replenished dishwasher salt and rinse aid and put new...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Apr 17, 2011 | Haier Dishwashers
Cloudy film left on all dishes and glasses. How do I remove the film?
Buy a gallon of white vinegar and rewash your dishes this time add 1/4 of a gallon of vinegar in the water with no soap just vinegar and water.... Also check and see if the dishwasher is completely draining you may have another problem that the dishwasher is not completely draining and you are washing with dirty water...... check the screen in the bottom of the dishwasher and the spray arm to see if they are clean and open...... I have used vinegar in my dishwasher and it has taken the cloudy film off... You may have to add it a couple of more times if you have a real bad build up......
I also use cascade complete dishwashing soap and has helped the problem with the cloudy film.
Mar 28, 2011 | KitchenAid Dishwashers
All glasses and plates have a cloudy film remaining after wash
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Feb 21, 2011 | Whirlpool Dishwashers
Have a Kenmore #13749k dishwasher (for the past 3 years). For the past month any glasses on the top rack are coming out either spotty or w/ a film. Any items placed on the bottom rack are coming out...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Jan 30, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
My glassware is coming out cloudy! the dishes are clean but the glasses and some of the stainless steel has a cloudy film Please Help! I am currentyl using a rinse aid and cascade powder detergent It...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
Dec 15, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
My glasses are coming out with a cloudy film on the dishes and glasses
Dec 14, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
Dishes not getting clean - a film is left on the glasses and plates - we tried cleaning the bottom tray and filter out but didn't help shv4303uc/u12 is the built in model #
Sep 18, 2010 | Bosch SHV4803 Dishwasher
I get a film on the inside of dishwasher as well as dishes at the end of a cycle. You can really see the cloudy film on glasses. Dishwasher is only 18 months old.
Cloudy film is usually from hard water. Or it means the dishes arn't drying properly. you wanna make sure your using jet dry and that your not using liquid soap. Liquid soap is a killer of dishwashers and creates mineral deposits. If you have hard water getting a water softener helps too. Theres a cleaning agent called dishwasher magic that works to clean the dishwasher . You wanna make sure your heater is coming on too.
Jun 15, 2010 | Kenmore Dishwashers
Glasses are not clean, come out cloudy and someimes have small food particles left on glasses
When the glassware comes out with a film on them (cloudy) the most common problem is a failed heating element. When it is repaired, the wash water will be heated to the proper temp to activate the dishwasher powder/detergent.
Please report back here what you find. OK?
Aug 10, 2009 | Frigidaire Dishwashers
Bosch 24 in. SHY66C05 Stainless Steel Built-in Dishwasher Logo
91 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
