Question about Electrolux Guardian Bagged Canister Vacuum
No suction over heating we think dirt got inside and don't know how to get it open
  • Electrolux Master
  • 43,501 Answers
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
Posted on Aug 04, 2010
Miele s7000
My question is what kind of dirt are you trying to pick up. Regular dirt does not plug up in twenty minutes. If you see dirt flying around that tells me your vac hose or parts that have a suction is plugged up. Take the hose and hose attachments off and make sure there is no dirt inside.If they are clear check the inside of the vac for dirt as well. Check your filter which is back of the vac bag as it may be plugged as well. The filter should come out to be cleaned.
Dec 21, 2017 | Vacuums
Dyson DC07 bin falls open
you can replace the lid
Oct 28, 2012 | Vacuums
Dirt devil jaguar pet vacuum - no power goes to vacuum
I've literally disassembled the ENTIRE vacuum. I got it for a dollar at the local goodwill with the intent on converting it into a dust collector for my mini workshop. As others have said. The suction is abysmal. I don't think it could beat a dust vac. And that's with just the motor hooked to dirt collector. No brush, no belt, no carpet adjusting. Just a motor, dirt collector and hose. Zero suction. Removed the hose, zero suction. Remove the dirt collector, solid suction. Dunno if the dirt collector is missing a part, but I doubt that based on other replies. I'm guessing all the holes in the red tube of top chamber are the issue. But I can't easily access it. I think I may end up cutting it open to try plugging some holes or some other modifications. But this vac is garbage in its original configuration
May 22, 2011 | Dirt Devil Vacuums
No suction through top of hose - HELP
disconnect the hose where it goes into the clear tube on top of the base.there will be a little flapper door there when yo take it off.open the door and take a coat hanger with the end bent over like a hook and pull the dirt clog out of there.but first take the dirt cup off and remove the filter,if its clogged with dirt you won't have any suction.try using the vacuum without the filter in the dirt cup.if you have suction then then thats your problem ,a cloggeds filter
Jul 01, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Wont suction the water
the suction channel is probably clogged.the suction channel goes right up the middle ,you can see it by looking through the cover.probably a lot of hair and dirt stuck up inside.there are some screws on the botton you need to take out then the cover will come off.seperate the 2 pieces of plastic and you will be able to clean the channel.please leave feedback
Apr 05, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Vacuum hose has little suction.
There is most likely a clog in the hose. If the hose has poor suction the foot probably has poor suction as well seeing that the hose is what gives the foot assy suction.
Jan 05, 2009 | Bissell 6594 PowerForce Bagless Upright...
No suction
check the belt or the inside tube between the bag and the brush
Aug 11, 2008 | Dirt Devil M086700 Vision Bagless Upright...
Poor suction-need to know how to remove & clean filter under canister of Hoover Wind Tunnel Mach 4.7 Twin Chamber System.
I assume this is a Hoover Bagless, if poor suction, the hose or dirt inlet by the brush roll may have a clog. The filter inside the dirt container may need replacement. Some had a screw to take out to remove the cover for the filter, the one under where hte dirt container sits. Alos the belt may be stretch and won't turn the brush roll under load. Having the model number would help.
Apr 19, 2008 | Vacuums
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
Hoover Windtunnel
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Oct 15, 2006 | Hoover U6630-900 WindTunnel Bagless...
Electrolux Guardian Bagged Canister Vacuum Logo
54 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
