Question about Gilmour Mfg Metal Impulse Yard Sprayer Sprinkler 967zd
I need assistance with properly setting the water flow, range, and rotation of the 993hps Gilmour Impulse sprinkler and the 967hzs Impulse Spike Base Sprinkler. There were not directions with the products and I have been trying by trial and error to get the setting correct. I need simple, clear instructions. Sometimes the sprinklers rotate and sometimes they do not. I am not sure what I am doing to impact the way they operate. I need to be able to consistently direct the water in my yard. Thank you
For some simple instructions check out the "additional information" section at http://www.gilmour.com/Watering/Hose-End/Sprinklers/Large-Coverage/Metal-Head-Impulse-.aspx. If your sprinkler doesn't rotate, ensure that you haven't lowered the water pressure by opening another faucet elsewhere. My sprinkler doesn't rotate as freely as it did when it was new, but it probably just needs to be taken apart and cleaned and greased.
Posted on Aug 24, 2010
Gilmour oscillating sprinkler repair
Make sure the dial is set to a specific location.
Sep 22, 2014 | Gilmour Mfg 7900PS Oscillating Sprinkler...
Need instructions for Gilmour Timer Polymer Head Impulse Sprinkler on Polymer Sled Base 193TPB
You can contact them here:
http://www.gilmour.com/about/
or call their customer service line here;:
800-458-0107
Or go back to the retailer of purchase and ask for a copy.
I have been working on this since 5 minutes after you asked the question for FREE. Thought finding you an instruction booklet / guide would be quick. (boy was I wrong!) I now understand why you came to FixYa for help.
Thanks for choosing FixYa,
Kelly
Jul 22, 2011 | Garden
Have 5 199LMHS sprinklers with 3 prong base. 3 of them spray, but do not rotate. Very stiff with water pressure, but free with water turned off.. How can I repair?
sometimes if the water pressure to rotating sprinklers is too high, they won't work due to to much force ,, your system should be running between 50 and 70 PSI tops, if its more than that you need to add a pressure regulator to your system
Jul 15, 2011 | Gilmour Garden
I have a gilmour 193spb polymer impulse sprinkler. It won't rotate anymore by itself. If I turn it to one side it will rotate to the other side, but wont trip to rotate back automatically.
Yea. Join the club. One day you and I both might purchase a better sprinkler. That way it might be worth the cost of a gallon of CLR (calcium/lime/rust remover) to soak them in which should fix the problem.
We could have/should have, but might never blow them out to remove all water remains before storing them for the winter.
:o).
Jun 04, 2011 | Garden
I have a Gilmour sprinkler that has a metal head impulse. The stand it sits on can be folded up or out depending on the support you need. I've had the sprinkler for about a year and it was working fine...
The striker / splasher sounds like it was tweaked. This part is the piece that normally swings back and forth, in and out of the water path. If this is not able to move relatively freely, then the head will not be forced to move.
On the same note, if the stop rings have become tweaked, they may be binding on the head, or the stop arm that folds down.
I am surprised, there just isn't much that can be affected just be grabbing the head on this unit.
If it doesn't work out and you can't get it going, the head is replaceable. It will spin on off so that another head can go on in its place, preferably another Gilmor.
If I have helped you, please rate accordingly. Otherwise, I will not get paid. Thanks for using Fixya.
Sep 18, 2010 | Garden
Impulse sprinklers stick after cloclwise rotation; no return
i wouldbet it is a pressure related problem , can you isolate them so you are only running 1 at atime? at least reduce the number of sprinklers running at the same time just to test them, drop the number by1or2 and i`m sure your problem will be fixed youdoit
Jul 22, 2009 | Orbit Sprinkler System Power Source...
Gilmour Mfg Metal Impulse Yard Sprayer Sprinkler 967zd Logo
1,026 people viewed this question
Top Gilmour Garden Experts
Marvin
Marvin
cackelberry
Level 1 Expert
Charles T Nevin
Charles T Nevin
Are you a Gilmour Garden Expert? Answer questions, earn points and help others
