Question about Toshiba Tecra 8200 Notebook
THE LAPTOP WORKS FINE BUT THE SCREEN IS VERY DARK
  • 496 Answers
Every laptop that is coming to the market has a button the bottom left just next to the "Crtl" button. This button says "Fn". On the other hand please find the buttons that are marked with dark Sun or a white sun. These buttons are for decreasing or increasing brightness. Just press down the "Fn" key (or button) and then press the key with the white sun on it. The brightness of the laptop screen will increase.
The keys with sun symbol on it are usually the arrow keys.
Good Luck!
Posted on Aug 04, 2010
Dell Inspiron 1525 laptop screen goes dark
Hey Lea,
Try the steps below to see if they will resolve this issue that you are having with your computer. If this does resolve the issue you can email me. My email address is listed below in my sigfile.
1) UNPLUG THE LAPTOP
2) REMOVE THE BATTERY
3) HOLD DOWN THE POWER BUTTON FOR ABOUT 30 SECONDS TO 2 MINUTES
4) THEN PUT THE BATTERY BACK IN
5) START IT UP..
Thank You,
Dell-Jesse L
Dell Social Media and Communities
email jesse_leonard@dell.com
Apr 13, 2013 | Dell Inspiron 1525 Laptop
My dell inspirion 6000 laptop screen goes black but sometimes I can see the windows screen but it's very dark. When I attach it to a desktop monitor it works fine but the laptop is still dark. Sometime the...
The back light is the whole of the screen, the screen is illuminated by a CCFL lamp (fluro tube) on the bottom of the screen. A inverter supplies high voltage to this CCFL lamp.
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 08, 2011 | Computers & Internet
My brightness control does not work just turned on and can not hardly see anything it is up and running what now
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Dell Inspiron 1545 Notebook
VERY Dim screen after a drop
Mar 24, 2010 | Sony VAIO VGN-NS190J/S Notebook PC
Dell ADAMO 13 w/Vista 64 Random power failure...goes dead in 1 second. Battery fully charged. Happened with external power and when on battery. I have latest BIOS v6.0. I ran pre-boot diagnostics...
If the power totally fails (i.e. power is cut off, LEDs turn off, fans stop, ... etc), then this more likely to be because of a short circuit developing in a failing semiconductor component, or a power supply problem.
However, if the laptop is still running & only the display on its LCD is cut off but the laptop itself stays powered on, then your laptop might be experiencing a failing screen inverter board, a failing screen backlight lamp, or a failing LCD screen cable.
TYPICAL INVERTER FAILURE SYMPTOMS
Feb 07, 2010 | Office Equipment & Supplies
Compaq Presario R3000 dim screen but not dark
Sounds like the auto-dim in the BIOS is set too low. Fortunately the Compaq R3000 allows you to adjust the brightness right from the keyboard. Hold down the [FN] function key while tapping the [F8] key will brighten the screen, while [FN]-[F7] will dim it. The settings are different for running on AC power and battery, so you must do each individually.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
Monitor keeps going dark
It sounds like a LCD backlight problem. Bring it to an authorized repair shop.
Dec 02, 2008 | Dell Latitude D600 Notebook
Screen gone dark
Hi Peter, Have You Tried Changing The 'Screen Resoulsion' ?
I'm Not Quite Sure How ToDo This But, I'm Sure If You Get In Contact With The Make Of Your Laptop , They Will Give You Some Advice , Maybe Send Them An Email?
Kind Regards,
Jessica Fyfe.
Aug 31, 2008 | Acer Aspire 3000 Notebook
Laptop Screen dark yet computer works with external monitor
does the fan work ok? and do you have a laptop holder for it or you just have it on a desk ....get a laptop holder for it if you do not have one and as for the rest goto the power mangment area on the computer and see if the monitor might be on stand by after a few min ...
Jul 14, 2008 | Compaq Presario R3000 Notebook
Toshiba Tecra 8200 Notebook Logo
161 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
