Question about JVC AM FM CD DET FACE CAR STEREO
Aftermarket stereo i have a jvc aftermarket stereo that i want to wire in but i dont know how to match the colours i have an 88 nissan pulsar n13
Hey dude,
The red wire is your power wire, the brown wire is your ignition wire and the black wire is the earth wire
Posted on Mar 04, 2009
  • hsvbay Mar 04, 2009
    for a nissan pulsar n13
Are N13 and N15 Pulsar Towbars the same?
best place to go to is a tow bar fitting shop/ trailer shop for this.
Aug 15, 2014 | 1990 Nissan Pulsar
1988 nissan pulsar n13 keeps getting stuck in first gear
YOUR CLUTCH CABLE MAY NEED ADJUSTING,HERE'S A LINK ON IT,
Feb 12, 2014 | 1988 Nissan Pulsar
NEED WIRING DIAGRAM
If you are referring to installation and have the aftermarket wiring harness, The wires should be color coded. RED, YELLOW, & BLACK are power, ignition and ground. These should correspond to matching wires on the back of the head unit (CD player). Match the colored wires from the back of the unit to the same colored wires on the aftermarket harness and then connect them using wire connectors/wire nuts. Once you have them into the correct order the aftermarket harness should connect into the harness in your vehicle. I hope this answers your question =)
Nov 05, 2013 | JVC AM FM CD DET FACE CAR STEREO
Looking for a holden astra LD 1989 workshop manual
  • Nissan Pulsar N13 and Holden Astra LD 1987 - 1991 Workshop Manual Repair Manual for Nissan Pulsar N13 Series & Holden Astra LD Series ... N13 and Holden Astra LD 1987 - 1991 Workshop Manual ... 1987, 1988, 1989, 1990 and 1991. Holden Astra LD ...www.automotobookshop.com.au/gregorys-?nissan-pulsar... - Cached
  • Dec 07, 2010 | Nissan Pulsar Cars & Trucks
    Nissan pulsar N13 1991 GL manual htch cutting out even in neutral
    2 things, sounds air related
    1 there is a split in one of your air pipes causing it to take on to much air and cut out.
    2 the air flow meter or air sensor is broke, or may need cleaning.
    Use carb cleaner to clean the sensors and wires.
    Jan 15, 2010 | 1990 Nissan Pulsar
    Pulsar N13 instrument cluster no TRIP or OD
    the common faults with most n13 pulsar dash clusters come from the rear circuitry where theey are all running to their respective gauges . heat and time finally get to the circuits and they let go causing a very small crack in the line causing no voltage to the gauge. easy to fix with a soldering iron and lots of patience .. good luck
    Mar 15, 2009 | 1990 Nissan Pulsar
    JVC AM FM CD DET FACE CAR STEREO Logo
    252 people viewed this question
    Top JVC Car Audio & Video Experts
    xxxxxx xxx
    Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
