Question about Check Point Safe@Office 500 Router (CPSB5005US)
I have a Checkpoint Safe@Office 500WP that I am tring to configure with two WAN Connections. Is it possible to forward VPN Traffic trough one WAN port and anything else (namely HTTP port 80) through the other WAN port
SOURCE: Site to Site VPN between DI 804HV and Sonicwall TZ190.
open port udp 500
Posted on Apr 08, 2008
  • 35 Answers
SOURCE: Cannot connect with SonicWall VPN Client with GigaFast EE420 R
sonic is sitting on the gateway. so dont matter where u are still u cant get outside
Posted on Aug 13, 2008
  • 20 Answers
SOURCE: wanna open gates from the router SIEMENS 5890
u can use the port forward for forwading ur port if it is blocked.
Posted on Jan 07, 2009
  • 285 Answers
SOURCE: Forward port on Checkpoint Safe@office W500
You can try to do something under firewall settings under 192.168.1.1 or 192.168..0.0 or 192.168.0.1
Posted on Jul 15, 2009
  • 13 Answers
SOURCE: I am having problems with the Checkpoint Safe office
SecuRemote VPN client is not capable of office mode (get dhcp for vpn)
Posted on Aug 23, 2009
UTorrent dowload stops when I turn my VPN on. How to set it up?
An alternative is not to stop uTorrent, but to block the traffic.
Assuming you're on Windows, and your torrent machine is always connected to your local network (i.e. it's not a notebook that's sometimes connected to public networks), the simplest method is to set up firewall rules to block uTorrent from having any network access unless the VPN is active.
  1. Configure the local network connection as a private network, and have all new networks encountered automatically considered public (that means any new VPN connection would be public). There was a simple way to do this with Windows 7, not sure about later versions.
  2. Create firewall rules to block uTorrent from sending any traffic via private networks, and allow it to send traffic via public networks.
  3. If you use the web UI then you will need to add an exception for the web UI port on the private network.
Once this is done if the VPN goes down uTorrent won't be able to send or receive any traffic at all (you'll see active torrents turn red).
Another option is to set up a second machine just for the VPN which forwards all traffic to the VPN Service (this is a good use for an old netbook). Then configure the torrent machine to use the VPN machine as its gateway. This only works if all programs on the torrent machine need their traffic to go via the VPN (or the other programs can be configured to send via your router).
Oct 05, 2017 | Computers & Internet
While using checkpoint VPN-1 SecureClient to connect to Safe@Office 500 device in office mode, i can't connect to server at the office site. The office mode is on a different subnet than lan so my vpn...
In the rules, you will need to create a new rule that allows your VPN subnets access to you office LAN, and then on your office network gateway, add a route for your VPN subnet pointing back to your checkpoint firewall.
Nov 08, 2010 | Check Point Safe@Office 500 Router...
Apr 08, 2009 | Check Point Safe@Office 500 Router...
Configure VPN
That 3Com really doesn't have a wahy of setting up a VPN.
As per the 3Com site it:
Support of VPN termination/initiation and passthrough allows secure connection to central office and/or secure access from remote workers.
So it will allow 3rd party VPN setups to pass through, but it doesn't have the ability to create one.
You might want to look into something like a Netgear Firewall
http://www.netgear.com/Products/VPNandSSL/WiredVPNFirewallRouters/FVS114.aspx
Aug 09, 2008 | 3Com OfficeConnect Cable/DSL Router 4 x...
Site to site VPN between Checkpoint UTM 1 R62 and Cisco pix /Netscreen
I couple of points:
PIX has a few dislikes...
1. Pix does not like class A address, make sure you are using B or C.
2. The VPN subnet always has to be differant to the LAN.
3. Has to have a working DNS server.
4. Add static route, and last resort to main ethernet port that has the DNS & R62. (or 2 if on differant sub)
Hope this helps.
Dec 16, 2007 | WatchGuard Technologies Firebox X5000...
DI 524 Router Not able to connect to office VPN on Wireless
I have the same model router at home, just checked the settings, you should be able to pass through the router with a normal vpn connection.
If you use a special VPN client, like a CheckPoint Secure VPN client, the router might block it. Also you might want to ask your office's sys admin if you are not blocked by the firewall or something similar. Your office's sys admin will prolly solve your problem since he knows your work network's configuration and setup and how to connect to it.
Nov 08, 2007 | D-Link AirPlus DI-524 Wireless Router
VPN
This example will demonstrate how to create a Virtual private Network (VPN) between two remote locations through the Internet. The VPN policy will use 3DES IPSec to securely send/receive encrypted data over the Internet. When the VPN tunnel is enabled, the two offices will virtually appear to be on the same local network. This example will consist of two DI-804V VPN Routers with a simple setup. The two remote offices in this example will be known as Office A and Office B. Both VPN Routers must already be set up and able to access each other. This is only an example, your setup will vary using the WAN IP address provided by your ISP. Please note the differences in the IP addresses for each office. We will begin by configuring the DI-804V at Office A. Start by going into VPN Settings under the Basic Setup menu. Step 1. In the Connection Name field, type in OfficeA. Click ADD. Step 2. A properties screen will appear for the new connection you have made. Fill in the appropriate information for Office A: Connection Name: OfficeA Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: 192.168.1.0 Remote IP Netmask: 255.255.255.0 Remote Gateway IP: 192.170.0.2 Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 3 Click SAVE. There should now be a VPN policy created for Office A. Now you will want to Save & Restart the DI-804V. Note: 123456 is an example of a preshared key, please fill in any secret preshared key you desire. Keep in mind that both sites require the same preshared key. Office A setup is now complete, we will now configure Office B with the other DI-804V, Follow the same steps previously with Ofice A to create a VPN policy. Step 1 Please change the appropriate information. Connection Name: OfficeB Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: 192.168.0.0 Remote IP Netmask: 255.255.255.0 Remote Gateway IP: 192.170.0.1 Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 2 Click SAVE. There should now be a VPN policy created for Office B. Now you will want to Save & Restart the DI-804V. After the VPN policies have been created for the two Offices, the two remote locations should authenticate and connect. To view the status of the VPN connection, go to the Device Status menu. On the bottom-left side of the menu, click on the VPN Status icon. A VPN Status pop-up screen will appear showing VPN connection status. If a VPN tunnel is active, the State should indicate Q-Estab. Go to a DOS prompt and ping the internal IP address of the remote network.
Feb 16, 2006 | D-Link DI 804V (DI-804V) Router
Check Point Safe@Office 500 Router (CPSB5005US) Logo
98 people viewed this question
Top Check Point Computers & Internet Experts
DROPNDEAL
DROPNDEAL
Laxman Bisht
Laxman Bisht
Gil Shultz
Are you a Check Point Computer and Internet Expert? Answer questions, earn points and help others
