Question about FAIP Non Marking Pressure Washer Hose 4000 Psi, 50ft. Length
I have a craftsman model 580752300 and had to replace manifold after it was steped on and cracked. I also replaced unloader value . Now there is no pressure and water is coming out of chemical hose. do I need to adjust unloader valve?
4 Suggested Answers
  • 101 Answers
SOURCE: pressure washer won't build pressure
The problem sounds like its in the handle.. trigger mechinism
Posted on Dec 15, 2008
SOURCE: Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Posted on Oct 03, 2009
spraydoctor
  • 97 Answers
SOURCE: 020209 pressure washer has no pressure
Your water inlet may be stopped up. Whether this model only has a screened hose washer or a better filter, pay special attention to that. Be sure the pathway is free and clear.
Take each of poppet valves and while pushing (with a pencil or something) on the part that moves up and the spring pushes it back down - with magnification and lots of light, be sure there isn't a small piece of debris affecting one of those valves. Its easy to miss, so look very closely.
Next, remove the hose from the pump. We are by-passing the entire unit that includes pressure hose, trigger gun, lance, spray nozzle. If it seems to pump a lot of water out of the pump--then the problem is most likely the trigger gun is clogged or the pressure nozzle is clogged. Some trigger guns can be taken apart -- some, not so much. Same with nozzles.
I hope this helps you, Randell. If yes, please take a sec to rate me. Thanks!
Don
Posted on Mar 24, 2012
Where the pressure release valve on 2500 psi gas model
A pressure release valve on a pressure washer is called an unloader.. It is on most machines a removable part. It allows the pressure that is created when the trigger of the wand is released to be re circulated inside the pump manifold assembly. They are pre adjusted at the factory and I do not recommend screwing around with the adjustment because if it is tampered with it can cause the unit to stall or blow out your water seals. Yes the unloader on most models be replaced, but you have to order specific to the model you have to ensure you have the correct one.
0da044b2-f75b-474d-bf93-eee0e6d8d14a.jpgThis pic is a typical unloader found on most Briggs and Stratton and other branded pumps averaging 1600 2500 psi.
http://www.allpartsinc.com/ProductDesc.aspx?code=16030
Aug 27, 2014 | Homelite Garden
I have a Craftsman compressor Model # 919-15292 2. The compressor stopped building pressure because air was continually being released through the unloader valve. I have replaced the unloader valve,...
you must have wired the new pressure switch incorrectly .when the pressure switch opens it will release the head pressure so your compressor must be running with the pressure switch contacts open should be 4 connections 2 marked motor which is from your compressor and 2 marked line which is your power coming in
Jun 15, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Pressure off and on every few seconds with my karcher 3000BH
hi there rjcomer2
here is web site for parts
http://www.ereplacementparts.com/karcher-2500-11944010-pressure-washer-parts-c-33388_33389_33973.html
sounds like you have a unloader valve problem or a crack in the pressure manifold housing between pressure outlet and unloader valve assy allowing unloader to cycle on/ off
or some dirt trapped in the unloader valve seat , make sure you have good supply of water - ie good flow from tap to pump
try cleaning unloader 1st and fitting in line tap filter
hope it helps
pauly46
May 20, 2011 | Karcher 2500 PSI Pressure Washer
Devibliss 60gal hp.runs to 120psi and cuts off, on restart it stalls and kicks reset on motor. Ive replaced pressure switch unload valve and pressure valve.stiill run. On second run at start you dont hear...
Some air compressors have 1 or 2 pistons one the piston sleeves could have a crack or a small hole what i would do is clean every thing and make sure the inlet valve is open and the unloader valve is clear of debris but if it doesn't help then you propably have a cracked piston sleeve I hope i was helpful ( tell me the model of it and i could get you more information)
Apr 07, 2011 | Campbell Hausfeld Air Tools & Compressors
2.5hp 40ltr unloader prob?
Motor stalling during the fill cycle would indicate problems with the intank check valve, weak capacitor or low power to compressor. The unloader generally opens only when compressor reaches set pressure. Easy test. Unplug compressor with air in tank and remove the small airline at the checkvalve (brass valve in tank). Listen for air leak. Checkvalve is ok if no leak at brass valve. Test capacitor for 95% rated value. Replace as needed or test for low power. Good luck.
Jul 30, 2010 | Craftsman Air Tools & Compressors
25 gal horizontal craftsman air compressor is leaking at the pressure control valve. Can I replace the valve or repair it?
Unloader valve probably needs to be adjusted. Should be two jam nuts holding the unloader to the pressure switch. Loosen the jam nuts and adjust the unloader slightly away from the lever. Tighten the jam nuts and try it again.
May 21, 2010 | Air Tools & Compressors
My granduaghter steped on my remote control now i cant get some of mychannels
sounds like the internal pcb is cracked i take it you can still go up and down the chanels? Time for a replacement ask your home insurance if they will replace on policy
Jul 12, 2009 | Sanyo DP32648 32 in. LCD TV
Open Questions:
See all FAIP Non Marking Pressure Washer Hose 4000 Psi, Questions
FAIP Non Marking Pressure Washer Hose 4000 Psi, 50ft. Length Logo
130 people viewed this question
Top FAIP Garden Experts
roeb
john h
Marvin
Marvin
Are you a FAIP Garden Expert? Answer questions, earn points and help others
