Question about Kenmore 6000 BTU Single Room Air Conditioner
6000 BTU window A/C makes loud sucking sound while running. I've cleaned the filter multiple times. It seems to be draining OK, and it blows cold. I found this post online, and it sounds like my problem. What should I do? "I bought one of these between 3 and 4 years ago. It did get heavy use during the summers; I installed it per the directions, I cleaned the filter regularly and did everything else I knew of to do for maintenance. Lately it had been doing a strange sucking or slurping sound while it was running, and I noticed the air flow was diminished even on high fan speed. I shone a flashlight down into the vent where the blower fan is, and discovered that the blower fan was moldy and disgusting. I took the front casing off and attempted to get to the fan in order to clean it. There is a motor shaft and the fan connects to that with a clamp and screw. However the metal parts are rusted and I cannot get the fan to come off. I can't really clean the fan properly without getting it out and away from the rest of the unit, as there is no clearance inside the unit. I'm getting frustrated since I can't get it apart to clean it, and I don't want to run it anymore with it moldy and disgusting. I'll probably end up throwing it away and getting something else. All in all I'm a little disappointed that I'll be pitching this thing after a few years, when the last unit I had ran a good ten years."
    President:
  • 2,559 Answers
There are only a couple of screws outside and along the side that hold the inside section and outer casing together,removal of these screws will allow you to slide the indide section out while leaving the case still in the window opening,this will allow for cleaning all of the inside parts.
Posted on Aug 04, 2010
  • dnewmank Aug 04, 2010
    Hi, thanks for the quick reply! So you think it's just dirty inside? Last night, I left the front grill open, just to see what would happen, and the machine didn't make sound. It's almost like the machine can't get enough air flow when the grill is closed and it's suffocating.
  • Randy Hough
    Randy Hough Aug 05, 2010
    Yes, it's just build up of dust and such and you can even use a water hose to wash the outside coil off as well,Just give it a good cleaning and it will be fine.
My washer just came to the end of the wash cycle and started making a loud grinding noise when it is time to drain. It won't drain.
from your description , there is something interfering with the impeller in the water pump
could be button, coin , hair clip, bra wire that has damaged the impeller blades
Rather than mess around trying to repair I would just get a new unit as the same time and difficulty is for both operations
Dec 10, 2015 | Washing Machines
New, loud noise - what is it, what to do?
How long has it been running since taking it back out of storage? I have heard that noise from many a AC unit and its usually the refrigerant moving around on the first startup, but usually goes away. The other things i could think of is if its really humid it could be condensation build up thats getting splashed by the outside fan, not the blower that moves the room air through it but the fan that blows the hot air out the back side on the outside. If it has a condensation drain that allows the water to drip out the bottom on the outside make sure its not plugged up, and also make sure the AC has a bit of a downward angle to it, so that the outside end is slightly lower to allow condensation to flow to the outside. If none of that solves it you could have developed a leak and lost some refrigerant and what your hearing is the compressor sucking at the refrigerant, think of a water pump with an occasional air bubble in the line, or when you turn on the garden hose and it has to purge the air out before you get a solid stream of water. But i would check the easy things first because most window units now days are throw away, can't repair or recharge them.
May 04, 2017 | Heating & Cooling
Rheem RPKA-030JAZ MAKES A HARD KNOCKING SOUND
sounds like it's running backwards. possibly need a time delay in the condenser. make sure your drain line is clean.also inspect low voltage wires for bare/ chew spots near outdoor unit.
Oct 12, 2017 | Heating & Cooling
Steam coming out of dishwasher
Sounds like the drain hose is partially plugged restricting the water to completely pump out.
Mar 28, 2017 | Dishwashers
How can i fix this problem
it sounds like it might be cloged up it happend to mine i had to put 2 small holes in the bottom out side and get all the leavs out of it then i had to clean the filter
Jul 11, 2012 | Danby 6000 BTU Window Air-Conditioner 10.7...
I have a Kenmore 25,000 BTU unit; and, unsure if it was not properly installed. On the front in looking inside there is alot of white installation covering the vent. I don't think this is normal?
Is it cooling ok?
If this is a window unit, it sounds like you're looking at the filter, which would be ok, assuming it's not clogged. You should be able to pop off or remove the front of the appliance and see if the filter is dirty.
Apr 18, 2011 | Heating & Cooling
Heater starts and runs for a short time and them quits!! Have cleaned all the filters nozzle and checked photo cell alignment. Seems as thought the flame is not 100% when it quits, possible photo cell...
What you are describing sounds more like a lazy fuel pump. When starting it, there is excessive fuel in the chamber to start with. Once this burns off, the pump can't maintain the same level of combustion.Another cause might be with a plugged up injector nozzle.
Dec 20, 2010 | Reddy Heater 60,000 BTU Kerosene...
Warm air
could be several things...if all is working/blowing and its clean inside & outside with a clean filter then more then likely it's low on gas/freon......if you continoue to run it it'll pobly ice up/freeze......also make sure you hear the compressor running as well as the fan blowing. sometimes this can be tough listen for that deep rumble/humming sound thats the compressor.
Jul 08, 2010 | Frigidaire FAC126P1 wall/window Air...
Envirovac kicks debris back at my feet and is loud
It's clogged!
Many so-called "environmentally friendly" vacuum cleaners have multiple stage filters; the usual configuration is a standard filter followed by a HEPA filter or equivalent. Standard filters can be a paper bag or a bagless, removable container.
From time to time, the secondary filter will get clogged, so it doesn't matter whether you change the bag or empty the container, performance will not improve.
If you have access to compressed air, try removing the secondary filter and blowing it clean with a high pressure air nozzle. If that doesn't work, check the hose to make sure it's clear. If you are using a rug beater attachment, make sure it has not clogged at its inlet.
Sep 06, 2009 | Eureka High Filtration s Mighty Mite...
Heating & Cooling Logo
88 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
