Question about HP w17e Monitor
Monitor looks pink in white areas. - HP w17e Monitor
  • 732 Answers
Ghrit, if disconnecting-reconnecting the vga cable 4 or 5 times won't cure your PINK screen, then you may have bad inverter supply or the "cold-cathode-fluorescent-lamps" might also be a bit tired-out and need replacing? Retrevo .com lists unit as over the hill but not ready to retire. Do some reading in my and other ("budmrtn" "buddymc") fixya profiles for info on what to do!!! Follow the links you find there to learn about pink screen and also black screen and blank n black screen conditions that occur with all brands of CCFL back-lit lcd monitors. Do some research here at FIXYA and pay a visit to YOUTUBE for video clips of "lcd monitor repair" "lcd monitor disassembly" so you have info for future use. Bye for now 12fixlouie
Posted on Aug 04, 2010
I have a toshiba l355 s7905 the screen has red lines making the white areas look pink, just bought it used any suggestions
follow these step.
1.- connect your laptop to external monitor (vga port)
If the image on external monitor is clear and show fine, you need replace the LCD Display.
You can buy at
http://www.lcds4less.com/
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 19, 2011 | Computers & Internet
The monitor color is pink...i want it to change to normal color...
Colors on the monitor are produced by mixing the three "primary" colours.
If the monitor is not producing one of those three colours, you can get "pink" instead of "white".
Fix the monitor, or replace the monitor, or replace the video-card (if using a different monitor also produces "pink").
Jun 21, 2011 | Computers & Internet
All the whites in the screen turns pink.
If the pink areas are streaky then the problem is the CCFL lamp.
Please click on this link and follow my instructions to determine the exact fault and fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Sep 14, 2010 | ASUS MB17SE LCD Monitor
I have a compaq desktop, winxp sp3. white has turned pink
The monitor needs some minor repair and alignment that's all
If you are any good with electronics and have a bit of decent test gear lying around you could probably do this job yourself.
But if not then a local TV or computer repair shop will be able to handle it and it should not cost too much.
Its a common problem on older CRT type screens
Aug 19, 2009 | Computers & Internet
Canon PowerShot S410 got wet. Now digital output
you may have ruined your monitor!!swampratt200!!AAEEE!!!
Jul 22, 2009 | Canon Cameras
Tiny pink dots will appear over the entire monitor viewing area
Its a signal cable problem,between AD bord to Panel..Fix it poperly, If no then replace the LCD panel..
Jul 10, 2009 | HP w17e Monitor
Whites look pink
this is a ez one go to setting and change the brightness if that dose not work tll me at alexswierenga@yahoo.com
May 29, 2009 | Mag Innovision InnoVision XJ 717 Monitor
Pink Screen
The reason its pink has two possibilities one is that you have a bad cable and needs to be replaced the second and most likely is that the backlight bulb is going out on you and will need to be replaced. When backlights go out things look pinkish reddish and then just go out all together.
If this helps please rate fixya
Thanks
May 04, 2009 | ViewSonic VA1930WM LCD Monitor
Screen goes pink
First, plug a external monitor and toggle the screen to discard configuration or software problems. If the image displays correctly you have a problem either in the LCD screen or its connection cable.
Open the bezel and check for loose or damaged connection cable. Look specially next to the hinge, ON THE LEFT.
In case the problem is not the cable you might have to get a new LCD. You can have replacement parts and instructions here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ViewObjectID=56222
Jun 27, 2008 | Acer Aspire 5102WLMi Notebook
Pink highlights on LCD screen
IT SOUNDS LIKE THE MAIN BOARD IS BAD. THERE IS 2 DIFFERENT VERSIONS FOR THIS SET .AM02 UNITS OR VERSION 0001 UNITS. THE PART NUMBER IS BN94-00695E. THEY BOTH ARE ABOUT $210 + $50 CORE.
DON..
Jun 02, 2008 | Televison & Video
HP w17e Monitor Logo
609 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
