Question about GE Profile JGSP48 Gas Kitchen Range
The electronic control on our range is not working so we cannot get neither the oven nor the clock to work. The digital display shows "F7" in red (on all the time) and" EC" in green (flashing). I will like to know what these letters/numbers mean? Do I have to replace just the Keypanel Support Assembly or the oven control too? Any advice or suggestions will be greatly appreciated. mmg
  • mmgallo64 Aug 06, 2010
    The solution given was very helpful. Thanks
    mmg
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F7 on your GE means that the keypad is shorted or stuck and to resolve this issue you’ll have to replace the Electronic Range control (ERC). Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 04, 2010
  • mmgallo64 Aug 04, 2010
    Thanks for your answer. So I will have to replace the ECR, but how about the keypad (Keypanel Support Assembly), would I need to replace this part too?
    mmg
  • Rylee Smith
    Rylee Smith Aug 04, 2010
    Try to clean the key pad with the help of a hair dryer if it still wont respond then you'll have to replace both ERC and the keypad. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Alarm comes on and display shows f7 code
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 11, 2011 | Kenmore 47702 / 47704 / 47709 Electric...
I have a jennair model sce30600wc, it was showing a f7 error code. if iI unplugged the oven it would usually work. Now the display does not illuminate but the oven works. DOes the keypad need replacing or...
Kevin
Jan 14, 2011 | Jenn-Air SCE30600 Slide-In Electric...
My oven beeps and show error code F7 on the panel. Help!!!
Kevin
Dec 02, 2010 | GE 27" Built-In Double Electric Convection...
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Oven showing f7 on lower oven
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning . F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control. you can get the required parts at www.repairclinic.com thanks.
Jul 11, 2009 | GE Profile JB968 Electric Kitchen Range
F7 Code on my GE Profile Oven
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
Double GE wall oven - F7 code
from repairclinic.com:
Apr 27, 2009 | GE Ovens
F2e0 error on stove
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
The lcd scrren on my range displays F7 in red and flashes d6 in g
The code is because of bad keypad/the control panel.Have it changed.It probably non-functional and constant beeping sound is followed as you mentioned.Theres a link to explain more about this for reference.The only solution is to replace the control panel.
http://www.askgene.com/2007/06/23/oven-error-codes/ge-oven-error-code-f7-and-how-to-fix-it/
Dec 13, 2008 | GE Spectra JBP78 Electric Kitchen Range
Panel is showing f7 and flashing e6 57 56 58 5a
F7 is a stuck key. Usually you can't get a key unstuck. Best thing to do is replace the keypad / user interface. Here are some of GE's error codes:
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Dec 01, 2008 | GE Profile 30" Self-Cleaning Slide-In...
GE Profile JGSP48 Gas Kitchen Range Logo
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
