Question about Whirlpool Dryers
I have a whirlpool dryer model number ler7648kq2 serial # mm1612410, the knob push to start won't stay on unless you keep pushing it to stay on
  • 119 Answers
YOUR PUSH TO START BUTTON IS A COMBO RELAY. MOST LIKELY IT IS BAD
Posted on Aug 04, 2010
Whirlpool electric dryer will not start when start knob is pushed
First check beaker flip it off than back on next check the door switch if tab missing or loose it should spring back when pressed next the dryer may have over heated the thermal fuse may have blown
Nov 03, 2015 | Whirlpool LER4634J Electric Dryer
Kenmore dryer model 110.74994300 push start does not stay on
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Kenmore Whirlpool Dryer Won Start Easy Fix
Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Jul 01, 2014 | Kenmore 62602 Electric Dryer
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
Searching for Model Number for a
post a picture of the dryer with the door open
Dec 27, 2012 | Dryers
My Kenmore 600 series dryer won't start when I push the start knob...I can hear a hum when the knob is pushed in but it won't start. Any suggestions?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
'lll
Aug 17, 2011 | Dryers
When washing Machine goes into spin cycle, , it starts making a grinding noise and never goes to full momentum and starts to slow down, after the grinding noise. The clothes aren't fully dry as they...
Sometimes, a Whirlpool dryer may not function as you'd like.Although specific details vary by model, the company offers several generalguidelines to troubleshooting your Whirlpool dryer and getting it back intoworking order.
Verify that thedryer is connected to its power source if it won't turn on. Whirlpool alsosuggests checking your home's circuit breaker, as the high power needs of thedryer may have tripped the circuit. If the circuit has been tripped, reset itby flipping it back into the "On" position. Push the door of the dryer. Whirlpool designed its appliances to not turn onif the dryer isn't secured and notes that the dryer door may not be fullyclosed even if it appears shut. Push firmly at the top and bottom of the door,as some Whirlpool models have two latches. Press the "Start" button again. Whirlpool reports that some modelsrequire you to press and hold the button for five seconds to fully start themachine. Depending on the model, the button may be labeled "Hold toStart," "Start" or "Push to Start." Check that the dryer's settings knob is set to an actual drying mode and notsimply "Air" or "Tumble." On most Whirlpool models, themanufacturer states that the settings knob should be set to"Accudry," "Timed Dry" or "Automatic Dry." Clean the lint trap, typically located at the top of the dryer and removedby pulling its plastic handle. Over time, lint and dust builds up here. Thethicker the trapped layer of lint, the slower your dryer performance. Whirlpoolrecommends removing built up lint after every dryer load. Remove some of the wet clothes inside the dryer if it's taking an unusuallylong time to dry your clothes. Whirlpool warns that placing too much clothinginside the dryer reduces hot air circulation, which also reduces dryingcapabilities. Recommended dryer load s vary, with compact Whirlpool modelsholding approximately 3.4 cubic feet while extra large Whirlpool dryers holdingmore than 7 cubic feet.
Jun 07, 2011 | Washing Machines
GEW9878LW Electric Dryer: Whirpool Dryer - Model # GEW9878PWO - Serial # MS4...
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 18, 2010 | Whirlpool GEW9878LW Electric Dryer
Wire diagram for Whirlpool dryer model Number Ler7648kq2
Should be under the lid of the unit, use screw driver and pry top off after removing two screw on the retaining clips on back
Mar 23, 2009 | Frigidaire FSG748GF Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
173 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
