Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Hi, my GE Profile PSG22SI series 2 door fridge has a hose broken at the back and itdisappears into some sort of solid device where you can move the hose up and down a little bit, but can't disconnect it, or even see where it is connected at the other end. Any ideas on how to fix? thanks much. Keith
watugot
  • 290 Answers
SOURCE: GE Icemaker flap door won't open causes ice jam in chute
There is an electric solenoid that opens the door. If you look up inside the dispenser you can see the solenoid. Either the solenoid is bad or the dispenser module that puts power to it is out. You will need to remove dispenser front and check for voltage to solenoid. If you have power from module, replace solenoid, if no power, replace both parts. It is common for solenoid to short out and damage the module so that both must be replaced. If solenoid is shorted and you replace module, new part will fry.
Posted on Oct 02, 2007
  • 93 Answers
SOURCE: GE PSC23SGRC SS refrigerator (Arctica) Profile
Main board is out. Replace. Located on rear of unit
Posted on Jul 17, 2008
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Posted on Sep 21, 2008
SOURCE: GE Profile Side by Side is getting too cold on the fridge side.
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
Posted on Mar 01, 2009
jumptrout51
  • 3361 Answers
SOURCE: My GE Profile fridge periodically (eve other n) leaks water
Thaw out the defrost drain in the freezer. It has frozen over and the defrost water has nowhere else to go except on your floor.
Posted on Apr 08, 2009
My GE Adora side by side makes ice but the water dispenser barely dispenses.
Did you recently move the fridge? One possibility is that the supply line in the back of the fridge is kinked. Usually it is coiled so you can move the fridge out and back damage but if it gets kinked, it would limit the water supply like a hose does when kinked. Also, the supply line is usually tapped from under the sink. Make sure the valve that supplies the line (usually 1/4 inch line) is fully opened. If that fails to help, then you're back to the solenoid valve for water that is not fully opening. Should give a solid clunk when actuated. G
Jan 27, 2014 | GE Adora (DSF25KGTBG) Side by Side...
Fridge door not closing 100% at the top.
Loosen the screws holding the top door hinge. Pull up on the freezer door and hold it while you re-tighten the hinge screws.
Dec 31, 2009 | GE Profile Arctica Stainless Steel Top...
GE fridge is warm and broken; the freezer is cold though.
Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
Ice/water tubing broken during move
If the tubing broke off evenly at the door , have to replace the door . G E's cant replace the tubing INSIDE the door . A used appliance store may have a door .
Aug 05, 2009 | Freezers
Top lock on GE Profile Fridge is broken
bad news you have to replace the door gasket
they only sell them in pairs and not cheap
Jul 03, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
The entire backwall of the unit is solid ice. 2
OK first defrost the refrigerator. Unplug and remove the back panel covering the evaporator and lets look at the defrost element and defrost thermostat. If they are OK we may need to have a look at mother board mounted on back of fridg. Let me know when you are ready, Sea Breeze
Apr 22, 2009 | GE Profile PDS22SCRL Stainless Steel...
Fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
