Question about General Electric Profile JGP945 30 in. Gas Cooktop
I have a 2003 gas oven, model #JGBP28BEK3WH. All the top burners kick on but the oven doesn't. I can set the oven to preheat but so far it never lights. Please help.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
You probably have a bad ignitor in your oven. The gas will not turn on until the ignitor glows red hot - less resistance and more current for valve to open. This can be replace by a repairman or a tool savvy homeowner. If you call a repair man, your looking at 150.00 to 200.00. Part can be from 50.00 to 110.00. I usually charge 110.00 plus the price of the ignitor.
Posted on Aug 04, 2010
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
Maytag Range won't heat up oven or cook top
you have melted internal wiring, probably some mice ate it. call an electrician and DO NOT USE IT!! turn off at the wall/fusebox
Nov 20, 2013 | Maytag MER8770WS 30" Freestanding Electric...
DCS RGS slow to preheat
You didn't state whether you used a DCS conversion kit or not. I was able to find conversion instructions for a model similar to yours (not an exact match) but it will give you an idea as to what all is involved.
DCS RGSC 305 Instructions Manual
Dec 14, 2017 | DCS RGU-364GL-N Professional Series 36"...
Spark ignitors went on stove top
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jan 09, 2010 | Whirlpool SCS3014LS Gas Cooktop
Gas range with stricker burners and oven burner
Most likely the oven will not work because the striker is not coming on. I am not very familiar with this stove but most thermador gas oven uses a electronic igniter. the switch controls both the igniter(striker) and safety solenoid so if neither the striker or solenoid is not powered up the switch may be the problem
Regards
Nov 07, 2008 | Thermador SGS36GS Gas Cooktop
Thermador PCS364GDUS griddle needs cleaning.
Wear gloves, put all items in a garbage bag. Put outside and spray a can of easy-off oven cleaner on all parts. Seal bag and let sit for 24 hrs. They should come out looking new after you rinse them off. After you wash them off, put them in a 300* preheated oven for about 30 min to ensure they are dry.
Oct 22, 2008 | Thermador PC366BS Stainless Steel Gas...
Extra low burner that won't ignite
Lowly what the potentior does is turn on the burner control system. When you turn on a normal burner you are opening a gas valve and closing a switch to generate a spark. Thus gas flow to the burner and spark. On the extra low simmer burner there is a electric solenoid between the burner head and the gas valve. this has to open as well for gas to flow. What the potentior does is signal the simmer control what level of flame you are requesting and telling the spark module to generate a spark. Once you go to the exlow setting the potentior tells the simmer control what level of heat and will cycle the flame on and off. So when the burner knob was between low and extra low, the flame would cycle on and off. You have to seperate the top section of the cooktop from the burner box to change the potentior for it sits on top of the gas valve for that burner.
Aug 10, 2008 | Thermador SGS36GS Gas Cooktop
Ignition sparking repeatedly
I have a Creda gas stove ,yesterday some water boiled over. I have a continuous spark ever since and the stove is not even on. Is there any way to reslove this without calling a repair person?
May 01, 2008 | Cooktops
General Electric Profile JGP945 30 in. Gas Cooktop Logo
Top General Electric Cooktops Experts
gbob59
ray gallant
Are you a General Electric Cooktop Expert? Answer questions, earn points and help others
