Question about Garmin nuvi 1390T Car GPS Receiver
The unit froze on "loading maps" when turned on yesterday. IF I plug it into my desktop, the "loading maps" screen is all that will appear. I have tried the "Factory Reset" and can get the screen with the question "Do you really want to erase all user data?" to come up but the unit will not respond to either yes or no. Is there a "reboot" solution? Dale Voice Cadillac, MI
    President:
  • 3,278 Answers
Hello, Dale.
Try this WebUpdater from Garmin Support:
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Hope this helps.
Posted on Aug 04, 2010
DO the Garmin receivers work with Windows ?
Yes the Garmin DPS units do work with Windows. There should be a USB cable in the box the GPS came in. The smaller end plugs into the GPS and the larger end into one of your computer's USB ports. The GPS screen should come on and show the Garmin name. Then the Loading Maps title should show briefly. A graphic should show up on the bottom part of the screen that looks like a desktop computer connected to a GPS. A horizontal white line should then appear about half way up the GPS screen which should turn to green. You should then be able to see your GPS listed as a removable drive in Windows Explorer, or whatever file management program you use.
If you are unable to see the GPS unit there is a plug in available on their website called the Garmin Communicator Plug-in which should help you see the GPS unit in Windows or your internet browser. IF you still cannot see it then try and switch to another USB port on your computer. If you have anything already plugged into a USB port and your computer can see the item, then try and plug your Garmin into that port. If you still cannot see the unit then there may be something wrong with the unit or your cable. If you still have a warranty you may want to take your unit back to the store you purchased it from. Windows should definitely see the unit without having to load any special driver.
Mar 06, 2011 | Garmin nuvi 1450 GPS Receiver
I have never updated my GPS and have had it for about 2 years. The map froze in one spot while driving around and I turned it off. When I did that it then said the map was locked. I tried a reset and now...
try plugging it in to the computer and updating it. chances are it could be a bug in the software and it should be fixed in the newest software update.
Feb 28, 2011 | Garmin nuvi 250W GPS Receiver
Gps has lost its maps, screen says can't unlock maps
There several reasons you may receive the message Can't Unlock Maps on your nuvi or zumo device.
  • Can you press OK and get to the Where To/View map screen?
  • Did you load maps to the unit using the MapSource or MapInstall program?
  • Did you load maps to an SD data card?
If one of the points above applies to you, please follow the steps below to clear the Can't Unlock Maps message:
  1. Remove SD card from unit, if applicable.
  2. Plug the unit into your computer with a compatible USB cable.
  3. Open MyComputer/Computer icon. (Mac users skip this step.)
  4. Right-Click on the Garmin drive and select Open. (Mac users can locate the Garmin drive mounted on the Desktop.)
  5. Open the Garmin folder.1
  6. Locate a file named gmapsupp.img
  7. Right-Click and delete file named gmapsupp.img
  8. Safely disconnect your unit from your computer to see if the Can't Unlock Maps message is gone.
1. Nuvi 1100/1200/1300/1400/1600/3700 and Zumo 665 users will open the Map folder instead.
*If the gmapsupp.img file does not appear in the Garmin folder, please create an unlock file for device.
Nov 28, 2010 | Garmin Nuvi 265W GPS Receiver
My garmin turns on but freezes when loading maps. I tryed to reset but did nothing.sometimes it will stay froze and sometimes it will turn itself off.serial #12p238176
Clear all ur installed apps/data/music/pictures first. Turn the unit off and then on. while on, reset it again. turn it on again and now connect it ur PC to load additional maps and see if it helps.
thanks
Aug 11, 2010 | Garmin Nuvi 660 GPS Receiver
Gps will not start up
Hello :
I recommend you to reset your device to fix the problem .
Here is how to reset your GPS :
1. Turn unit OFF
2. Press and hold the PAGES key
3. Press and hold the PWR key
4. Release both buttons when the USA map appears
Here is how to hard reset your GPS . But be careful because Hard Reset (Deletes stored GPS Data such as Waypoints and trails)
1. Turn unit OFF
2. Press and hold the ZIN&ZOUT Keys at the same time
PLEASE DON'T FORGET TO RATE !
Apr 16, 2010 | Lowrance LCX-15MT GPS Receiver
Garmin Nuvi 1250 stuckin "loading maps" screen
I just plugged my 1350 in (had exact same problem) into computer and deleted the GPX (trip log) and it finally started back up. Deleted all of the favorites and such but it working again.
Feb 05, 2010 | Garmin nuvi 250W GPS Receiver
Maestro 4250 frozen after incomplete 2009 map up date
I had same problem on 3/28/09.
According to Magellan and other people who have experienced the same problem, this is terminal to the unit. It can be caused by downloading the 08/09 Magellan map upgrade, which can cause the unit to permanently lock up. Magellan is well aware of the problem, and should offer to replace your unit if you have the problem. If you elect to have it repaired, Magellan can download the map upgrade for you in the repair process. Here is a site noting the same problem: http://74.125.93.104/search?q=cache:pNLjGT-i4-sJ:forums.gpsreview.net/viewtopic.php%3Ft%3D8958+magellan+4250+gps+stays+on+blue+screen&cd=8&hl=en&ct=clnk&gl=us
Questions for Magellan: 1) why would they sell, in 2009, gps units with old 2007 maps loaded in them, requiring the purchaser to buy a current map, and 2) if there is a problem with downloading the current maps, why is there not an advisement or warning to the installer.
Other than replacing the unit, there appears to be no "fix".
Mar 29, 2009 | Magellan Maestro 4250 GPS
My GPS froze
its the battery problem as its getting drained and near to getting weak.
Mar 02, 2009 | Garmin Nuvi 660 GPS Receiver
Streetpilot c330 Frozen on.
take the face plate off of it, and to the right of the screen there is a reset button
May 04, 2008 | Garmin StreetPilot C330 GPS Receiver
Error screen trouble shooting
If you have the USB cable and a dvd/cd that contains the software/maps, then it needs to be loaded. Install the software on your computer. With the unit off, plug it into USB, then turn on unit. run program installed from dvd/cd. you can also try resetting the unit by holding down the Menu and Nav key, hopefully a small box appears and you can use the stiff stick to change the numbers. if this does appear, change the numbers to read 32 then press the stiff stick in (pressing enter). _Daniel
Apr 13, 2007 | Magellan eXplorist 200 GPS Receiver
Garmin nuvi 1390T Car GPS Receiver Logo
63 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
